3rd gen 6 inch suspension options???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maka45, Jan 2, 2022.
  1. Jan 4, 2022 at 6:56 PM
    #41
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    You could put in a couple of aal .
  2. Jan 4, 2022 at 7:27 PM
    #42
    Maka45
    Maka45 [OP] Active Member
    Caleb
    2020 tacoma trd sport 4x4
    6 inch BDS lift
    Ah ok about how long until its unsafe? And what are some good options to put in place of the blocks?
  3. Jan 4, 2022 at 7:28 PM
    #43
    Maka45
    Caleb
    6 inch BDS lift
    Also update i aired down the tires to 34. Pretty big difference honestly thanks guys
    Junkhead likes this.
  4. Jan 4, 2022 at 7:30 PM
    #44
    shotgunbilly420
    Yup 34psi is just right
    71tattooguy likes this.
  5. Jan 4, 2022 at 7:33 PM
    #45
    shotgunbilly420
    if offroading aggressively and truck bed loaded down , just have to inspect blocks for any cracks . Only time will tell.
  6. Jan 4, 2022 at 7:35 PM
    #46
    shotgunbilly420
    Pro comp was my choice .There is many other brands .
    Maka45[QUOTED][OP] likes this.
  7. Jan 4, 2022 at 7:38 PM
    #47
    Maka45
    Caleb
    6 inch BDS lift
    Honestly dont do much off-roading but i do load around 1300-1500lbs of concrete bags in it every so often lmao
  8. Jan 4, 2022 at 7:43 PM
    #48
    shotgunbilly420
    AAL's would help I'm running a 2" and a 1.5" . I have a little bit of hop in the rear when truck bed is empty . It doesn't drive me crazy. We do a lot of camping and landscaping around our house .
  9. Jan 4, 2022 at 8:48 PM
    #49
    Maka45
    Caleb
    6 inch BDS lift
    Any recommendations on some good AALs? Is it possible to replace the block all together? If you can are there any benefits?
  10. Jan 4, 2022 at 9:05 PM
    #50
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I run 30 psi in mine 285/70 R17
  11. Jan 4, 2022 at 9:06 PM
    #51
    toku58
    Mall Crawler!
    You need the long AAL's. The short ones will make your leaf springs into a "W"
  12. Jan 17, 2022 at 12:09 PM
    #52
    shotgunbilly420
