3rd Gen 2016 Tacoma Thud When Coming to Stop - Axle Wrap or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 49Tacoma, Mar 7, 2016.
  1. Mar 30, 2016 at 7:04 PM
    #41
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    Mine does it almost every time when cold.... about 30-40 then stop at a stop sign.... CLUNK!
    smitty99 likes this.
  2. Apr 5, 2016 at 1:09 PM
    #42
    JWhitmer
    JWhitmer Active Member
    State College, PA
    2016 Tacoma DCSB TRD OR 4X4 BBP
    Any update on what the dealer said? A lot of us would really like this fixed it think!!
  3. Apr 5, 2016 at 1:28 PM
    #43
    broders
    broders Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    Of course, the thud stopped over the weekend (It comes and goes as it pleases) so I cancelled my appointment, I really didn't want to sit at dealership for hours for them to tell me they couldn't recreate the issue. Next time it starts doing it, I'm just going straight into dealer without appointment.
  4. Apr 5, 2016 at 1:36 PM
    #44
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Mine is enigmatic too. Usually I notice in the AM when cold.
  5. Apr 5, 2016 at 1:44 PM
    #45
    JWhitmer
    State College, PA
    Same here. I think I noticed this weekend that in rainy conditions it is not present...But that could have just been coincidence. I am really trying to wait until my 5K service but the clunk along with the vibrations make me feel like this thing is a junker. ugh
  6. Apr 5, 2016 at 3:45 PM
    #46
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Mine can be replicated after I have driven about 5 miles and come up to a stop light or sign and brake rather quickly to a stop with one application of the brake peddle. Just like when someone cuts you off short and you have to stop a little quicker than you normally do.
  7. Apr 5, 2016 at 4:17 PM
    #47
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Another one to put on the list it seems. I've noticed this for a while now, and was always hoping it was gas sloshing in the tank or something easy. Usually I notice it before the car has warmed up, most commonly when I'm backing down out of my slanted driveway and brake as I get into the street.
  8. Apr 5, 2016 at 7:46 PM
    #48
    IowaToyotas
    IowaToyotas Well-Known Member
    Matthew
    San Diego
    13 TRD Super Charged
    Super Charger, 2 In lift, TRD pro 17in Rims, 285 Toyo all country tires
    My truck does this alllllll the time, its so funny people say, write it off, "its a truck" "they all do it." I found the TSB on it, its TSB-0016-13 REV1, stats they need to remove the propeller shaft coming out of the transfer case to the front diff then drive the truck and if it remedies the issue then they replace the propeller shaft in between the transfer case and the front diff. If you truck is making the thump then is because the propeller shaft is the wrong size, the TSB only covers up to 2013. I'm taking my truck in this Friday for the 60,000 mile because its still under warranty, I know it sounds dumb but I wish it wasn't I want to do most of this myself.
  9. Apr 5, 2016 at 7:47 PM
    #49
    IowaToyotas
    Matthew
    San Diego
    My bad theresTSB-0016-13, TSB-0016-13 REV1 and TSB-0016-13 REV2.
  10. Apr 5, 2016 at 8:18 PM
    #50
    Skinny Dugan
    Skinny Dugan Member
    Dave
    Taco
    This is a long time Toyota pu quirk. Mi had the same thud on my 02 Tundra. You guys are describing it to a tee.
    A very good friend was the service mgr at my local dealership and he tried unsuccessfully to fix it with zero luck. He said that Toyota was well aware of it but didn't have a clue as to how to fix it.
    It seemed like it was better when I would load my zerks up with grease.
    They have known about it for years and they aren't going to start fixing it now.
  11. Apr 5, 2016 at 8:19 PM
    #51
    IowaToyotas
    Matthew
    San Diego
    but from what I can tell it doesn't hurt anything just annoying?
  12. Apr 14, 2016 at 3:15 AM
    #52
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Finally had my driveshaft replaced by the dealership. Clunk is still there. Actually it's worse now with the new driveshaft. The old one had been lubed with the Ford/Motorcraft grease. Field rep is supposed to look at it again on Friday. Supposedly Toyota is working on trying to find a fix, but they're not sure if it's coming from the DS or Trans. In my mind it's the DS since when it was lubed it got better, and with the new one it's worse. That's the only variable changed. We'll see what happens, but I'm not exactly hopeful they'll fix it since this has been a long standing issue. My advisor said I'm far from the only one complaining, and that it seems to be more common with the 16's.
  13. Apr 14, 2016 at 4:41 AM
    #53
    eseckinger
    Eric
    2018 TRD Sport
    It's transmission and temperature related. Pretty sure we all feel it. IMO it's mapping related and will be fixed with a re flash probably.
  14. Apr 14, 2016 at 8:24 AM
    #54
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    nope. imho, nope.
    that thud will be there forever. it's in the physical design of the tranny valves
    and how 1st is selected and at what pressures and timings that it can occur
    it is a combination of the
    transmission brake down to 1st
    when you stop
    (this is a valve with o-ring that slides to put you in 1st,
    aisin 340 and 750 thump is just how it works sometimes)
    and sometimes, add some axle/spring wrap unloading
    add sometimes some idle control gibberish
    with some a/c clutch action thrown in, in some moments
    when you come down to a fast stop the tranny does not brake to 1st
    right away, it lets the guts wind down then boop, 1st gear gets pushed in
    yes depending on age of fluid, foaming of fluid, temp of fluid..speed of rundown...etc it may not thump at all
    1st gear in auto trannies is special, it is the only gear you can physically pick by shifting to 1st,
    (other gears require working valve body and solenoids, 1st is mechanical when done with lever afaik)
    so when the valve body and computer chooses 1st for you when brake-down, I think the valving
    is routed some funny way different than all other gear selections. and there is a sort of 'hydraulic hammer'
    that can happen in the valve body
    Ganjafornia, Taco Driver and Dean724 like this.
  15. Apr 14, 2016 at 8:28 AM
    #55
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    This is pretty much what the service tech explained to me when I brought my truck in to have the tranny fluid checked because I had the same small thud when I came to a stop. It's very subtle and only happens on occasion. He told me 4Runners had this the worst a few years back, but it's always been a Toyota P/U - 4Runner issue.
  16. Apr 14, 2016 at 10:01 AM
    #56
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Did the new driveshaft get Ford grease in the slipjoint?
  17. Apr 14, 2016 at 11:34 AM
    #57
    broders
    NC
    I don't understand.....but it sounds like you know what you're talking about. So basically, we should just learn to deal with the occasional thud?
  18. Apr 14, 2016 at 11:38 AM
    #58
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    well
    all my toyota trucks and 4runners have it since 1998 to 2013
    many others here on the forum are familiar with it
    it's just what they do...now...does this answer here cover every possible bump or chuggle? hell no but all these
    descriptions and worries I see, and filtered through my road-weary eyes, tell me this is the same
    thing they all do...not a problem, functions as designed
  19. Apr 14, 2016 at 1:27 PM
    #59
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Nope. Brand new and untouched. That's why I think it's slip yoke related since the grease definitely helped. Now the other shaft is in its back again.
  20. Apr 14, 2016 at 2:16 PM
    #60
    splitbolt
    NW Arkansas
    You'd think all slip joints are basically the same.
    You ought to see all the different patents the industry has. They are a lot more complicated than what I gave them credit for.
