3in rear block and aal question???
Discussion in 'Suspension' started by milam89, Dec 2, 2010.
  1. Dec 2, 2010 at 11:32 PM
    milam89
    milam89 [OP] Well-Known Member
    houston,tx
    2006 blacked tacoma
    i wanted to know if i put a 3in block in the rear along with aal, do i have to extend the brake lines or should they already be long enough, and do i have to put one of those angle shims under the block to fix the angle of the diff with the driveshaft??:confused:
  2. Dec 3, 2010 at 5:58 AM
    BBB1
    BBB1 Member
    Louisiana
    06 DCSB TSS
    6" Pro comp lift. Painted handles and mirrors. Spider Trac Spacers
    I have a procomp 6 inch. I put a 3 inch block with a 3 degree shim and took out the block that came with the lift. I wanted to have a little rake in it so when I pull my boat, it is level. It put the rear of my truck, 1 inch higher than the front. If you want it level, you could get a 2.5 inch block.
    I wish I knew how to post pictures. I could show you what it looks, like.
    BBB
  3. Dec 3, 2010 at 6:01 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I believe that you would need to extended your brakelines.
    Hopyfully you have longer shocks in the back too? What size is the AAL? 1.5", 2"?
  4. Dec 3, 2010 at 6:38 AM
    milam89
    houston,tx
    2006 blacked tacoma
    yea i have longer shocks, i have the procomp aal i thinks its 1.5" do you know?
  5. Dec 3, 2010 at 9:45 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i have a 3 inch block and a aal. i believe mine is a 1 or 1.5 inch aal.
  6. Dec 3, 2010 at 10:15 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i have a 2 in block with the procomp aal it said it was a 1.5-2.5in lift based on spring condition. and due to the lift the parking break line hanger on the leaf springs broke off whenever the suspension was a full flex i am guessing considering its not attached anymore, and yeah its kinda tight. break lines look okay to me
  7. Dec 3, 2010 at 10:14 PM
    milam89
    houston,tx
    2006 blacked tacoma
    so you have a 3in block with a procomo add a leaf and a 3degree shim, do you know if you had to extend the rear brake lines
  8. Dec 4, 2010 at 3:42 PM
    BBB1
    BBB1 Member
    Louisiana
    06 DCSB TSS
    You are correct. That is the setup i have. I didn't have to extend my lines. I don't wheel my truck so I don't know what the flex would do.
    BBB1
  9. Dec 4, 2010 at 4:03 PM
    milam89
    houston,tx
    2006 blacked tacoma
    kookoo thinks for the info!:D
