3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Feb 23, 2017 at 4:07 PM
    #81
    wirenut
    wirenut [OP] I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Alright. It is official, I purchased 5100's with OME 887 coilpacks and dakars and 5100's for the rear. Low-Range Offroad was great to deal with. Will post pics and thoughts after install.
    98_3RZ_NIC, as79fire and wjrichardson like this.
  2. Feb 23, 2017 at 4:13 PM
    #82
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    If you can, grab some pre-install hub-to-fender measurements and then follow up with after.
    Clay7160 likes this.
  3. Feb 23, 2017 at 4:29 PM
    #83
    wirenut
    Andrew
    NH
    98’ T4R
    I will indeed.
  4. Feb 23, 2017 at 4:38 PM
    #84
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You're going to be a lot happier with this than your original plan. What was the cost?
  5. Feb 23, 2017 at 5:30 PM
    #85
    wirenut
    Andrew
    NH
    98’ T4R
    1137$ for the suspension delivered I have to get a 1/4" taco leaner, ecgs bushing thingy and 1 1/4" wheel spacers still.
    iridebikes likes this.
  6. Feb 23, 2017 at 5:48 PM
    #86
    as79fire
    as79fire Well-Known Member
    Adam
    2016 TRD Sport 4d White
    Thank you very much! I also added it on my seats.
  7. Mar 1, 2017 at 1:34 PM
    #87
    wirenut
    Andrew
    NH
    98’ T4R
    Dakars and ecgs thingy showed up today!
    98_3RZ_NIC, SilverII and sorgon82 like this.
  8. Mar 1, 2017 at 1:44 PM
    #88
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Did you buy the standard 5100 rear shocks (part # 24-186728) to go with these leaf packs?
  9. Mar 1, 2017 at 2:02 PM
    #89
    wirenut
    Andrew
    NH
    98’ T4R
    Im pretty sure they are low-range offroad hooked it up. When they show up in a couple days I will confirm.
  10. Mar 1, 2017 at 2:08 PM
    #90
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    How's the ride with the front at 2"?
  11. Mar 1, 2017 at 2:11 PM
    #91
    Mr Salty
    Hermmy
    Lots of chrome
    If you got the standard 5100s they pretty much sold you the wrong shocks (too short, they can work but do not pair well), if they sold you the 5125s those will produce a pretty harsh ride (I know from experience, compression on those makes for a stiff ride). If you got the 5125 you will likely need longer brake lines to accommodate for the extended length of the shocks.
    With the Dakars, did they tell you that you needed bushings for the one side of the packs?
    Did they supply you with the Carrier Bearing Drop as well?
    You got longer ubolts too right?
    You got the fronts assembled or no?
  12. Mar 1, 2017 at 2:38 PM
    #92
    wirenut
    Andrew
    NH
    98’ T4R
    Lol oh boy, just confirmed the rear bilsteins they sized me up with are for 1 to 3" of lift, bushings, bearings, u-bolt, and front assembled with tophat yes. This isn't the first taco I've risen from the ground, but low range deffinately had the best deal on the assenbled front 5100's with 887's
  13. Mar 1, 2017 at 4:29 PM
    #93
    rathbun102
    rathbun102 Member
    Kyle
    2016 Tacoma Double Cab
    5100s set on the third mark with 1.5 inch aal and 285s. i do have a slight rake but thats what i was hoping for.
  14. Mar 1, 2017 at 4:34 PM
    #94
    wirenut
    Andrew
    NH
    98’ T4R
    Nice truck!
    rathbun102[QUOTED] likes this.
  15. Mar 1, 2017 at 4:36 PM
    #95
    greez82
    greez82 Shreddin the gnar
    Adam
    So Cal
    2017 Quicksand DCLB TRD OR 4x4
    Looks great!
  16. Mar 1, 2017 at 5:11 PM
    #96
    idoitforthebacon
    idoitforthebacon Active Member
    Looks awesome! Did you keep the overload?
  17. Mar 1, 2017 at 5:34 PM
    #97
    rathbun102
    rathbun102 Member
    Kyle
    Yes I did
  18. Mar 1, 2017 at 9:55 PM
    #98
    Mr Salty
    Hermmy
    Lots of chrome
    Bilstein does not make 1-3" lift application rear shock for the Tacoma's.
  19. Mar 2, 2017 at 3:46 AM
    #99
    wirenut
    Andrew
    NH
    98’ T4R
    Well ive been told there is and if they dont work ill send them back to get ones they do.
  20. Mar 2, 2017 at 6:08 AM
    #100
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I never heard of Bilstein making rear lift/leveling shocks either. Long travel, sure. Rear lift comes from springs or blocks.
