An Oil Filter Mess
Discussion in '2nd Gen. Tacomas (2005-2015)' started by no_werries, Apr 19, 2009.
  1. Apr 19, 2009 at 9:41 AM
    no_werries
    no_werries [OP] Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Doing my second oil change in 4 weeks today, these long drives are killing me, my question is do any of you have a method for removing the damn thing without making a major mess, this time around I just grabed a bunch of rags and wraped them around the filter as I unscrewed it to catch most of the oil that spilled out but still made a mess, anyone got any advice for me??
  2. Apr 19, 2009 at 9:42 AM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
  3. Apr 19, 2009 at 9:43 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Just put a cup under the drain hole. Hold the filter there for a minute after you unscrew it and let it drain. I do this and never have a drop spill.
  4. Apr 19, 2009 at 9:50 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Wilson hit the nail on the head.
  5. Apr 19, 2009 at 10:11 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    A 1 liter bottle with the neck/spout chopped off makes a good catch can. It'll sit right on the belt and it's still tall enough to catch what ever you have dripping.
    Search for the Ultimate Oil Change thread. It may of already been given to you. Chris and others use a clear tube and run it into the drain pan you use for the crankcase oil catch. Lowe's has this tube in the plumbing dept. It was .79 cents a foot. You'll need 5ish feet. Then grab a couple of wooden golf tees or bolts to plug up the ends of the tube after you drain it. That'll keep the residual from making a mess in your tool (giggity) box or your work shop.
  6. Apr 19, 2009 at 10:55 AM
    no_werries
    great thanx for the help all, and canucksinsc, I'm a beach bum from Wasaga!!! Go Blue Jays, wtf Leafs, and why the hell would they be upping the price on argos tickets?
  7. Apr 19, 2009 at 11:06 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    The only thing I could add to Chris's write up is the drain valve on the oil pan. Changed mine the other day with no ramps, 10 minutes, and no mess.
    I don't have the valve with the nipple, and it doesn't matter, as it doesn't splatter while draining into the pan because of rate of flow. Save the $$ on the reg. model. IMO.
    http://www.qwikvalve.com/search.php?mode=search&substring=&makeid=58&modelid=156
  8. Apr 19, 2009 at 1:02 PM
    TheSchwartz
    TheSchwartz Well-Known Member
    Aaron
    Smithsburg, MD
    '11 DC/LB SR5 Magnetic Gray
    Avid BullBar, BFG 265/75R16, remote car starter, Slim's HID heads and fogs
    I think fram hos somthing like this and it comes with a hose
    link
    http://www.jegs.com/p/Fram+&+Autolite/750898/10002/-1
  9. Apr 19, 2009 at 1:06 PM
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
    I drian the pan and pull out the dip stick before changing the filter and had no mess at all. i didnt even need the hose on the drain for the filter housing.
  10. Apr 19, 2009 at 1:24 PM
    4x4x4trd
    North Texas
  11. Apr 19, 2009 at 1:29 PM
    TheSchwartz
    Aaron
    Smithsburg, MD
    I'd never seen the Fram, but the Fumoto valve has been around quite a while with a good track record. I like the Fomoto operation better, than the twist Fram, as in locking in the closed position and construction. IMO.[/quote]
    I had the fram in my '94 Toyo Pcup never had a prob with it leaking. But then i never heard of the Fumoto till today either...
  12. Apr 19, 2009 at 1:30 PM
    TicTacOma
    Columbia,SC
    Are we talking about a mess from the oil drain pan stand point or the mess from the "upside" down filter?
  13. Apr 19, 2009 at 1:36 PM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    upside down filter, I believe
  14. Apr 19, 2009 at 1:39 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    the upside down filter
