3rd gen 5100 on 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Feb 9, 2021.
  1. Feb 9, 2021 at 5:13 AM
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    2015 tacoma dcsb SR5 4x4
    None so far
    Is the only difference the notch setting?
  2. Feb 9, 2021 at 5:36 AM
    BeefedTacos
    Brian
    None so far
  3. Feb 9, 2021 at 5:37 AM
    BeefedTacos
    Brian
    None so far
    Found a good local deal. I have 885 and only want a 2.5 in over stock. Every where is sold out on 2nd gen bilstein.
  4. Feb 9, 2021 at 12:10 PM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    I think the travel is a little shorter, but it will definitely work. Are you using you stock 2nd gen could
  5. Feb 9, 2021 at 12:26 PM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I did a lot of digging into this regarding the 6112's and found a bunch of info on the 5100's. Rear 5100's are all the same (length and valving) for 2nd and 3rd gen. The 3rd gen 5100's have one extra clip setting since the 3rd gen is heavier up front. If I remember correctly each setting on the 5100 from a 3rd gen front shock on a 2nd gen is apx 1/4"-3/8" (on. a v6 model) higher than the same setting if used a 2nd gen 5100 on a 5100. So, be careful if you want to put it all the way on the highest setting. You will likely end up close to 3" of lift depending on your front accessories. That would require UCA's and would ride very rough since you would be closer to the end of your down stroke. I would probably go with the 3rd or 4th clip setting at the most. Internal valving from all my research seems to be the same on both 2nd and 3rd gen. NOTE: if you have 3rd gen coil springs, they will lift it further since they are a higher spring rate.
  6. Feb 9, 2021 at 12:58 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport
    BeefedTacos [OP] likes this.
