3rd Gen 2016 Tacoma Thud When Coming to Stop - Axle Wrap or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 49Tacoma, Mar 7, 2016.
  1. Mar 29, 2016 at 3:09 PM
    broders
    broders Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    Has anyone got this rear end thud issue resolved? Mine has been doing this very often lately, quite annoying.
  2. Mar 29, 2016 at 5:19 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    This is still a problem? You sure it's not your u-joints?
  3. Mar 29, 2016 at 5:50 PM
    Rhubarb
    Rhubarb Well-Known Member
    Big D (TX)
    2016 OR, Manual Trans
    I noticed it on my truck (manual transmission) recently. I came to a soft stop and it sounded as if I had a load of something in the bed that shifted and hit with a thud. I have already lubed my u-joints and checked the u joints. I need to research 'axel wrap' because I've never heard that term before (truck only has 1,500 miles on it). Other than that, everything seems to be working fine.
  4. Mar 29, 2016 at 6:15 PM
    easbaysav
    easbaysav Well-Known Member
    Eddie
    Central Valley, CA
    2019 TRD Off Road AC Cement
    Sub'd.
    I've noticed this pretty much since I bought the truck. Best way I've found to avoid this is to ease to a stop; happens mainly when I stop to quickly.I initially thought it was the trans slipping on downshift (if even possible). U-bolts torqued, U-joints lubed, and trans was topped off by the dealership.
  5. Mar 29, 2016 at 7:08 PM
    Syncros
    Syncros Well-Known Member
    This showed up in my 2006 out of warranty. Had to pull the driveshaft apart and grease it every 5000km. I tried many different greases but none were a proper solution.
  6. Mar 29, 2016 at 8:21 PM
    49Tacoma
    49Tacoma [OP] Well-Known Member
    2016 Tacoma Limited 4x4
    Glad others are replying to this thread regarding the thud coming to a stop. I thought I was the only one.
    I'm almost positive it has to do with our leaf springs aka axle wrap. The previous TSB for this was the 4 leaf pack that affected 2nd gen owners got.
    Our 3rd gens only have 3 leafs unfortunately. Imho I think it'll be awhile before they release a TSB on this unless more owners come forward. If you guys are having this issue, make sure to take it to the dealer and get a case opened with Toyota Customer Care prior to the visit
  7. Mar 29, 2016 at 9:01 PM
    asiantaco 253
    asiantaco 253 Well-Known Member
    PNW
    2016 Toyota Tacoma Inferno DCLB TRD Offroad
    I get that thump after the truck comes to a complete stop for 2 second.no matter if it's going forward or backwards.
  8. Mar 30, 2016 at 3:02 AM
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I'm taking mine back in for this pretty soon. I'm pushing for a new driveshaft. It's been pulled apart and lubed twice now. It's better, but still thumps particularly after it's been sitting. Does it in D and R.
  9. Mar 30, 2016 at 4:40 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I have experienced this a bunch of times on my '16. It really threw me for a loop, just like something was sliding around in the bed and then hitting the tailgate or front of the bed. I notice it most often after I back into my driveway.
  10. Mar 30, 2016 at 4:43 AM
    Pixelrazzi
    Pixelrazzi Member
    Dennis
    2016 Tacoma TRD Sport 4x4
    Extang Trifecta, after market remote start, P3 Tekonsha
    Same noise on my truck. Dealership ordered new clamps for the boot and some drives shaft parts. When parts come in (hard to get cause new model) they are going to drop the driveshaft and check to see if it's scarred, if so replace the slip yoke. If not scarred just take apart and lube real good. Toyota should have put a lub zert there to make it easy to service. They called it "slip yoke bump". They have had it on some 4Runners, Land Cruisers and other truck base Toyota's.
    Being a Toyota salesperson for over 30 years I have driven a Gen 2 Tacoma for the past 8 years and am very familiar with them. If it were not for low tranny fluid and this thud I would be perfectly satisfied. I'm getting the gas mileage or better that's on the sticker and love the extra power.
    All in all I could have gotten a new late 15 but I do like the 16 better even with these annoyances.
  11. Mar 30, 2016 at 5:52 AM
    Rhubarb
    Big D (TX)
    So what's the order of business: Bring it to the dealership first and then, while there, ask that a case be opened?
    Also, for those with manual transmission, are any of you having a slight 'clunk' when shifting from first to second and possibly from second to third? Not sure if that's normal or indicative of something that needs to be looked at.
  12. Mar 30, 2016 at 6:04 AM
    RitchieE24
    RitchieE24 Well-Known Member
    Zack
    Ontario
    2016 Inferno Tacoma TRD Sport Upgrade 6MT
    This is likely not the issue you are experiencing. But, perhaps it is just a wild thought! I had an old truck that would make a "thud" noise when coming to a stop. It turned out to be the rear drum brake shoe catching a bit.
  13. Mar 30, 2016 at 6:08 AM
    RitchieE24
    Zack
    Ontario
    My thought is likely not the issue ^^^
    I'm not sure if I was clear enough. haha!
  14. Mar 30, 2016 at 6:13 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    whatever it is, it's normal
    trucky (taco) does it and Mr Sqweeks (4runner) does it
    it ain't wrap, as my 4runner has done this for the past 17 years and you can't wrap that axle there are no leafs
    and it has rear control arms, therefore axle cannot twist
    it's characteristic of toyota.
    RitchieE24 likes this.
  15. Mar 30, 2016 at 6:22 AM
    #35
    Pixelrazzi
    Pixelrazzi Member
    Dennis
    I am told it's from the slip yoke grabbing instead of sliding when the driveshaft needs to compress and expand. If it's bad enough our dealership resolves it. Mine is. Thats the reason they will have a spare driveshaft on hand in case it's scarred.
    I do not claim to be a mechanic. Don't need too...we have great mechanics at my dealership.
    49Tacoma[OP] likes this.
  16. Mar 30, 2016 at 8:43 AM
    #36
    49Tacoma
    I'm assuming since you work there - your dealer is more apt to assist you. For the rest of us, I'm wondering how to replicate the issue during a test drive and if it doesn't then we're SOL. Mine doesnt occur all the time but when it does, you definitely know it (pretty big rear ending-type feeling). Thanks for any feedback bud
  17. Mar 30, 2016 at 8:51 AM
    #37
    T4RFTMFW
    T4RFTMFW Well-Known Member
    That's a dealer warranty and not a Toyota warranty, so that makes some sense, outside of a shitty dealership trying to find a way to screw you over.
  18. Mar 30, 2016 at 2:56 PM
    #38
    Pixelrazzi
    Pixelrazzi Member
    Dennis
    Actually since I work there I think I get put last in line. I found if I medium accelerated up to a least 40mph and then slowed to a stop, on a smooth road so as be able to hear and feel the thud. I could get it to do it a least a third of the time. Its key that you can show the problem to a mechanic. If they can't sense it how can they diagnose it.
    Make them document your compaint, all dealerships are phobic of a lemon law claim. We have never had one at our dealership.
  19. Mar 30, 2016 at 3:10 PM
    #39
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    This happens on my truck once every handful of drives. Seems like usually when it's cold and if I'm doing like 30 or 35 mph on a smooth straight flat road, take foot off accelerator as approaching stop sign, slow braking and then THUMP like a very hard downshift clunk. It is strong enough to feel like its pushing my truck forward.
  20. Mar 30, 2016 at 5:22 PM
    #40
    broders
    NC
    I have an appointment on Monday about this. I'm betting they will either say they cant recreate issue or its normal. Any takers?! Haha
    smitty99 likes this.
