3rd gen Access Cab Bed Lights Using Double Cab Cargo Light Switch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoFlaTacoTRD, Jun 11, 2016.
  1. May 1, 2017 at 12:49 PM
    trrn11500
    trrn11500 Well-Known Member
    According to the above diagram if I remove the leds from my third brake cargo light and then install an led light in my cap and tap into wire number 1 and number five I should be able to control this light from the cab cargo switch? Thanx.
  2. May 25, 2017 at 10:15 AM
    redbird48oo
    redbird48oo Well-Known Member
    Greenville, SC
    2017 Tacoma SR Access Cab, 2.7 with auto GREAT TRUCK
    okay was looking at the part number for for switch plate 55446-04030-c0, and with that number the toyota dealers on line are showing the switch plate that goes under the AC controls? I copied and pasted the number, and still came up with the toyota dealers on line showing the switch plate under the AC control, am at lose now help
  3. Jul 21, 2017 at 12:51 PM
    joepagejr
    joepagejr Well-Known Member
    Joe
    2016 TRD Off-Road Access Cab - Inferno
    ...for future installation reference...
  4. Aug 22, 2017 at 12:08 PM
    jbpace
    jbpace Member
    Jon
    2016 Grey Tacoma AC TRD OR
    Finally installed a set of bed lights (third-party off Amazon) and took some photos of installation inside the cab. Right now this is simply my placeholder to post photos & a part number when I get home.
  5. Apr 13, 2019 at 6:20 PM
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    So I assume in a 3rd gen Access Cab the OP found the light green wire extending from the relay he installed TO IE1 but found no light green wire extending FROM IE1?
    sandtaco2016 likes this.
  6. Apr 13, 2019 at 8:13 PM
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
  7. Apr 13, 2019 at 8:27 PM
    sandtaco2016
    sandtaco2016 Member
    2016 Quicksand TRD
    Lift, Grille, Light bars, wheels, tires
    I had to buy that wire from the dealership and install it into the connector. No wire tap, just connect right to it.
    Since there was no switch or relay, I had to buy the piece for the switch, the switch, the relay and the green wire.
    I will post a pic with part numbers soon.
    Boghog1, Tullie D and 5500 like this.
  8. Apr 15, 2019 at 9:50 AM
    oly51
    Gary
    S.E. MA
  9. Apr 15, 2019 at 6:44 PM
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    SCS F5, 5100, Kenwood-Kicker/Polk
    I have an SR5, where is this relay supposed to go? in the engine compartment fuse/relay box?
  10. Apr 15, 2019 at 6:53 PM
    sandtaco2016
    sandtaco2016 Member
    2016 Quicksand TRD
    Inside the cab. It’s on the other side of the bed light switch panel.
    You should see other relays or at the very least a relay “bus bar”
  11. Apr 15, 2019 at 6:56 PM
    caribe makaira
    Caribbean, Puerto Rico
    Cab..but your SR most likely doesn't have the terminals to attach to the relay.
  12. Apr 16, 2019 at 5:11 AM
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    the factory wiring is there for the switch and 3rd brake/cargo so will see if for relay too. thanks
  13. Apr 16, 2019 at 5:17 AM
    caribe makaira
    Just noted you have SR5:rolleyes:, so I'd say you're set:thumbsup:
  14. Apr 16, 2019 at 12:27 PM
    caribe makaira
    :popcorn:
  15. Apr 18, 2019 at 1:11 PM
    #35
    sandtaco2016
    sandtaco2016 Member
    2016 Quicksand TRD
    Here are all the part numbers you need if you don’t have the factory deck lights.
    If you have the power rear window, you will need a different housing.
    And if you don’t need the Squatch lights or don’t have the A/C power switch. They are easy to see in the parts book.
    Housing. Description base, switch hole NO.1
    55446–04030 – CO
    Deck lamp switch. Description deck lamp part number 8426-0C020
    Relay 90080–87026
    Wire - terminal, repair 82998–24290
    BigWhiteTRD likes this.
  16. Apr 18, 2019 at 2:30 PM
    #36
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just need qty1 wire?
    This wire is where you connect your lights 12v (switched) I assume?
  17. Apr 18, 2019 at 3:33 PM
    #37
    caribe makaira
    Since you don't have the Cargo Lamp green wire going towards the high mount stop/cargo lamp..then yes.
  18. Apr 26, 2019 at 5:10 PM
    #38
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    This is what I installed in the box of my 2017 TRD Access Cab.
    I will have 3x ways to turn on the lights, manual switch mounted in the cubby on the left side, remote control fob from a relay under the hood and soft touch controller from inside the cab.
  19. Sep 23, 2019 at 7:34 AM
    #39
    AMOORE_93
    AMOORE_93 Well-Known Member
    Richmond, va
    2016 Tacoma 4x4 Offroad
    A write up on this would be most helpful...
  20. Sep 23, 2019 at 7:52 AM
    #40
    oostroma
    oostroma (Boomer)
    Ontario
    I'll get some pics uploaded tonight with a bit more detail as to how I wired the truck up.
    AMOORE_93 likes this.
