3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Feb 19, 2017 at 12:07 PM
    #61
    as79fire
    as79fire Well-Known Member
    Adam
    2016 TRD Sport 4d White
    I have a crazy schedule. Message me when you know when you will be in the area. But I am usually working Sundays and Mondays 3pm to 11pm in Northfield, and over nights Fri and Sat nights.
  2. Feb 19, 2017 at 12:11 PM
    #62
    wirenut
    wirenut [OP] I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Sounds great, ill keep you posted!
    as79fire[QUOTED] likes this.
  3. Feb 21, 2017 at 4:10 PM
    #63
    wirenut
    Andrew
    NH
    98’ T4R
    So I'm just about to pull the trigger on this through wheelers. 5100's all the way around, 887 coils and dakars in the rear. Im sure I'll end up with wheel spacers by the end of the instal I'm just wondering if uca's and drop diff are recommended. And if so why?
  4. Feb 21, 2017 at 4:17 PM
    #64
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    You should probably ask @vei1side on that one. From all the information I've looked at on that question the response is that UCA's and diff drop are not "must-haves" with a modest lifts under 3".
  5. Feb 21, 2017 at 6:56 PM
    #65
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    The shock is the same length, the coil is "preloaded" more with each notch, giving the lift.
    camdz likes this.
  6. Feb 21, 2017 at 7:08 PM
    #66
    wjrichardson
    WI
    2017 TRD/OR/AC
    I'm assuming ride quality is generally superior with a 5100 at 0 with an OME 885 (or whichever is appropriate for your weight) compared to a 5100 on say, the second or third notch on the stock coil?
  7. Feb 21, 2017 at 7:11 PM
    #67
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    That seems to be the consensus, but I haven't really seen any complaints about 5100 ride quality even preloaded with OEM coils - vs the Hitachi units on the SR, SR5, and Sports.
    wjrichardson[QUOTED] likes this.
  8. Feb 21, 2017 at 7:15 PM
    #68
    wirenut
    Andrew
    NH
    98’ T4R
    I started to make that assumption as well. At some point I just need to say fuck it. And do it. (Pardon my French)
    Josiahcm and Munney like this.
  9. Feb 21, 2017 at 7:45 PM
    #69
    TacoMaxxxx
    TacoMaxxxx Well-Known Member
    Orange County, CA
    2016 Limited
    I have 5100's at 0 on top of my MaxTrac spindles and the ride quality is good. Logic would say that the higher you run the Bilsteins the worse the ride would become.
  10. Feb 21, 2017 at 8:10 PM
    #70
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    There's a difference between ride quality on the street and OR performance with preloaded springs.
    wjrichardson likes this.
  11. Feb 21, 2017 at 8:33 PM
    #71
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    Running Toyo OC AT2 LT265/75/16, running BORA spacers for a little poke thats all.
  12. Feb 21, 2017 at 8:35 PM
    #72
    Marcoc
    Connecticut
    No diff drop but I did the ECGS bushing, It needed it.
  13. Feb 21, 2017 at 8:35 PM
    #73
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Agreed.
  14. Feb 21, 2017 at 8:36 PM
    #74
    Marcoc
    Connecticut
    No they bolted right up. I measured studs to verify. I believe its the minimum you can run (.75")
  15. Feb 22, 2017 at 4:14 AM
    #75
    wjrichardson
    WI
    2017 TRD/OR/AC
    What made you go with a spindle lift? I haven't seen too many of those around.
  16. Feb 22, 2017 at 4:15 AM
    #76
    wjrichardson
    WI
    2017 TRD/OR/AC
    Can you elaborate on that a little?
    wirenut[OP] likes this.
  17. Feb 22, 2017 at 6:59 AM
    #77
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    The fact that I could get a 4" lift that didn't mess with the factory geometry was the big one. I knew I wanted a larger lift than a standard coilover setup could provide. I ended up getting Icon UCAs to improve the alignment and Deaver Leafs to improve the ride. Still debating on getting Icon Coilovers and Rear Resis but I'm not convinced it's going to improve my ride on road that much.
  18. Feb 22, 2017 at 7:26 AM
    #78
    iridebikes
    iridebikes Well-Known Member
    Scott
    2016 TRD Sport Manual
    Bilstein 5100 / Icon AAL / SCS SR8s
    your truck looks spot on! the little bits of red in the decal and wheels pick each other up and otherwise super clean. nicely done!
  19. Feb 22, 2017 at 8:10 AM
    #79
    Blktre
    Land of Oz....
    Coil bind mainly. Just be careful how much preload you have on the coils for your intended use/desired lift height. This is why most people like to keep their adjustable shocks set to 0 and use the spring for lift. Some will use the shock and coil for lift and when you do so you can run into coil bind when taking your truck off road where you will be flexing the limits of your front suspension. On the street its not much of an issue unless you are searching for potholes...lol
  20. Feb 22, 2017 at 8:22 AM
    #80
    wjrichardson
    WI
    2017 TRD/OR/AC
    Perfect, thank you sir!
