3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Dec 5, 2017 at 4:01 AM
    #361
    caterpilllartacoma
    caterpilllartacoma Well-Known Member
    Denver, North Carolina
    2017 Tacoma SR
    working on it
    Unless I missed it, I haven't seen anyone in this thread that has a SR. I have a 17 SR access cab, should the 5100s with 887 OME springs and an AAL work on the SRs? I just want to make sure before I go dump money on a lift, get it and not have it fit on my truck.
  2. Dec 5, 2017 at 4:18 AM
    #362
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Yes they fit. Sr is same truck essentially just different suspension. So you will be the same as my off road essentially after you do it since im running similar aftermarket suspension
    Dont forget 1/4” driver side taco lean trim packer to go on the one side and 887 are the taller so your on the threshold of UCA’s that you could always add later if you dont like alignment
    Durango95 and wirenut[OP] like this.
  3. Dec 5, 2017 at 8:55 AM
    #363
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    Okay, I kinda thought it would work, just needed to double check, thank you for the info!
  4. Dec 11, 2017 at 6:51 PM
    #364
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    One more question if you don't mind...when combining the ome coils and 5100s, what additional hardware do I need for this all to work? Or will I be able to use the old hardware from the oem front struts?
  5. Dec 11, 2017 at 6:55 PM
    #365
    Friedtacolover
    Travis
    Ontario, Ca
    If its a new truck they use the oem hardware. You need front shocks, rear shocks, leafs for rear, longer u bolts for new leafs, springs, driver side trim packer.
    Optional:
    Extended brake lines, ucas, diff drop, ecgs bushing
  6. Dec 11, 2017 at 6:58 PM
    #366
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    Sweet, that's about what I had on my list so far. Thanks for the info again :thumbsup:
  7. Dec 11, 2017 at 7:49 PM
    #367
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    Well, I finally made up my damn mind and ordered my lift today. Pretty standard setup: 3rd gen 5100 with ome 887s and icon progressive aal. No UCA just yet, I'm hoping my alignment will be good enough. Thanks to @Low Range Off-Road for the hookup! I'm hoping everything will be in by Friday so I can install it all this weekend.
    Artvandelay and Friedtacolover like this.
  8. Dec 11, 2017 at 9:59 PM
    #368
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    i have seen others use the same setup with factory control arms, you should be fine, my brother has his 4 runner at 2.5" in the front and his alignment was in spec, but will get control arms when he can to get better castor and camber numbers
    Big Dustin[QUOTED] likes this.
  9. Dec 29, 2017 at 10:08 AM
    #369
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    So out of curiosity, if anyone with a third gen has the 888 coils and the 5100 shocks, would they recommended a front diff drop kit from toytec with that big of a lift?...I'm already doing UCAs as well.
  10. Dec 29, 2017 at 10:55 AM
    #370
    Timey50
    Timey50 Member
    I did the same lift and I didn’t need it.
    caterpilllartacoma likes this.
  11. Dec 29, 2017 at 2:41 PM
    #371
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    What did you do for the rear lift with the 888s up front? Looking to get the most level lift front and back as possible.
  12. Dec 29, 2017 at 2:57 PM
    #372
    Timey50
    Timey50 Member
    A 2 inch block it left a rake of a 1/2 inch.
  13. Dec 29, 2017 at 2:58 PM
    #373
    caterpilllartacoma
    2017 Tacoma SR
    working on it
    That's what's I was thinking about doing on the rear, did you have to do anything else extra, like extend brake lines etc.?
  14. Dec 29, 2017 at 3:11 PM
    #374
    Timey50
    Timey50 Member
    No nothing extra. If your doing it yourself the bolts on the upper control arms are a bitch. You have to bend the inner fender to get them out. Or cut them and get new bolts. The brackets holding the brake lines to the frame in the rear just reach after the adding the blocks.
  15. Dec 29, 2017 at 5:11 PM
    #375
    Electriclarry
    Electriclarry Member
    Headstrong 5100's and there AAL.
    304_Taco, Batman!, arnette64 and 3 others like this.
  16. Dec 29, 2017 at 8:13 PM
    #376
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Looks good!
  17. Dec 31, 2017 at 1:17 PM
    #377
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    Going with your type of setup :) Do you have any photos of your ride?? Also where do I get the spacer's you have
  18. Dec 31, 2017 at 1:40 PM
    #378
    wirenut
    wirenut [OP] I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Headstrong offroad has the lean spacer and next size up. I did by tires for myself for xmas.
  19. Dec 31, 2017 at 1:52 PM
    #379
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Please don’t tell me you have a Pro and switching your suspension to 5100s....
  20. Dec 31, 2017 at 1:59 PM
    #380
    wirenut
    Andrew
    NH
    98’ T4R
    Lol at that point just block and space the pro shocks
