3G Service: Filters and Treatments - Need Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GTGallop, Nov 9, 2024.
  1. Nov 9, 2024 at 9:57 AM
    GTGallop
    GTGallop [OP] Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Took the truck into Camelback Toyota for what I thought was the 15k mile oil change but it was done at 10k so not due until 20k. All they did was rotate the tires and try to sell me a TON uf upgades or service items that were necessary but at $tealership Prices.
    So.... Since I like the DIY route:
    1. What are you using for a Fuel Treatment?
    2. What are you adding to the Oil as an Oil Treatment?
    3. What Air Filter are you using (Stock box)?
    4. What In-Cabin Air Filter are you using?
    Anything else I should be looking at?
    And yes - I searched.
  2. Nov 9, 2024 at 10:21 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    1. none
    2. none
    3. OE
    4. OE
  3. Nov 9, 2024 at 10:25 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    Leaning towards none on the Fuel / Oil too.
    If anything I'll just go get an oil change and let fresh, new, clean, oil be my oil additive.
    musicisevil and Chew[QUOTED] like this.
  4. Nov 9, 2024 at 10:26 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
  5. Nov 9, 2024 at 10:30 AM
    AZ_TJ
    AZ_TJ Well-Known Member
    T.J.
    2018 SR OR 4x4 MGM
    Stuff.. but not much
    I didn't use anything for the fuel or oil but I use K&N for the air & cabin filters. No horsepower gain or anything from using them, I just prefer them. Nothing wrong with OE filters.
    GTGallop[OP] likes this.
  6. Nov 9, 2024 at 10:34 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I just do not want to pay K&N for air filters. Wix from O'Reilly ... which is expensive enough as is.
  7. Nov 9, 2024 at 10:51 AM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Nov 9, 2024 at 11:12 AM
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    I don’t use any fuel or oil treatments on my Tacoma, and I just use the OE filters.
    in my SAABs, I’ve tended to run Liqui-Moly ceramic oil additive. But then, a stout Japanese truck is a different beast than a temperamental European sport sedan.
  9. Nov 9, 2024 at 1:27 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    no treatments at all needed on a vehicle less that 10 years old
  10. Nov 9, 2024 at 1:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It doesn't need anything at that mileage.
    Change the oil, check the paper filters, put gas in it and drive
    RIX TUX and GTGallop[OP] like this.
  11. Nov 11, 2024 at 4:19 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    And so this story takes an unusual twist - well maybe not unusual, but a twist I didn't expect.
    I asked about Fuel Treatment, Oil Treatment, Air Filter, In-Cabin Air Filter because along with the 4 wheel alignment (which I also turned down) these were the things the dealer said were a "MUST DO." And they got a little freaky when I politely declined. I went ahead and bought a Wix Engine Filter (it has an odd little pre-filter pad on it) and a Bosch HEPA Filter for the cabin.
    When I pulled the Engine Air Filter it was Toyota OEM and looked nearly new. I tapped it on the pavement and a little dust fell out but it looked fine. So I dropped the new filter in and blew the old filter out with the air compressor. Going to save it back as a spare.
    The in cabin air filter had very little debris on it but looked green and black so I swapped it but didn't keep it as a back up.
    Chew likes this.
  12. Nov 11, 2024 at 8:18 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    This is their pre-wallet flush, wallet flush. You did well keeping them out of yours. Ski
  13. Nov 11, 2024 at 9:03 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I've been going with OE just because I'll jump on a sale and get them for the same price of aftermarket filters. With that said I've also used Purolator, Mobil 1, Bosch etc air/cabin air/oil filters without concern.
    GTGallop[OP] and Chew[QUOTED] like this.
  14. Nov 11, 2024 at 9:22 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Recommending an engine air filter at only 15K is (in most cases) attempted robbery. I had mine out yesterday and at 22K it still looks like new. When I was a dealer tech the air filter was always part of the 30K service and even then they looked pretty clean. Buy a quality synthetic engine oil and a good filter and don't bother with any supplements. Personally, if they tried to sell me all that stuff at 15K it'd be the last time they saw me.
    Chew likes this.
  15. Nov 11, 2024 at 10:29 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What's the twist?
  16. Nov 11, 2024 at 11:14 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    1. I just use a name brand fuel system cleaner every oil in the next fill up. Techron is a good one but not brand loyal. BG products are good, Lucas is ok too.
    2. No additive. Just use a good oil and change it regularly, I'm using Supertech 0w20.
    3. Regular paper air filter, Wix, Fram, purolator all ok. I use OE oil filter
    4. Supertech or whatever cabin filter I can find on Amazon, there is a charcoal one on Amazon for like $12 that works fine
  17. Nov 11, 2024 at 1:12 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    First mistake: taking it to the dealer.... especially Camelback.
    Warren Buffet doesn't need any of my money. He owns all those Camelback dealerships.
    I bought from Camelback but use Yota Pros to do all my work.
    7144 S Priest Dr, Tempe, AZ 85283
    Good people - good work done right - reasonable prices.
    I take mine there every 5,000 miles for oil change/ tire rotation.
    Canadian Caber likes this.
  18. Nov 11, 2024 at 2:03 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    /thread
    b_r_o likes this.
  19. Nov 11, 2024 at 2:16 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    i would highly advise against using oiled engine air filters. Absolutely zero performance gains. They do add a bit of a noise but thats all.
    I used to love my TRD oiled air filter but until i discovered a fine layer of dust in my intake tube, that POS went straight into garbage.
  20. Nov 11, 2024 at 4:05 PM
    Vinman02
    Vinman02 Well-Known Member
    Vince
    2019 Tacoma TRD
    Levelling kit
    I agree, use a non-oiled filter for better filtration.
