3rd Gen Ball Joint Bolts a thing?!?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scubatoe, Sep 29, 2024.
  1. Sep 29, 2024 at 7:02 PM
    Scubatoe
    Scubatoe [OP] Nice Marmot
    Lawrence, KS
    '21 Blk AC 4WD SR; '04 White AC 4WD TRD (gone)
    All Pro Bilstein kit, w/ 2in lift
    I'm in the process of repairing some damage to my pass LCA brackets, and taking the opportunity to do a bunch of other crap while I'm down there. (For the curious, I'll list at the end).
    Anywho, I managed to misplace one of the lower ball joint bolts (but later found it). In the meantime, after a failed attempt to source a new one at the local O'Reilly's, I discovered that an M16-1.5 flange bolt is VERY diffucult to find, let alone one 45mm long.
    During my search, I came across this thread:
    https://www.tacomaworld.com/threads...s-wanted-about-lower-ball-joint-bolts.772506/
    That had me read the whole evaluation they did @SpikerEng See here. I also traveled down the rabbit hole of ball joint bolt failures on 1st Gen Tacos and 4Runners.
    I haven't found much in the 3rd Gen threads about lower ball joint bolt failures. I'm guessing the M16 bolts Toyota put in the 3rd Gens (as opposed to the M10s) may have been in response to this issue, considering they have 2.5x the cross-sectional surface area of the M10s.
    THAT ALL BEING SAID - why the hell is it so HARD to find a flange bolt in M16-1.5 x 45mm?!?!
    I'm putting in the @Marlin Crawler LCA Frame Brace, White Line LCA Bushings, and Dirt King UCAs.
    On a side note - has been a great tool for straightening the bent lower control arm mounts.
  2. Sep 29, 2024 at 7:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Sep 29, 2024 at 7:30 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    For m16, 2.0mm is the standard pitch so that's about all you find in the regular chain hardware or auto parts store. Try looking at independent hardware or auto parts stores. Still finding the right combination of pitch, head type and length will be hard to find anywhere other than toyota or any other car manufacturer.
    scocar likes this.
  4. Sep 29, 2024 at 7:44 PM
    scocar
    scocar hypotenoper
    TnShooter[QUOTED] likes this.
  5. Sep 29, 2024 at 7:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Most hardware stores are geared toward contracting and homebuilding, so they stock coarse thread hardware. M16-2.0 is coarse thread. M16-1.5 is fine thread.
    Specialty metric hardware stores have them, but they cost more than the OEM bolt at the dealer. For example: https://belmetric.com/m16x1-5-fine-...9-special-oem-zinc-flake/?sku=BF16X1.5X45PGEM
  6. Sep 29, 2024 at 7:51 PM
    Scubatoe
    Lawrence, KS
    Yes, thanks, my computer also comes with the googles, in which I am proficient. In fact, I completed the transaction for 4 new bolts from that very site about 30 seconds before finding the offending, mischievous bolt hiding in plain sight in my shop. That having been preceded by at least 2 hours of searching, giving up, and driving around to find a replacement.
    The important part here is: are these M16 bolts as vulnerable to failure as the M10s on the 1st Gen and associated 4Runners? The weird part I discovered is that an M16-1.5x45mm flange bolt (even any length M16 fine thread) is seemingly only available from Toyota. Conversely, why did Toyota choose to fix the problem with the 1st Gen/4Runner bolt failures with such an obscure bolt? Hell, even Fastenal only had M16-1.5x50mm - and several other fastener wholesalers, if they even carry M16s, only offer it in coarse 2.0 pitch.
    After thinking through it while writing this, I'm going to answer my own question. The M16-1.5x45mm bolt was chosen by engineers doing FEA, to identify the minimum size bolt suitable for the stress analysis - with no thought to the availability of said bolt. A recurring problem I've had as a fabricator (with a mechanical engineering degree) that repeatedly reinforces the shit welders talk about engineers.
  7. Sep 30, 2024 at 8:40 AM
    Scubatoe
    Lawrence, KS
    The other question I really needed to highlight here is:
    Do the 3rd green Tacomas have issues breaking lower ball joint bolts?
  8. Oct 1, 2024 at 6:27 AM
    lbhsbz
    lbhsbz Well-Known Member
    No, the 2nd and 3rd gen use a completely different (opposite) design than the 1st gen. Nothing really broke in the first gen, they just separated when the poly liner wore out and the ball stud got into the housing. The 2nd and 3rd gen ball joints carry the load in a different direction so that the ball stud is pushed into the housing instead of trying to pull it out of the housing.
  9. Oct 1, 2024 at 6:40 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  10. Oct 2, 2024 at 8:35 AM
    Scubatoe
    Lawrence, KS
    Ball joint BOLTS...not ball joints.
