3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Mar 8, 2023 at 8:31 AM
    #661
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    what brand?
  2. Mar 8, 2023 at 8:34 AM
    #662
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I know, I've been checking every day. The price still went up tough.
  3. Mar 8, 2023 at 8:40 AM
    #663
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    Honestly, here's what I would do, I would go and build a setup on 1stgenoffroad, they really have it dialed in over there. Now, in the past, when I was building up a 1st Gen Tundra, (Same Suspension Design) as a 3rd Gen Tacoma. I would scroll down to the bottom of the page, and send them an email or call them, ask about the 5100's, what springs they would recommend. The brand isn't really all that important, ARB, Dobinsons, I cannot even remember which springs are in my Tacoma right now, I have two different brands, one are a 600lb spring, gives a similar to stock ride, soft but controlled. The 650lb springs are stiff, more sporty of a ride, and you feel every bump especially offroad without the extra weight of a bumper and winch on the front.
    Here's the link to their Custom Suspension Recommendation Request page, they know nearly everything there is to know about Toyota Suspensions and they are honest and will give you good advice.
    https://www.1stgenoffroad.com/customsuspensionlifttoyota.html#/
  4. Mar 8, 2023 at 8:47 AM
    #664
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Stock unless you get a plate bumper and winch.
  5. Mar 8, 2023 at 8:48 AM
    #665
    OnHartung'sRoad
    You can also keep the stock springs with them for a good ride on and off-road. Yes- mine has them also and I off-road with a lot of weight in back and on top of the cab. I only occasionally put weight up front on my Curt receiver and also have a full set of Mobtown steel skids underneath.
  6. Mar 8, 2023 at 3:21 PM
    #666
    98_3RZ_NIC
    what notch did you set them on? Not sure what notch is 1.65”.
  7. Mar 8, 2023 at 3:28 PM
    #667
    RI_OR21
    RI_OR21 Well-Known Member
    RI
    21 TRD OR/DCLB Army Green (1st Taco)
    Isn’t 600 stock coil over weight for a TRD OR? I’ve read so much now I forget what’s what but that sounded familiar. Please correct me if I’m wrong.
    EDIT: sorry I responded without seeing there was another page. Never mind
  8. Mar 8, 2023 at 5:33 PM
    #668
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    x2 here. I was expecting a harsh ride after installing 5100 last weekend and I was surprised to see that it is not what some here claims… actually I think that oem sr Hitachi shocks are stiffer than 5100. Yes, it is a former ride but it is not like driving a brick or lowered car for track…. Hell no…
    98_3RZ_NIC likes this.
  9. Mar 9, 2023 at 4:40 AM
    #669
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    620864D0-C29A-4719-AB87-AC7A195B4E53.jpg 8911CA8A-BEE6-4C45-AD36-6DF60449A8AF.jpg
    Did the the deed yesterday. 5100s all all around (standard length) and a single Deaver add-a-leaf. Taking it to the shop for an alignment this morning. The camber is definitely off on the front.
    gsubioguy, 98_3RZ_NIC and atc250r like this.
  10. Mar 9, 2023 at 5:53 AM
    #670
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    @bcgill keep your stock springs? If so, which perch did you put them on?
  11. Mar 9, 2023 at 6:02 AM
    #671
    bcgill
    Ben
    Yep! I set them at the 3rd setting.
    gsubioguy[QUOTED] likes this.
  12. Mar 9, 2023 at 7:04 AM
    #672
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Your going to have a much greater than factory rake with a 1.1" front lift and a 1.5" rear unless you plan to have some weight on the rear.
    I'm not knocking it. I like the factory rake myself..... just not in excess. ;)
    bcgill[QUOTED] likes this.
  13. Mar 9, 2023 at 7:14 AM
    #673
    bcgill
    Ben
    Yep I know and I'm OK with it. I'm having a camper shell added later in the month which should cut down on the rake a bit.
    Also in typical fashion, I forgot to measure everything before I started so I don't know exactly how much lift I got in the back.
  14. Mar 9, 2023 at 7:34 AM
    #674
    rybern
    N Alabama
    Ah, the camper shell will help. Looking forward to the pics. ;)
  15. Mar 9, 2023 at 8:07 AM
    #675
    bcgill
    Ben
    I should also say thanks to everyone here and those that responded to my DMs (conversations) for advice on how to get this done. It was extremely useful.
  16. Mar 9, 2023 at 8:56 AM
    #676
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Oem front is about 20.3", rear -21.3(center of the hub to the fender lip)
  17. Mar 9, 2023 at 10:18 AM
    #677
    bcgill
    Ben
    Thanks I'll measure it when I pick it up from the shop later today.
  18. Mar 9, 2023 at 10:48 AM
    #678
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    I have a 2017 DCLB with 5100s all around and an add-a-leaf. I run a canopy and I sit ~1.5 up in the front and .5 in the rear. I will say after two years of this set up a few long road trips and light off road use (forest roads) I wish I would have replaced the leaf pack. My factory leafs are starting to suffer and I get a little sagging when I load up now... sorry if this has been said before
    98_3RZ_NIC and bcgill like this.
  19. Mar 9, 2023 at 10:53 AM
    #679
    bcgill
    Ben
    That's good to know. This the setup I have and the same use I intend to use the truck for. I'm committed to the setup for the time being but it will be something I'll look out for.
  20. Mar 9, 2023 at 11:16 AM
    #680
    Tronfunkblow
    California
    I will say it was an improvement over stock and still is. Enjoy it!
    gsubioguy and bcgill[QUOTED] like this.
