3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Feb 18, 2017 at 9:51 AM
    #41
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Ok ...agree to disagree then... I mentioned "better ride".... not disagreeing with how some folks use them. To each his own here but .... "optimal setp", which would you prefer?
  2. Feb 18, 2017 at 10:02 AM
    #42
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    no i definitely understand your point, but i think you saying shocks are not meant to lift the truck is an in accurate statement because yes that is typically true. But the 5100's like the ranchos and now the procomps are designed to lift the veh. its just a longer shock. my experience with changing the springs on any truck is always a much stiffer ride. if you want to maintain closest to factory ride and just looking for 2-2.5"'s of lift cant go wrong with the 5100's
  3. Feb 18, 2017 at 10:04 AM
    #43
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Ride on the concrete jungle vs OR performance are two different things that can be achieved with the same 5100/OME equipment. I'm in the 5100 set a 0 and let the coil do the lifting camp. I would be very hesitant to get off the beaten jungle with the 5100 set anywhere above the 2nd notch and expecially paired with a OME coil. But if all you want is looks then go for it.
    jsinnard and bobrown14 like this.
  4. Feb 18, 2017 at 10:07 AM
    #44
    bobrown14
    Bob
    Philadelphia
    Gen 3
    I have a Sport, new springs 885s actually improved the ride and made it a lot less bouncy and less harsh around town. On the trails it's stiffer when I need the tires in contact with the ground....
    They aren't too expensive and the same labor so it's a good investment IMHO.
  5. Feb 18, 2017 at 10:10 AM
    #45
    wirenut
    wirenut [OP] I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Geez I leave you guys alone for a couple hours and see what happens. both assemblies would probably withstand the punishment I would hand out to my taco. Lift heights are about the same as well so i suppose im gonna call the broad and see what she can talk me into.
  6. Feb 18, 2017 at 10:13 AM
    #46
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Call the broad... always a good plan... specially when spending her money right?
  7. Feb 18, 2017 at 10:36 AM
    #47
    wirenut
    Andrew
    NH
    98’ T4R
    I dont think the chick at headstrong would buy me a lift. Always worth a shot I guess.
  8. Feb 18, 2017 at 11:04 AM
    #48
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Be respectful, she's not a broad and she'll do a good job of getting you set straight without overselling you stuff you won't need.
    zepperhead89, jgr81, D-CM and 11 others like this.
  9. Feb 18, 2017 at 1:17 PM
    #49
    wirenut
    Andrew
    NH
    98’ T4R
    No disrespect whatsoever, broad is a general term in lue of forgetting the womans name. Always a gentleman, Never a doosh. On another note is wheelers offroad decent as well? I found myself shopping on that site as well.
    pescadoman66 likes this.
  10. Feb 18, 2017 at 1:22 PM
    #50
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I've used wheeler's in the past, solid business, no problems whatsoever and I'd recommend them also.
    Also recommend using the term "lady" as a general term in the future if you forget a woman's name.... :thumbsup:
    Especially if she happens to read these forums and is in a position to help you out.
    xerogs1, jgr81, Hawk45 and 9 others like this.
  11. Feb 18, 2017 at 1:26 PM
    #51
    wirenut
    Andrew
    NH
    98’ T4R
    Roger that. I appreciate all the info.
  12. Feb 18, 2017 at 4:17 PM
    #52
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Oye.. ummmm, does not compute :anonymous:
  13. Feb 18, 2017 at 8:36 PM
    #53
    as79fire
    as79fire Well-Known Member
    Adam
    2016 TRD Sport 4d White
    265 70 17
  14. Feb 18, 2017 at 8:37 PM
    #54
    as79fire
    Adam
    Do you come to the Tilton/Northfield area at all?
  15. Feb 18, 2017 at 10:09 PM
    #55
    vei1side
    vei1side Active Member
    Cerritos, Ca
    '17 DCLB TRD Sport 4x4 Inferno
    Bilstein 5100 Shocks, OME 888 Springs, SPC UCA, Deaver AAL, DeMello Offroad Hybrid Rock Sliders VTX Offroad Terra Wheels 285/70/17 BFG K02
    I have Bilstein 5100s, OME 888 Springs, SPC UCA, and Deaver AAL. About 2.5 inch lift, truck is pretty level.
    98_3RZ_NIC, chuck69, trktwo and 28 others like this.
  16. Feb 19, 2017 at 2:52 AM
    #56
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights,
    Very nice! What tire size are you running with?
    LJArk94 likes this.
  17. Feb 19, 2017 at 4:37 AM
    #57
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    That looks great. 5100's on 0 and letting the OME's handle the lift in front?
    LJArk94 and Zchristie14 like this.
  18. Feb 19, 2017 at 9:54 AM
    #58
    wirenut
    Andrew
    NH
    98’ T4R
    I do, I hit the home depot once a week for misc stuff for jobs. Tilton diner is usually the meeting spot for all of us on dirtbikes on weekends.
  19. Feb 19, 2017 at 10:02 AM
    #59
    vei1side
    Cerritos, Ca
    285 70 17
  20. Feb 19, 2017 at 10:03 AM
    #60
    vei1side
    Cerritos, Ca
    Yup 5100s on 0.
    LJArk94 and wjrichardson[QUOTED] like this.
