3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Mar 9, 2023 at 2:50 PM
    #681
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    The more I read the more I think I'll do one of the "multi leaf" add a leaf set ups where you remove the stock leafs except the main leaf and add two new ones to it. Seems a good balance of economical and long term improvement.
    bcgill likes this.
  2. Mar 9, 2023 at 2:53 PM
    #682
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    I'm at about ~21.5" in the front and ~23" in the back (approximate because perfectly level ground is hard to find around here).
    Edit: This is with the Bilstein 5100s set at the third groove (1.1") and a single Deaver AAL in the rear.
    rybern, Kolohe07 and atc250r like this.
  3. Mar 9, 2023 at 3:00 PM
    #683
    bcgill
    Ben
    Driving it around a bit, I have a barely perceivable rhythmic vibration(?). I don't think it was there before the lift, but I'm not 100% of that (its really slight). It was there before and after the alignment and feels like its coming from the front.
    Something to worry about?
    tollster64 likes this.
  4. Mar 9, 2023 at 3:30 PM
    #684
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    23 is about right for your aal. I looked at mine, it is at 23.5 with the empty tank
  5. Mar 9, 2023 at 3:33 PM
    #685
    Vlady
    Issy, WA
    Probably the needle bearing. See if it is gone in 4H. Don't worry too much. You always can get a bushing.
    bcgill[QUOTED] likes this.
  6. Mar 9, 2023 at 3:39 PM
    #686
    bcgill
    Ben
    This was my suspicion based on reading stuff on here. I was hoping to avoid dealing with it since the lift wasn't that high.
  7. Mar 9, 2023 at 3:54 PM
    #687
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Yup. Needle bearing.
  8. Mar 9, 2023 at 4:17 PM
    #688
    bcgill
    Ben
    I'm going to put in 4HI on my way into work tomorrow and check... and likely stop at my shop and make an appointment since its on the way in.
    gsubioguy[QUOTED] likes this.
  9. Mar 9, 2023 at 7:24 PM
    #689
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    That looks great. Please edit the post and provide details about the lift above or below that photo. Was it 1.1" via 5100's and an single AAL in the rear?
  10. Mar 9, 2023 at 7:39 PM
    #690
    rybern
    N Alabama
    Sorry I just saw your question. My tires are 265/70r17. Check the thread in my signature for details and even part numbers about anything related to my truck. If your using a smart phone, turn it sideways to see sigs... I just learned this myself. ;) I do love my desktop though.
    bcgill and 98_3RZ_NIC[QUOTED] like this.
  11. Mar 10, 2023 at 6:30 AM
    #691
    bcgill
    Ben
    Yup. Its the needle bearing. Vibration is gone in 4H.
    Unfortunately, I stopped by my normal auto shop and they looked at me as if I was from another planet when I explained replacing the needle bearing. Now I need to find somewhere else to have it done.
  12. Mar 10, 2023 at 6:39 AM
    #692
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    I wouldn’t skimp on that. Either do it yourself and watch YouTube or take it to the dealer and pay to have it done right and warrantied.
  13. Mar 10, 2023 at 8:06 AM
    #693
    Vlady
    Issy, WA
    Don't worry to much about it. Keep driving. It is not gonna grenade on you. I have installed the bushing 1 year after the lift.
  14. Mar 10, 2023 at 8:30 AM
    #694
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Depending on your mechanical experience, it isn't too complicated. Watch some YT, watch some more YT, get the list of tools you need, go to parts store of your choice and get their loaners and plan on a ½-1 day. Heck, find your state/area's thread and ask there. Chances are someone near you has done it and would be more than happy to help in exchange for couple beers.
  15. Mar 10, 2023 at 9:57 AM
    #695
    rybern
    N Alabama
    Sorry to read this... I've read this too many times. Your not alone on this. I'm surprised that it happened with only a 1.1" lift..... honestly, it looks higher than the 3rd clip but the stock tires size makes the fender gap larger.
    I agree with others about finding someone that has done it before. There's a LOT of mechanically inclined folks out there that have done it in thier garage that I would trust verses someone that doesn't have a clue about what's going on with it and won't do the research to figure it out.... (nothing against them).
  16. Mar 10, 2023 at 10:01 AM
    #696
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    Plus those doing it themselves, might be new to it but they've got a vested interest in it being done properly.
    tollster64 and bcgill like this.
  17. Mar 10, 2023 at 10:20 AM
    #697
    bcgill
    Ben
    No worries. Yeah I knew it was a possibility going into it and I rolled the dice on not replacing the needle bearing with a bushing when I had the strut partially disassembled. Part of the calculation was that I was only doing 1.1" lift, which I thought would lower my chances of this happening.
    I'm definitely not taking it to that shop considering that the manager didn't know what the needle bearing was. I probably should have just talked to one of the floor mechanics who has a lift 2nd gen that was parked outside.
    I'd prefer to do it myself or with help, but my schedule in the next couple months is a bit insane. I'll see what I can manage.
    rybern[QUOTED] likes this.
  18. Mar 10, 2023 at 10:55 AM
    #698
    rybern
    N Alabama
    Honestly, I originally considered only doing a 1.1" lift for the same reason. I thought you'd get by without the bearing trouble. Didn't you install the lift yourself? If you did that, you can do the bushing. There's plenty of vids and threads on this. I'd start rounding up the parts to do it in the near future and not wait until the problem becomes more server. Tools can be found in the classifieds.
  19. Mar 10, 2023 at 11:13 AM
    #699
    bcgill
    Ben
    Yep I did the lift myself with a friend. He's a complete novice with Tacomas, but was super helpful and I definitely couldn't have done it without his help. We also used his garage because I don't have one. I've done suspension work and lifts on Ford Rangers, but that was over a decade ago. It was pretty straight forward though and we just went slow. I definitely don't regret the lift. The truck rides great with the 5100s.
    I've started scoping out videos of people doing it to see if I'm up for it... I may be still sore from Wednesday when we did the lift.
  20. Mar 10, 2023 at 12:14 PM
    #700
    98_3RZ_NIC
    Anyone level their truck with the stock wheels and tires? I wanna see how it looks. Eventually I’ll get 285/70/17 but I want to level it right now.
