33s on a 4cyl....
Discussion in '4 Cylinder' started by '98_Taco, Feb 23, 2010.
  1. Feb 23, 2010 at 6:30 AM
    '98_Taco
    '98_Taco [OP] Member
    I've always had 32x11.50s on my '98 2.7L. I really want to go up to 33x12.50 All-terrains. I've got 6 in of lift so clearance will not be a problem. I briefly had a set of 33x12.50 Thornbirds on my truck, but I sold them after about a year because of the noise and it would bog down in overdrive, which I attributed mostly to the knob and resistance of the Thornbirds...
    I think with a smoother tire, I will be able to use overdrive even in a 33x12.50. I would appreciate any insight you guys may have to offer.:)
    My truck is a 5 spd.
  2. Feb 23, 2010 at 10:48 AM
    '98_Taco
    Oh Well,
    I just ordered 33x12.50 BFG All-Terrains. I know I would have kicked myself if I had gone with more 32s! 33s just look so much better to me. So what if I wont be passing anybody:D;)
  3. Feb 24, 2010 at 5:02 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I just mounted 33X10.50x15 BFG T/A KM2s on stock rims on my 2000. My truck is a TRD with the 4.30 diffs, so the 33s essentially brought my rpms down into the "stock" range. I lost a little power, but again, it just brought it back to where a 4cyl would normally be. I'm happy with mine. On the other hand, I go more for the effectiveness of the tire, rather than the look. The narrower tires are actually better for traction in all terrains except deep sand, less rotating weight (translates to better power and gas mileage), and no rubbing issues with a 2" lift.
    By the way, love the tire. Smooth, quiet, great tread...tall!
  4. Feb 24, 2010 at 1:58 PM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    99 taco 2.7l SAS
    Dana 44 front and some other useless things.
    ive got 33x12.5 Mickey Thomson MTZs on my 99 taco with stock 4.10s. Still drives fine, still able to use fifth on highway and still pass people :)
  5. Feb 26, 2010 at 8:15 PM
    Popperman63
    Popperman63 Member
    NW Arkansas
    95 Tacoma 4x4 2.7 L
    Deckplate mod, Elbow mod, Magnaflow exhaust, Toytec 3", 2" PA BL, 33x12.5R15 Kumho M/T KL71, Midland 1001z, PA, UWS Black Lo-Pro toolbox, Ext. Breather, Hella 500s, Black emblems, De-badged Tailgate, Custom rear bumper
    I've got 3.58's and 33x12.5 Kumho KL71's and I still use 5th gear and pass people on the freeway.
  6. Mar 3, 2015 at 1:16 PM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    i putting 4.00 gears in with 32 and a auburn posi
  7. Mar 4, 2015 at 9:40 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    98 2.7l w/automatic trans and 285/75R16 BFG A/T's with 4.88's - Couldn't be happier
  8. Mar 26, 2015 at 9:51 AM
    GreatChopps
    GreatChopps Member
    01 Taco
    rear camera, DVD In-dash TV
    with the 4.88 is there a decrease in power and MPG or did it bring it back to stock ratio. I have been on fence to do 5.29 to go to a 33" but My taco came with 265's with 4.56 and hills are not its friend
  9. Mar 26, 2015 at 10:30 AM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Lots of folks are happy with 4.88s and 255/85 (33.3) tires.
    If your regularly on the highway, It's recommended to go with 4.56 gears.
    My driving is more around town...so 4.88s for me please :)
    tacoburrito likes this.
