3rd Gen Bilstein 5100 now available
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulldog, Sep 28, 2016.
  1. Jan 28, 2017 at 1:25 PM
    #301
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    page 14 post 266 of this thread.
  2. Jan 28, 2017 at 1:46 PM
    #302
    Taco351
    Taco351 Well-Known Member
    Robert
    NLR/Sherwood
    2017 Tacoma Double Cab 4X4 TRD Off-Road White
    K&N air filter/LED lights/Magna Flow Muffler/TOYO AT2 Tires and lots of fun stuff.
    Got it. Thanks!
  3. Feb 1, 2017 at 2:10 PM
    #303
    Bikeguy
    Bikeguy Member
    I've received my new Bilstein's from HeadStrong and I'm thinking about running the driver side one at the second to lowest setting and the pass. side one on the lowest. Do you guys think that this would fix the 1/4" driver side sag or would it be to much?
    Your thoughts?
    HeadStrong Off-Road likes this.
  4. Feb 1, 2017 at 2:22 PM
    #304
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    I would guess too much, then you would have a passenger side lean...
  5. Feb 1, 2017 at 3:38 PM
    #305
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I think dusman is right. 2nd notch = 0.65. Probably just change the problem to the other side.
  6. Feb 2, 2017 at 6:59 AM
    #306
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Hey guys question...I'm still deciding which lift to go with,4" spindle lift or a Bilstein 3" lift.....the only thing keeping me from the 4" spindles is having to do the carrier bearing drop kit....
    SO, for those that have the 3" Bilstein lift all around with 2888 coils, driver spacer and single AAL in the rear....how does the truck sit? Is it level? Does it have a bro lean? or does the truck still have a slight rake?
    Looking to order my kit today but want to see if a Deaver AAL (single) will raise the rear enough to be level with the front or if I should do a 1" or 1.5" small block along with the AAL....would appreciate ya'll giving your input!
  7. Feb 2, 2017 at 7:20 AM
    #307
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    @ChadsPride
  8. Feb 2, 2017 at 7:22 AM
    #308
    Leo4x2
    Leo
    San Antonio, Tx
    lol just talked to him about the CB drop kit. I think I'm going to stay with the spindles.
  9. Feb 2, 2017 at 7:25 AM
    #309
    bcbrack
    bcbrack Well-Known Member
    Thinking of going 885s & 5100s or the 6112s the come with coils. Any reason to pay the extra $$ to go with the 6112s?
    jhunter80 likes this.
  10. Feb 2, 2017 at 7:56 AM
    #310
    Bikeguy
    Bikeguy Member
    Dusman & Bigfoote , Thanks for the info!
    Maybe I'm missing something, but what is the best way with my setup to get rid of that driver side 1/4" sag?
  11. Feb 2, 2017 at 8:19 AM
    #311
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
  12. Feb 3, 2017 at 6:16 AM
    #312
    Bikeguy
    Bikeguy Member
  13. Feb 3, 2017 at 6:30 AM
    #313
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I dont think there is an 1/8 spacer. Are you on the stock coils? Check the rubber washer at the top of the coil to see if there is something wrong.
  14. Feb 3, 2017 at 6:38 AM
    #314
    Bikeguy
    Bikeguy Member
    Stock coil springs! I'll check the washer tomorrow when it warms up. I'm planning on putting my 5100 front shocks (24-263108 ) on then, the rear (24-186728) are already on.
  15. Feb 12, 2017 at 4:35 PM
    #315
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I'm going to be "that guy" and ask this - I've read the whole thread, read the whole other 3rd gen Bilstein 5100 thread, and searched... and I'm still not 100% sure about this.
    I realize individual results vary.
    That said, I want to install 5100s all around and keep the stock springs. I want to level the front, or have the front just a hair lower than the rear, which should be about 1" +/- lift in the front. 2017 AC 4WD SR (base).
    My concern is that 3rd gen 5100s at .65 will be too low and still give too much forward rake, and 1.1 will be too high and give a hair rear rake. I think 2nd gen 5100s at .85 may be the way to go to be mostly level with just a hair of forward rake but I'm honestly unclear about this. Anyone with this setup (leveled only) care to comment on the best option?
    Also, when we are referring to "settling" after install, I always thought this pertained to the SPRINGS, not the struts. No? The way I'm reading the thread, even guys with stock springs (that should already be broken in from use) are having settling after install? Yes/no?
    Thanks...
  16. Feb 28, 2017 at 8:24 PM
    #316
    Leo4x2
    Leo
    San Antonio, Tx
    Hey guys, so on the 3rd gen Bilstein struts, Headstrong does not recommend using the 5th setting on our Tacomas.
    I am running a 4" spindle lift with these struts set at 0 but need to gain another 2-2.5" to clear my tires.
    What are the dangers of using the 5th or highest setting? Is anyone here running theirs on that 2" notch?
  17. Mar 1, 2017 at 7:45 AM
    #317
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    It isn't us that doesn't recommend it necessarily. That is a recommendation made from Bilstein themselves. If you are wanting to gain more lift in order to try to clear you can go with a lift coil and keep the Bilsteins at the 0 setting. This will also help with the ride quality.
  18. Mar 1, 2017 at 7:56 AM
    #318
    Leo4x2
    Leo
    San Antonio, Tx
    I just assumed it was something ya'll didn't recommend because it's under the 3rd gen Bilstein shocks. But I wouldn't like to sacrifice ride quality with compressing the springs too much. So you think a spacer will do just fine?
  19. Mar 1, 2017 at 7:58 AM
    #319
    HeadStrong Off-Road
    You already have the spacers there right? If so you could just give it a try and see how you like it.
    Leo4x2[QUOTED] likes this.
  20. Mar 1, 2017 at 8:00 AM
    #320
    Leo4x2
    Leo
    San Antonio, Tx
    I have my RC spacer that they claim is 2". I will try using that and see how it looks. I am looking to get steel blocks for the rear but they are hard to find. Is this something that you carry?
