3378jakesr5 expedition trailer build
Discussion in 'Other Builds' started by 3378jakesr5, Dec 15, 2014.
  1. Jul 29, 2015 at 9:22 PM
    3378jakesr5
    3378jakesr5 [OP] AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Oh yah and badge the crap out of it sense we are now a company and kinda do these things. XP
  2. Jul 29, 2015 at 10:46 PM
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I really like your trailer build. I am a debating on whether to build from scratch or buy a base trailer to build off of. How much would you say that you have invested in the basic structural metal? Could you post some specifics about the materials used (tube size/thickness, floor thickness, etc)? Would you say that it is necessary to get an axle with brakes or just a base hub? What are each of your electric lifters rated at?
    I know, I have a lot of questions... and more to come...
  3. Jul 30, 2015 at 4:36 AM
    TheBlackTaco
    TheBlackTaco Well-Known Member
    Forsyth, Georgia
    2008 tacoma SR5
    baja rack, ironman suspension, 33" bf goodrich
  4. Jul 30, 2015 at 5:29 AM
    3378jakesr5
    jake
    littleton colorado
    Pepsimankolt,
    If you are a confident enought welder I would say build your own. One welds are much stronger if done right. And two you can build it exactly to what you want. I used 2x3 box tube .120 wall. With the recived and supports being the 2.5x2.5 recived box tube .25 thick. The floor is 11 gauge sheet. The walls and top are 1.5 square box tube .120 wall and 1x3 box tube .120 thick skinned in 14 gauge. This is very very heavy duty In my opinion but wanted it to be. But you do have to live with the weight. Mine topped out empty with tent and one battery at 2,134 lbs. I have about 1,100$ in metal for the thing for the structure. Add in tent rack, fenders, tire carrier, and other little bits and peices add 2-3 hundred to metal. The electric breaks on this is I think a must. I love them. Your not burning your breaks as bad and you have stopping power provided by the trailer. This Is nice in down hill roads because you don't have to worry as much about the trailer pushing you down or wanting to jack knife. Also good for trails for the same reason and for ledges. Along with the Saftey of breakaway breaks. And lastly the actuators are 20 inch travle actuators found on Amazon, they each move up to 220 lbs and do a good job at it. You just have to build in some slop because unless you wire each of them to there own switch they will start to to out of sequence. Easly solved by slotted top mounting points so when you hear the first pop pin pop you can stop and then just go around and lift the corners up the little bit tell those pop in. Or continue with the actuators if you want to but I have self destructed one of them collapsing the tent :( that way.
    Jake,
  5. Jul 30, 2015 at 5:30 AM
    3378jakesr5
    jake
    littleton colorado
    Thank you,
    Sorry it took so long to update.
    Jake.
  6. Feb 29, 2016 at 8:21 AM
    3378jakesr5
    jake
    littleton colorado
    Tacoma SS and Red Baron like this.
  7. Feb 29, 2016 at 8:31 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Aint no body got time fo that :duel:
    3378jakesr5[OP] likes this.
  8. Feb 29, 2016 at 8:33 AM
    3378jakesr5
    jake
    littleton colorado
    hmmm your right!! i guess ill have to push pack some bed racks tell after moab then so i can get this done.
  9. Feb 29, 2016 at 8:35 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    look at you go! This is goals coming to life right here. Congrats
  10. Feb 29, 2016 at 8:36 AM
    3378jakesr5
    jake
    littleton colorado
    You need to come down and help too:boink:
    BohlaaH[QUOTED] likes this.
  11. Feb 29, 2016 at 8:37 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I would do it, youre only a few hours away haha, bit more than a few. Maybe summer holidays ill run down for a meet.
  12. Feb 29, 2016 at 8:40 AM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
  13. Feb 29, 2016 at 8:40 AM
    3378jakesr5
    jake
    littleton colorado
    Make it a 3 week holiday and come down for a week for moding everything then go to rock therapy!!
  14. Feb 29, 2016 at 8:43 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I can get about 21 days off if I use all my holidays, maybe ill have a chat with the girlfriend about changing plans. Was gonna go to the east coast, maybe I can convince her with the use of promised mountain boarding and hiking... But secretly offroading/ modding haha
  15. Feb 29, 2016 at 8:46 AM
    #35
    3378jakesr5
    jake
    littleton colorado
    see now your thinking!!!!
  16. Feb 29, 2016 at 8:46 AM
    #36
    3378jakesr5
    jake
    littleton colorado
    your tag is just broken
  17. Feb 29, 2016 at 8:54 AM
    #37
    3378jakesr5
    jake
    littleton colorado
  18. Feb 29, 2016 at 8:56 AM
    #38
    mountainmonkey
    Colorado
    Never enough
    Nope didn't get this one either...
  19. Feb 29, 2016 at 8:57 AM
    #39
    3378jakesr5
    jake
    littleton colorado
    welll how did you know i was talking to you??
  20. Feb 29, 2016 at 8:59 AM
    #40
    mountainmonkey
    Colorado
    Never enough
    Cause I got a notification that you replied to the thread and just assumed I was the broken engineer. I'd feel better knowing someone else is the broken one though :fingerscrossed:
