3rd Gen - AC Outlet in Cab and 400w Anytime
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djembefola, Aug 12, 2017.
  1. Oct 13, 2020 at 9:08 AM
    #181
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    As somebody who installed one of the rectangular surface installs (with 2 outlets and 2 USBs), you are correct on all points.
    Here is how I think about it, I was installing (2) outlets (my design requirement), so I could add (2) USBs without any significant additional real-estate used up by installing a surface mount unit. I just figured it was a couple extra USBs at no significant area or effort. I also added some 12V cigarette outlets that are powered from secondary battery (that are always hot) in the same area. I haven't measured the parasitic power used by the USB in the 120v outlet, but I THINK it is very very small when nothing is plugged in.
    So yes,
    for several reasons,
    it would be 'better' to make the USBs separate from the 120V... But maybe you want both...?
    A very important thing to consider: I think it is likely that newer USBs are going to come out in the future, so maybe its not the best usage to install USB outlets, instead install extra 12V cigarette outlets, so you can plug in the best/latest super duper USB outlets into the cigarette outlets, rather than being stuck with outdated technology.
    (If you had permanently installed 500mA USB outlets in your truck, those would seem pretty worthless now compared to the quickcharge USB chargers of today.)
    Grossomotto and tonered like this.
  2. Oct 13, 2020 at 9:53 AM
    #182
    harbrown
    harbrown Well-Known Member
    Harold
    Daphne AL
    2016 Tacoma Off Road 4x4
    yes, i agree that look with the grommet is nice. i considered it, one issue for me is i need the high speed good usb charge for higher end devices. those that i looked at were standard charging. Qualcomm 3.0 is the way to go. overall, using the 2 devices took up more room, in the end might be a little better though. time will tell. Why cant they just do it from the factory -- ugh...
  3. Oct 13, 2020 at 11:17 AM
    #183
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    These will do the job
    https://www.ebay.com/itm/30W-Fast-C...uick-Charger-QC-4-0-USB-A-QC-3-0/192721470472
    BigWhiteTRD[QUOTED] likes this.
  4. Oct 25, 2020 at 6:30 PM
    #184
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I know this is an old post, but do you happen to remember on the MT, what wire you had to ground? If any.
  5. Oct 25, 2020 at 6:43 PM
    #185
    caribe makaira
    Caribbean, Puerto Rico
    Edit: Cut pink, Ground the Inverter side. Insulate (tape up) and secure the remaining side.
    VirusCage[QUOTED] likes this.
  6. Oct 25, 2020 at 6:44 PM
    #186
    VirusCage
    Bruce
    Allison Park, PA
    Thank you, by remove: cut and cap, or depin?
  7. Oct 25, 2020 at 6:45 PM
    #187
    caribe makaira
    If you fancy, de-pin and insulate (tape up) and secure.
  8. Oct 25, 2020 at 6:47 PM
    #188
    caribe makaira
    @lapoltba is still on the wall for the Y harness on this...
  9. Oct 25, 2020 at 6:47 PM
    #189
    Grossomotto
    2017 4WDV6LB6MT
    Yes, listen to caribe. It's been almost two years since I did the mod. Good thing it's all still working.
    Sandokan and VirusCage[QUOTED] like this.
  10. Oct 25, 2020 at 6:47 PM
    #190
    VirusCage
    Bruce
    Allison Park, PA
    Thank you, Again! I should have done this earlier this year when I added my meso panel, my lights, my usbs in the dash, my anytime rear cam, my aux panel... but I didn't think I needed it! HA
    Grossomotto likes this.
  11. Oct 25, 2020 at 6:49 PM
    #191
    VirusCage
    Bruce
    Allison Park, PA
    Oh yeah and 2WD lo mod!!!! It was all too much at once
  12. Oct 29, 2020 at 11:17 AM
    #192
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  13. Nov 6, 2020 at 8:15 AM
    #193
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    uploadadventure likes this.
  14. Nov 6, 2020 at 8:55 AM
    #194
    Grossomotto
    2017 4WDV6LB6MT
    Working great, haven't driven the truck a whole lot but everything works.
    Sandokan and tonered[QUOTED] like this.
  15. Nov 6, 2020 at 9:00 AM
    #195
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    My daughters will appreciate the USB outlets and 3A should be enough for battery charging. Just gotta get the wire colors right.
    Grossomotto[QUOTED] likes this.
  16. Nov 6, 2020 at 9:06 AM
    #196
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Do you have the plug and play adapter or are you doing it yourself?
    I went with the toyota plug (from the 4-runner I think) and I'm planning to put it in the center console... some day.
    tonered[QUOTED] likes this.
  17. Nov 6, 2020 at 9:10 AM
    #197
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm going to dance with the angry pixies all by myself. I got the power grommet from Amazon. The first one in the Products box below.
    I just want to stop pulling the center console. A couple of the molded-in clips are not very happy. This should be the last mod for it.
  18. Nov 6, 2020 at 9:14 AM
    #198
    dilbert
    dilbert AI Member
    PNW
    :sawzall:
  19. Nov 6, 2020 at 9:22 AM
    #199
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :fingerscrossed:
    Grossomotto and dilbert[QUOTED] like this.
  20. Nov 6, 2020 at 9:49 AM
    #200
    Grossomotto
    2017 4WDV6LB6MT
    I'm pretty much done, I can't take me dash and doors off anymore.
