3inch Lift Question - Diff Drop?
Discussion in 'Suspension' started by Buell, Sep 13, 2011.
  1. Sep 14, 2011 at 11:43 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ you should ask a mod to delete your duplicate posts.
  2. Sep 14, 2011 at 11:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    I did, he said: NO. Live with the failure............:pout:
  3. Sep 14, 2011 at 11:45 AM
    mjp2
    NJ
  4. Sep 14, 2011 at 1:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Search feature :D
    Good info guys, I wasn't trying to start a crap storm, just wanted to better understand why the diff drop should or should not be used for a 2nd Gen.
  5. Sep 14, 2011 at 1:53 PM
    Buell
    Buell [OP] Instagram: @thebuell
    Michael
    Brooklyn, NY
    1970 Chevy Nova
    Another question....what is topping out, Down South said if I get this lift I might have issues with Topping out when I off road or hit a pot hole or speed bump
  6. Sep 14, 2011 at 1:55 PM
    Pugga
    Massachusetts
    It means your shock extends as far as it will go. The rear shocks might not be tall enough for the 3" rear from Allpro. Listen to Downsouth, they know their stuff. Did they recommend an alternative product?
  7. Sep 14, 2011 at 2:00 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    so i know this is for a second gen, but for a 1st gen, does the diff drop do any good?
  8. Sep 14, 2011 at 2:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    I did search............I went to post it and BOOM there you were to save the day. FML
  9. Sep 14, 2011 at 2:03 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  10. Sep 14, 2011 at 2:03 PM
    TexasTacoma37
    Want me to neg rep him?
  11. Sep 14, 2011 at 2:04 PM
    mjp2
    NJ
  12. Sep 14, 2011 at 2:05 PM
    Pugga
    Massachusetts
    :quickdraw:
  13. Sep 14, 2011 at 2:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sweet jebus NO!!!! He's packin!!!!
    :eek:
  14. Sep 14, 2011 at 3:15 PM
    TexasTacoma37
    :eek:
    Hi Mike :wave: *whistling slowly*
  15. Sep 14, 2011 at 3:36 PM
    #35
    Pugga
    Massachusetts
    I'm cool :eek:
  16. Oct 11, 2011 at 7:17 AM
    #36
    Woody06
    Woody06 Well-Known Member
    Maryland
    06 DCLB Sport
    6"lift procomp with 2 in lift struts custom alcan 8" leafs in the rear bilstein shocks
    Yup the reason being i still wanted play with the front struts and didn't want to have a stiff ride..... this way the lift struts just act like normal struts with the three inch spacer on top of the 5100 series lift strut. The lift strut is in the stock position.
  17. Oct 11, 2011 at 7:26 AM
    #37
    Pugga
    Massachusetts
    But your struts will bottom out before you hit the bump stops because you just spaced them down. If you don't off road you'll be fine but seems like a waste of money buying 2 lift kits for the front...
  18. Oct 11, 2011 at 8:29 AM
    #38
    mjp2
    NJ
    Read below, because he nailed it.
    Here's a visual of what happens when you move the shock down without modifying the bumpstop to restrict uptravel. With top plate spacers this happens on potholes in the road, not just when wheeling:
  19. Oct 11, 2011 at 8:53 AM
    #39
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
  20. Oct 30, 2011 at 7:28 PM
    #40
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I was searching something and my 6 year old daughter saw this and said "Why did he let that happen? He must not care about it if he let that happen." I just laughed...be glad your pain is humorous to others.:D
