3rd Gen Bilstein 5100 now available
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulldog, Sep 28, 2016.
  1. Mar 1, 2017 at 8:04 AM
    #321
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    We have cast for the 1, 1.5, 2 and fabricated for the 3 and 4.
  2. Mar 1, 2017 at 8:05 AM
    #322
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    I will send you a PM.
  3. Mar 2, 2017 at 7:42 PM
    #323
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Having had the 3rd gen 5100 set at 1.1 initially and now at stock height I was thinking about 884 coils which would provide the 1" lift I'm after. Truck rides great at the current position, thought it was too harsh at third notch(1.1"). According to the chart on Headstrongs website it seems as if 884=1" lift even though it is not directly stated. Will the 600lb 884 coil be enough and will it be noticeably softer then the preloaded factory coil?
    HeadStrong Off-Road likes this.
  4. Mar 3, 2017 at 8:22 AM
    #324
    HeadStrong Off-Road
    From the feedback I have customers do feel like the OME coils provide a better ride quality then the preloaded factory spring (depending on preload settings and which coil you go with). Ride quality is one of those things that is greatly subjective though and really comes down to your personal perspective.
  5. Mar 3, 2017 at 9:45 AM
    #325
    Silentshredr
    Chuck
    16 DclbOr4x4
    Pretty much my thought, also comparing preloading a progressive spring rate to a non preloaded linear rate spring. I'm sure I'll be in contact next week to order, thanks for your input as always.
  6. Mar 3, 2017 at 12:03 PM
    #326
    HeadStrong Off-Road
    Anytime!
  7. Mar 6, 2017 at 3:41 AM
    #327
    Krazy4Tacos
    Krazy4Tacos Member
    Coltin
    2017 Tacoma TRD Sport
    Marie,
    I'm looking to obtain the same stance as this tacoma. I'm set on buying the 3rd gen 5100's 4th notch for the front. What size block would you recommend for the rear as I won't be doing an AAL of any kind, just stock everything in the rear.
  8. Mar 6, 2017 at 4:14 AM
    #328
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    @HeadStrong Off-Road
  9. Mar 6, 2017 at 4:06 PM
    #329
    HeadStrong Off-Road
    I am so sorry that it took me awhile to get back to you, Monday's are hectic.
    That truck has an Icon 3-leaf with the overload retained which means that there is probably around 2" of lift in the back. It would be recommended to go with different shocks in the rear since the stock shocks are not really meant for any rear lift.
  10. Mar 10, 2017 at 11:38 AM
    #330
    HeadStrong Off-Road
    Working on PM now. :)
  11. Apr 6, 2017 at 6:49 PM
    #331
    alxdo2
    alxdo2 Proud Toyota Owner
    2016 4x4 SR5 Double Cab Tacoma
    * DoubleCab 4x4 SR5/Appearance Package Tacoma * Added Toyota Tonneau Bed Cover * Added Toyota Predator Steps * Added Weather Tech Mats * Added Tacoma Letter Inserts on Tailgate * Added MBRP Catback Exhaust * Added Weather Tech Bed Step * Added Sound Proofing Material * Added New Speakers on 4 doors * Added TRD PRO Grill * Added LED Bulbs Hi/Low * Added Skid Plate
  12. Apr 7, 2017 at 12:31 PM
    #332
    HeadStrong Off-Road
  13. Jul 25, 2017 at 8:03 AM
    #333
    Neodous
    Neodous Well-Known Member
    Larry
    2016 Super White Toyota Tocoma TRD Off-Road
    Stock
    Maybe someone can help me in here I'm planning on lifting my 2016 Toyota Tacoma off-road with Bilstein 5100. I want to lift the front 2.5 inches and the rear 2 inches with blocks. I did see on someone's website that the Bilstein only accommodate a 0 to 1 inch lift and in the rear. Does anyone know anything about that?
  14. Jul 25, 2017 at 8:10 AM
    #334
    HeadStrong Off-Road
    You can use them with 2" blocks, but they will fully extend rather quickly. If you just use your truck to commute and don't really off-road it, they are fine. If you off-road it a lot they are not the ideal shocks to run because of their extended length.
  15. Jul 25, 2017 at 8:23 AM
    #335
    Neodous
    Larry
    Stock
    I don't plan on doing a whole lot of off-roading but I wanted it to be capable. Would there be a better option for rear shocks from Bilstein?
  16. Jul 25, 2017 at 8:27 AM
    #336
    thinbluebowman
    thinbluebowman Well-Known Member
    Colorado
    2017 DCSB OR
    Tint, Tonneau.
    Did we ever find a solid answer for this? I too am interested in this exact same setup with the 285's. maybe 17 inch wheels tho. Any pros from 16 to a 17?
  17. Jul 25, 2017 at 9:12 AM
    #337
    HeadStrong Off-Road
    You could go with the 5160 Bilstein that is a great option. The extended Bilstein 5100 is more for a 3-4 block or a full leaf pack replacement so you would most likely have to modify the factory bumps to run that with a 2" block. Bilstein also has 5125's but they are a universal shock that isn't vehicle specific so the valving is more generic.
  18. Jul 25, 2017 at 9:13 AM
    #338
    HeadStrong Off-Road
    The 887's will provide around 3" of lift on a stock weight 05-15 4dr 4wd running the 2nd gen Bilsteins at the 0 setting.
    It is always hard to say exactly how much lift you will gain from any one coil because so many factors come into play like condition of the factory components, trim of truck, and any add-ons or additional options you may have. With that being said here is a link to our spec page so you can see what the average after-settled lifts are from the various coils on the different struts available.
    http://www.headstrongoffroad.com/uploads/1/1/8/4/11846658/lift_guide_shock_and_coil_selection.pdf
  19. Jul 25, 2017 at 10:06 AM
    #339
    thinbluebowman
    Colorado
    2017 DCSB OR
    Tint, Tonneau.
    Thanks for the reply I'll check it out. Im in a 2017 so I'll have to do some more digging. Just interested in getting 285's without rub as economically as possible.
  20. Jul 25, 2017 at 10:07 AM
    #340
    HeadStrong Off-Road
    Working on PM for you now :)
