35's anyone running them
Discussion in 'Wheels & Tires' started by wurthit4660, Sep 21, 2011.
  1. Sep 21, 2011 at 2:39 PM
    wurthit4660
    wurthit4660 [OP] Well-Known Member
    Hollywood
    St.Louis, MO
    02 Taco Prerunner ExtCab SR5 TRD
    K&N Cold Air Intake Flow Master Muffler 3" Suspension lift
    have a guy local that has a great deal on some nice super swamper 35/12.5-16.5 tires... wondering if i would have to re gear or do any kind of mods to run these on my 02' taco prerunner 3" lift, 3.4L w/K&N cold air intake.. currently running 285/70/16.... yes I know i will have to get different rims because the tires are 16.5....
    and if they would rub or not? do not want to do any cutting mods to wheel wells.........IM not off roading so keep that in mind...
  2. Sep 21, 2011 at 2:42 PM
    rcfreak201
    rcfreak201 Well-Known Member
    they wont fit with stock fenders and a 3" lift, you would need to trim/cut alot of your fender and inner fender lining or run glass fenders, even then you would need a cab mount chop(atleast on 2nd gens, not sure what they do on the first gens) and yes you would need a regear for sure
  3. Sep 21, 2011 at 5:25 PM
    wurthit4660
    Hollywood
    St.Louis, MO
    Thanks enough said, squash that:sadviolin:
  4. Sep 21, 2011 at 5:31 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    This is what you would have to do :D And then replate it. Im doing this soon....
  5. Sep 21, 2011 at 5:35 PM
    rcfreak201
    ^thats crazy
    i just had to do this
    to fit these
  6. Sep 21, 2011 at 5:45 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    ^Those are 35" tires?
    EDIT< I can fit 35" tires without trimming, but that is only because I have LT up front.
  7. Sep 21, 2011 at 5:45 PM
    rcfreak201
  8. Sep 21, 2011 at 6:03 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    you guys are lucky, we have to do alot more work to fit big tires.
    Are you sure? This guy has LT and he still had to do what i posted above.
    http://www.trailslesstraveled.com/article/clearance-for-35inch-tires-on-a-tacoma-at-any-lift-height/
  9. Sep 21, 2011 at 6:09 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Not completely accurate because of the difference in wheelbase of the trucks...a 2gen on 35s is like a 1st gen on 33s in terms of angles...a 1st gen on 35s would be like a 2gen on 37s.
  10. Sep 21, 2011 at 6:12 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    Could you explain a little more? I thought the 2nd gens just had bigger wheel wells, therefore making it easier to fit bigger tires. Always open to learn new things.
  11. Sep 21, 2011 at 6:15 PM
    jandrews
    Tire size isn't everything. Wheelbase length plays into it. A smaller tire on a shorter wheelbase gives the same effect as a larger tire on a longer wheelbase. Body overhang also plays a role.
    Do some googling on approach, breakover, and departure angles.
    This is why Suzuki Samurais can get away with ridiculous shit running 31 inch tires that makes guys in pickups on 38s cry.
  12. Sep 21, 2011 at 6:16 PM
    Manwithoutaplan
    ID
    rcfreak are you on 8 or 9 inch rims ???
  13. Sep 21, 2011 at 6:17 PM
    rcfreak201
    16x8s broskie
  14. Sep 21, 2011 at 6:25 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    I realize that, I just meant to fit 35s we have to do a lot more work. Sorry, I should have been more clear.
  15. Sep 21, 2011 at 6:28 PM
    jandrews
    Right, but probably not more work than a 2genner fitting 37s, is my point.
    In other words, if you want a certain level of capability out of your vehicle, there's just a price.
  16. Sep 21, 2011 at 6:35 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    looks like a lot of work!
  17. Sep 21, 2011 at 6:40 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    So do it!
  18. Sep 21, 2011 at 6:45 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    I understand, that makes sense.
  19. Sep 21, 2011 at 10:04 PM
    wurthit4660
    Hollywood
    St.Louis, MO
    Wow the thread blew up lol... no way im cutting/chopping my wells... so out with the 35's and in with 33's which i know will/should fit so here are my choices. Which of the following would be the least amount of wear and tear on the ball joints and other parts, keeping in mind I want the wide look here..
    #1 33/13.30 15 on 15x10 wheels or (15x12 hear these are harder on the joints?)
    #2 33/12.50 17 on 17.9 wheels
  20. Sep 22, 2011 at 4:04 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    I say option 2, why do you want a wide look?
