33 inch tires with fat bobs 2.75 lift
Discussion in '5 Lug' started by ToddToddSherman, Apr 4, 2014.
  1. Apr 4, 2014 at 3:31 PM
    ToddToddSherman
    ToddToddSherman [OP] ToddToddSherman
    Todd
    San Diego
    2008 4 cylinder 5-lug
    still stock looking for improvements
    I've looked everywhere and I haven't found an answer. Has anybody put 33 inch tires on a 5 lug with a fat bobs 2.75 lift. The only thing I've seen people using is 31, which is what fat bobs recommends. I'm just curious if you could run a 33. And I am aware that it'll rub
    Thanks
  2. Apr 4, 2014 at 3:39 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Well I mean why couldn't you? Worst is going to happen is rubbing...
  3. Apr 4, 2014 at 8:42 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I would think putting 33s on a 5 lug with that lift is like putting 35s on a 4x4 with a lift. It will do more than just rub. You will hardly be able to turn. And heaven forbid you actually stuff tire
    Also depends on how wide. No way you can fit a 33x12.5. 4x4s rub with 3" and 33s. And you are at least 3" lower at least
  4. Apr 4, 2014 at 9:06 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    I test fitted 285s when selecting tires and they will clear. Black box removed and if stock bumper it will have to b trimmed as well.
  5. Apr 5, 2014 at 9:42 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Just curious, I thought because of the way the fenders are, 31's can fully articulate through them regardless if you are a 4x4 or not. Correct me if I'm wrong...
  6. Apr 6, 2014 at 12:49 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    not sure what you mean by this. 4x or not, the 6 lug suspension is the same, and of course a 31 will be fine as its stock
    both of you guys have 6 lug suspension. totally different
  7. Apr 6, 2014 at 6:42 AM
    Skinny Rogers
    Lance
    NC
    10 taco
    No sir I'm a 5 lugger
  8. Apr 6, 2014 at 7:53 AM
    jtye
    jtye Well-Known Member
    DC
    08 Super White 5 lug
    Fog lights, fatbob's 5lug lift, Cragar 15x7, 31x10.5 Gen.Grabbers, Wet Okole
    There was a 5 lug on here with 32's that had to do a lot of trimming. I'm sure you could 33's under there if you really wanted to, but the one thing I do know if that you would need to regear immediately. I've got 31's and thought I'd be fine with stock gears, and I was wrong. It was totally killing my mpg and 5th gear was completely irrelevant. 33's would be a joke with stock gearing.
  9. Apr 6, 2014 at 4:59 PM
    Skinny Rogers
    Lance
    NC
    10 taco
    Neslerrah is running 33 with a readylift which is the same as fat bobs. Prerunner style front bumper and he was ok. Also on stock gears. I'm sure he lost 5th gear as well. I'm on 265s and stock gears and don't really see a need for the regear. But I'm an automatic.
  10. Apr 7, 2014 at 11:41 AM
    jtye
    DC
    Maybe it's just because I've got the stick shift, but it was really getting to me. Really had to wear out first gear to get anywhere around the hills around my apartment. Plus I think the stock gears for stick are 3.38 and auto is a little better like 3.58 or something like that?
  11. Apr 7, 2014 at 12:44 PM
    ToddToddSherman
    Todd
    San Diego
    I'm not really dead set on running 33s I just wanted to get a little more lift. I plan on making a prerunner front bumper anyway so I'll probably end up with a 32. I'm also planning on getting a cold air intake and aftermarket headers. Do you still think I would need to regear?
  12. Apr 7, 2014 at 1:10 PM
    Skinny Rogers
    Lance
    NC
    10 taco
    I ended up running p rated 265s on an alloy wheel to save weight. I had plans to regear with ecgs and really didn't see the need to. It still does what I need it to do. If I went to a larger lt tire I would regear most likely. But it all depends on how the truck handled the tires. But for what I do what I have is just fine.
  13. Apr 7, 2014 at 3:38 PM
    jtye
    DC
    I would get the tires first and see what you think. I got a good deal on a complete 4.10 3rd from another TW guy so i pulled the trigger. Bolted it up with a friend in about 3 hrs, but it's not like the truck wont work with the stock gears.
  14. Apr 8, 2014 at 7:08 PM
    alwaysat8k
    alwaysat8k My truck is slow
    Virginia
    2012 Access Cab SR5 4cyl 5spd 5lug
    Fat Bobs 2.75" spacer, 1.5" Long AAL in rear
    I will tell you right now,33's will work, and they have been done. Im running 32's and have enough gap for 33's. I have no rubbing whatsoever with room for more. Matter of fact, I will be running 33's next tire set. You will have to do some chopping on the plastic fender well covers and black box mod, that is all.
    Gears:
    For the life of god, manual stock gears are terrible with 32's. I was shifting from 4th to 5th about a thousand times freeway driving. Under 60, there is no 5th gear. I had a rear end built by east coast gear supply with 4.30s.. perfect combo in my opinion. I have some geddy up now (as much as there can be with the camel speed 2.7l) and my gas mileage has leveled. I run on avg, 18mpg city, 21mpg freeway.
    BTW: Heres my thread where I documented much of my heartbreaks and ups and downs. http://www.tacomaworld.com/forum/5-lug/250374-de-estrogenizing-5lug.html
    I hope that it may help you. If you have any questions, please don't hesitate to PM me. Either way man, lift it and get rid of the grandma styling of the 5lugger! I couldn't be happier with my taco now!
  15. Apr 11, 2014 at 11:21 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    I was running 265/75s with no rubbing. I was running totalchaos/icon with no extra preload. its all in the alignment.
  16. Apr 19, 2014 at 7:18 AM
    gitsum
    gitsum Well-Known Member
    Gitsum
    Delawhere?
    5 lugger. BB mod. 15x7 black D
    BB mod, Black D 15x7, Grabber AT2 31x10.5x15, Fat Bob, Tractor Supply black truck box, class III hitch, 4.56 third member swap, home made console, tail gate hose clamp mod
    Im running 31's on a fat bob lift and 4.56's. im planning on moving up to 33's when these wear out and was going to do a 2" body to make sure I have good clearance. I think it will be sufficient
  17. Apr 19, 2014 at 7:35 AM
    Skinny Rogers
    Lance
    NC
    10 taco
    What width were u thinking?
  18. Apr 21, 2014 at 6:10 AM
    gitsum
    Gitsum
    Delawhere?
    The same 7" rim with 10.50" tires. The same as now other than height.
