3rd gen 4Runner Rear Coil spacer question
Discussion in '4Runners' started by d.moto4r, Nov 21, 2019.
  1. Nov 21, 2019 at 10:07 AM
    d.moto4r
    d.moto4r [OP] New Member
    1996 4runner SR5
    So I went ahead and grabbed a set of 1in land cruiser front coil spacers by whiteline. My question in which order should the spacer be installed. The groove in the spacer seemed to work best with spacer between spring and bumpstop. But since I installed them I feel the rear end being way more sloppy in turns. Here is a pic of the order I installed them in.
  2. Jan 10, 2020 at 8:08 PM
    zwalker16
    zwalker16 Active Member
    what coils are those
  3. Feb 29, 2020 at 7:33 PM
    Lefty JD
    Lefty JD Well-Known Member
    JD
    97 Taco, Black 3.4 auto 4x4
    Fox 2.5 Resi's Dakar leafs w/Icon 2.0 Resi's TG front bumper 4xInnovations rear bumper Savage Off Road Skids 255/85r16 DC Extreme Country's 1.25" spacers up front 4Runner Bucket seats
    I did mine the other way around way back when. (IE spacer at the very top) Didn’t have any ill handling issues that I recall? But that doesn’t mean it was “right” either!
    Can you set up a camera to catch the suspension motion? I can’t see the spacer placement causing the sloppy feeling you describe. Either the Springs are too soft or the spacer is squishy; either would add some body sway in corners.
    Or did you remove the sway bar? Check your connections-I had one of the sway bar to axle mount bolts shear off after I lifted; so the sway bar looked installed but in use it wasn’t actually helping.
  4. Mar 7, 2020 at 5:17 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    That’s how it’s made to go as dumb as it seems. The rear end shouldn't feel much different but when you get away from factory geometry shit can get unpredictable. I have a 1.5” spacer on new coils and it handles fine, better that the old worn out shocks and springs. Also if you went with 99 coils you’re at 2” of lift now so your Panhard bar may be starting to work against you also.
