33s or 34s or 35s and why
Discussion in '3rd Gen. Tacomas (2016-2023)' started by milesperhour, Jul 28, 2020.
  1. Jul 28, 2020 at 1:34 PM
    milesperhour
    milesperhour [OP] Member
    2020 Toyota Tacoma OR Cement
    I know there is a bunch of post out there in this topic but would like to get some fresh opinions on running 33/34/35
    I truly want 35s I know what it includes cab mount chop or cab mount relocation, pinch welds, inner fender trimming, regear to 5.29. But I still can’t seem to commit to it just yet. I would consider 33s but from what I see sometimes they look tiny on the taco. I would do 34s but I feel like I might as well jump it up to 35s at that point. What would you guys do?
  2. Jul 28, 2020 at 1:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Go 33’s and if you need more get more.
    Evdunn, Aqualoon, crackils and 6 others like this.
  3. Jul 28, 2020 at 1:38 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    33's with a mild lift looks perfect on these trucks.
    Besides some 35's dont measure 35"s. So you get the weight of a 35...the cost of the tire itself plus what it might take to run that tire...and not any real benefit over a 33" tire that measures a true 33".
    Just do your research.
    Im on 255/80's FWIW
    Shippe, Evdunn, Falldownhard and 4 others like this.
  4. Jul 28, 2020 at 1:39 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    ive had stock, skinny 33s, and now 35s.
    the moment I went to 35s I wanted 37s, and still do. More ground clearance, more meat, and it looks better.
  5. Jul 28, 2020 at 1:40 PM
    milesperhour
    Should you regear for 33s?
  6. Jul 28, 2020 at 1:41 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Are you running steel armor?
  7. Jul 28, 2020 at 1:42 PM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    The pinch seam is the easy part of the CMC so you might as well do it while you're down there. You'll need to do the CMC if you're wheeling or mashing your 33's regardless. Fender trimming is cake if you can do the CMC yourself. You literally have the cutter out just trim as necessary and zip-tie if you need. If you want to get real fancy you can break out the heat gun or blow torch and mold your liners.
    As for re-gear you may want to consider that even w/ 33's. My truck was a bit of a dog when I did 33's and now has its pep back with 4.88's.
    What I am saying is: In order to fit the 33's properly you're going to be paying basically the same thing (money and labor) as going to 35's. Just go into it with that mentality and pick what you think is best. The only thing that's really going to weigh on you is your gear ratio -- you're going to have to marry it so re-gear only when you're 100% on which tire size you want to stick with. 33's and 5.29's without a ton of weight sucks I've driven 3 trucks with it and hated every one of them. 35's and 4.88's sucks, too. 34's are the happy medium with both ratios.
  8. Jul 28, 2020 at 1:42 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
  9. Jul 28, 2020 at 1:43 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I was not willing to tub, but I was willing to do all the other stuff. Plus I think 33s still look small on double cab long bed. Plus if I’m going to cut, might as well cut big. More capability. Hence 35s.
  10. Jul 28, 2020 at 1:43 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    the best answer so far
    Oreo Cat[QUOTED] and whatstcp like this.
  11. Jul 28, 2020 at 1:44 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    You dont have to tub for 35s...
  12. Jul 28, 2020 at 1:44 PM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I know. I’m saying that was why 35 was the upper limit for me.
  13. Jul 28, 2020 at 1:45 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    If marlin crawler would relese the rclt id have 40s
    whatstcp, Key-Rei, Chako and 2 others like this.
  14. Jul 28, 2020 at 1:47 PM
    tacotacosauce
    tacotacosauce Active Member
    Do what you want, if you think 35s look best, get 35s. Other people’s opinion shouldn’t matter, it’s your truck
  15. Jul 28, 2020 at 1:53 PM
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    Im in the same pinch myself. Brand new truck (to me) and deciding whether to go with 285/70/r17 or 315/70/17s
  16. Jul 28, 2020 at 1:54 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    315s every single time. No question. If 35s are on your mind, then you dont care about MPG to much. Youve also decided that you are going to gear the truck. SO at this point, go big.
    ghost_ix, t0nyvalenzuela and whatstcp like this.
  17. Jul 28, 2020 at 1:55 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    cab mout relocation, gears, and cutting required? Along with Adjustable UCA's a requirement?
  18. Jul 28, 2020 at 1:56 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I dont have adjustable UCAs, I have JBA high castor. I also havent relocated my cab mount, just cut it to shit and hit it with a hammer. Same with the pinch weld. I do have 5.29s tho
    There is thread dedicated to installing 35s on tacomas, you should take a gander at it
    Edit: here it is https://www.tacomaworld.com/threads/intro-to-fitting-35s-3-lifts.594309/
    Rockefelluh likes this.
  19. Jul 28, 2020 at 1:56 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    53's you want a monster truck anyway
    the.sight.picture likes this.
  20. Jul 28, 2020 at 1:57 PM
    overlandozzy1
    Jonathan
    2016 WHITE DCLB
    Got a link?
