$380 Control Arms
Discussion in 'Suspension' started by chadderkdawg, Nov 16, 2011.
  1. Nov 16, 2011 at 6:55 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Ya they'll work it out. I think I'm gonna get a set in the spring to go with a DB lift. Now yell at me about the DB and get your post count to 30k. :D
  2. Nov 16, 2011 at 7:53 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    So what I've gathered here and after a search is that there is what I would call a total of 4 Revisions. It's possible that they did 2 and 3 simultaneously but appeared like the BJ issue started it all...
    Rev 1
    This one had early failing BJ's and a problem with the rubber compound at the bushings which resulted in tearing.
    Rev 2
    Fixed the BJ's.
    These things have been around forever giving excellent service life even in non-greaseable form, so it should have never happened. Too bad that one of SPC's vendors failed on this.
    Rev 3
    Improved the rubber compound at the bushings and enhanced the geometry of the rubber. These vulcanized assemblies also have been around for a long time (ie. motor mounts) and this too should not have happened.
    Looks like SPC should have put more time in on testing before releasing this product.....they know that now.
    I do like the overall design because the part addresses shortcomings in the other options, both aftermarket and OEM.
    In Rev 4 which is supposed to be out in early 2012, I would like to see some grease fittings at the BJ and at the bushings.
    I think that part of the fail at the bushings could have been due to the bolts getting dry and binding. This would have transfered more movement to the rubber cushion causing the tearing.
    Going all this way and no greaseable BJ ? What's up with that ?
    At least I can't see a zerk in those latest pics.
    Some would probably like to see greaseable poly bushings but 99% of vehicles use the quieter, vibration-absorbing, rubber system with good results.
    SPC has a good design, they just need to clean it up a bit and it will be the price-performance sweet spot in aftermarket UCA's.
  3. Nov 17, 2011 at 5:52 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    :confused:I do not have aftermarket UCA's.
    Must be thinking of someone else.
  4. Nov 17, 2011 at 6:21 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    You are right it is another guy with a white taco wish I could remember his name
  5. Nov 17, 2011 at 9:05 AM
    jflan
    Vancouver, WA
  6. Nov 17, 2011 at 10:04 AM
    raswank
    Rick
    Auburn,Ma
    Yes thank you that is him
  7. Dec 7, 2011 at 6:48 PM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    So did you order the ones off Amazon. I am thinking of getting them for 363.11 shipped!
  8. Dec 7, 2011 at 6:54 PM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Im waiting till the next update after the first of the year.
  9. Dec 7, 2011 at 7:05 PM
    jflan
    Vancouver, WA
    So is this a big secret or are you going to put a link up ?
    :D
  10. Dec 7, 2011 at 7:27 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Check page one bro
  11. Dec 7, 2011 at 7:38 PM
    jflan
    Vancouver, WA
    Yeah thanks, I actually went ahead and bought those a few days ago.
    They came directly from SPC.
    I was wanting esp to post a link for his deal.
  12. Dec 7, 2011 at 7:51 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    His deal is at the link in the first post. Looks like Amazon's price changed... :wink:
  13. Dec 7, 2011 at 8:00 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Bingo, ordering that shiz tomorrow
  14. Dec 7, 2011 at 10:48 PM
    jflan
    Vancouver, WA
    That's what I paid.
    esp said shipped but it's plus shipping which gets you to around $380.
    Still a very good deal.
  15. Dec 14, 2011 at 8:24 AM
    #35
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Update, I emailed SPC about ordering their UCA's from Amazon and asked about the redesign. Here is their response, take it as you may, I personally am going to order them.
    Chad,
    The original issues were with the rubber bushings. These bushings have not been produced in about 2 years. Ordering from amazon will get you the latest design, as most of our distributors there do not keep those parts in stock, but instead will use us to drop ship this item directly to you.
    Brad Gardner
    Customer Service Dept.
    Specialty Products Company
    1-800-525-6505
    303-772-1918 fax
    custserv@specprod.com
  16. Dec 14, 2011 at 9:55 AM
    #36
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    ^^ This
    When I ordered my LR UCAs earlier this summer from Fat Bob's, they were actually shipped directly from SPC.
  17. Dec 21, 2011 at 1:15 PM
    #37
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    thanks just ordered. $380.86 OTD.
  18. Jan 1, 2012 at 11:14 AM
    #38
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    i ordered these not too long ago. 380 shipped from Amazon. great price and spc has good cs
