3rd gen 5100's w/ AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wirenut, Feb 16, 2017.
  1. Mar 2, 2017 at 6:13 AM
    #101
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    RCD Bilstein is the extended rear shock seems to be the one used on a lot of dakars for Tacomas
  2. Mar 2, 2017 at 6:14 AM
    #102
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Extended for travel, not lift.
  3. Mar 2, 2017 at 6:16 AM
    #103
    Clay7160
    They do not make a shock that lifts for the rear, but sometimes your rear lift is too much for stock length to handle so you need a longer or extended shock for the application
  4. Mar 2, 2017 at 6:17 AM
    #104
    breenlucas
    breenlucas Well-Known Member
    Lucas
    Southwest Florida
    2017 SILVER SR5 SHORT BED
    Forgive me... Can you go into a little more detail as to the exact specs and parts you'd suggest. I've been reading so much shit and I am sort of understanding what I want to do.
    TacoSurfs and remgu2000 like this.
  5. Mar 2, 2017 at 6:28 AM
    #105
    Clay7160
    Easiest way is to give Marie @HeadStrong Off-Road or @Downsouth Motorsports a shout, tell them your budget, and how much lift do you want to achieve. Seems the two most popular ways on Tw is using Bilstein 5100 shocks all around . You could obtain the lift in front by using the stock coil springs, and using the adjustable perches to add preload. The second way which will also ride better is to use the shock with an aftermarket spring such as OME . There are different models depending on how much lift do you want, and if you plan on adding skid plates and bumpers. For the front if you start going over 2" (some have not needed any up the 3 inch lift) you may have to get some upper control arms to get your alignment specs correct again. For the rear you could use blocks , add a leaf, or rear OME Dakar leaf springs. Three leaf add a leaf seems to be popular with the Tacoma crowd. Dakar are more costly and requires brake lines if you plan on flexing a lot off road, along with extended travel rear shocks.
  6. Mar 2, 2017 at 6:30 AM
    #106
    Blktre
    Land of Oz....
    Yes. I know this but it was said from 603sign that he was told the Bilstein shocks add rear lift. They do not. We just need to either correct his thinking or maybe we are not communicating with him correctly.
  7. Mar 2, 2017 at 6:33 AM
    #107
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    RCD/Bilstein's extended length rear shocks can SUPPORT up to 3-4 inches of lift.
  8. Mar 2, 2017 at 6:35 AM
    #108
    Blktre
    Land of Oz....
    Support, yes. But are not adjustable for lifting like the front. Right or wrong?
    Clay7160 likes this.
  9. Mar 2, 2017 at 6:36 AM
    #109
    Clay7160
    Re-read his post, it was clear
    he has Dakar rear lift springs
  10. Mar 2, 2017 at 6:37 AM
    #110
    Leo4x2
    Leo
    San Antonio, Tx
    Correct.
  11. Mar 2, 2017 at 6:38 AM
    #111
    Blktre
    Land of Oz....
    This is what made his remarks confusing then.
    Getting picky. Im bored this AM!
  12. Mar 2, 2017 at 6:42 AM
    #112
    Leo4x2
    Leo
    San Antonio, Tx
    We he did word it correctly and what they "sized him up with" are the shocks that support a 3-4 inch lift. Those are what he will need because those OME Dakar leaf packs will provide him with 2-3 inches of lift.
    So what he is saying is correct and those are the ones he will need to keep.
    mrjordan415 and Clay7160 like this.
  13. Mar 2, 2017 at 6:44 AM
    #113
    Leo4x2
    Leo
    San Antonio, Tx
    If you are talking about the shocks for the rear then yes keep them. They don't provide any lift, they just support up to 3-4" of lift. You will need them because your Dakars will give you anywhere from 2-3inches of lift.
    I currently have 4" Maxtrac spindles, OME Dakar leaf pack, 5100's adjustables set at 0 (or first notch), and the extended length rear shocks to support the 2-3" lift.
    The standard length shocks (24-186728) only support stock height - 1.5" lift.
  14. Mar 2, 2017 at 8:43 AM
    #114
    breenlucas
    Lucas
    Southwest Florida
    Can you attach some side photos and give some more details on the specs. This is exactly what I want to do with my truck. Same rims and all.
    Been looking all over the place for a similar setup. haha
    Thanks in advance
    remgu2000 likes this.
  15. Mar 2, 2017 at 8:45 AM
    #115
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    :smash: Holy cow man who's talking about rear shocks providing lift. I was simply indicating for his lift application (Dakars) he needed shocks that would support it. The standard 5100s will work, but they are too short and will fully extend rather easy thus causing them to fail (leak) over time. From what I've been told RCD is backordered on their extended 5100s, Bilstein has not been able to fill their order yet. This tells me there is a very good chance 603sign has the standard 5100 or 5125s. If he has the 5125s with the generic valving, depending on the extended length, he may need longer brake lines or at minimum a brake line extension spacer. I mentioned this because it could very well be that the company he bought from didn't go over all this with him, but I could be wrong.
    Just looking out for a fellow TW member, but I'm out of here
    mrjordan415 and wirenut[OP] like this.
  16. Mar 2, 2017 at 8:46 AM
    #116
    wirenut
    wirenut [OP] I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Lift comes from the OME dakar leaf springs.
  17. Mar 2, 2017 at 8:46 AM
    #117
    Blktre
    Land of Oz....
    Its all good. I took some posts the wrong way. My bad.
    mrjordan415 likes this.
  18. Mar 2, 2017 at 8:47 AM
    #118
    Blktre
    Land of Oz....
    Derrrr.
  19. Mar 2, 2017 at 8:49 AM
    #119
    Mr Salty
    Hermmy
    Lots of chrome
    He said "5100s set on the third mark with 1.5 inch aal and 285s"
    To me this would imply he has the 3rd gen 5100 set to the 3rd setting up front with the factory coils, 5100s in the rear with a 1.5" lift AAL. His tires are 285 so I'm guessing he has 285/70/17.
    1cleanFG likes this.
  20. Mar 2, 2017 at 8:50 AM
    #120
    Mr Salty
    Hermmy
    Lots of chrome
    No worries man, I do this a lot :fistbump:
    Blktre[QUOTED] likes this.
