3rd Gen Bilstein 5100 now available
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulldog, Sep 28, 2016.
  1. Oct 13, 2016 at 10:37 AM
    #101
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    The only difference in the coils, with the exception of the 886 coils, is the free length.
    I'm not sure I understand the question, but....
    The coils themselves will produce a slightly different ride as more free length equals more initial preload. The same holds true with the notch settings, because they land at different locations the initial preload at assembly can produce a slightly different ride.
    Does this answer your question :oops:
  2. Oct 13, 2016 at 10:39 AM
    #102
    HeadStrong Off-Road
    Oh and we tweaked the description a bit more to help make things more clear. Feedback is very much appreciated :thumbsup:
  3. Oct 13, 2016 at 10:41 AM
    #103
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I should have said do OEM 2015 and 2016 coils ride the same at similar notches on the gen specific 5100's? Sorry I wasn't clear.
  4. Oct 13, 2016 at 11:03 AM
    #104
    HeadStrong Off-Road
    Well the new 5100 have a 5th notch so there's that. Also the projected lift heights are different and so preload is going to be different, which this will affect the ride. Aside from this if there is a difference in valving in the 5100s this can alter the feel from one to another. There is just way too many variables there to do a fair comparison.
    Sooo I can't really say and have not physically tried to compare the two (i.e 2015 with 2nd gen 5100 at 2nd notch vs. 2016 with 3rd gen 5100 at 2nd notch).
  5. Oct 13, 2016 at 11:10 AM
    #105
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Thanks Marie! I figured this would be the answer but hey i had to ask.
  6. Oct 13, 2016 at 11:19 AM
    #106
    HeadStrong Off-Road
    Anytime. If you have any other questions just let me know :)
  7. Oct 13, 2016 at 12:11 PM
    #107
    RBfastback
    RBfastback It's Got Electrolytes
    mike
    FL
    16 mgm TRD off road
    thank you for the explanation, also the zero setting on both 5100's being different makes much more sense.
    so i was planning on doing the ome 887's with the new gen 2 billsteins and some UCA's installed on a 2016 gen 3. would that be more then a 2" lift?
    everyone always says not to go over a 2" lift on a gen 3 tacoma unless u do other things too.
  8. Oct 13, 2016 at 12:17 PM
    #108
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    So 2015 bilsteins set at .85 is the same as 2016 bilsteins set at .65 as far as front lift is concerned? Using stock springs
  9. Oct 13, 2016 at 12:31 PM
    #109
    HeadStrong Off-Road
    So because of the new ZERO notch setting on the 3rd Gen 5100s the 887 coil will see more initial compression. This would normally translate to more lift, however; because of the smaller extended length you will probably only get about 2.25". Though we do our own testing here, it really helps to gain feedback from the masses to ensure more accurate data. With minimal data available this is the approximate lift height we anticipate seeing.
    We do agree with keeping the front of the truck at around 2" max lift. Aside from the angles, lifting the truck too much just takes from the down travel which in turn impacts the ride, specifically where droop is needed in the suspension to soften the blow (i.e. pot holes or dips in the rode).
  10. Oct 13, 2016 at 12:37 PM
    #110
    HeadStrong Off-Road
    Not the same, one is giving 0.85" of lift and the other is giving 0.65" of lift.
    These are very exact numbers so think approximate. When I see 0.85" I think about 1" lift. When I see 0.65" I think about 0.5" lift. Coils are never exact anyways, there's always a product tolerance that needs to be considered which influences the actual lift height when all said and done.
  11. Oct 13, 2016 at 12:59 PM
    #111
    bucktowntaco
    New Orleans
    Thanks. Still trying to decide which ones to put on my '17 sport.
  12. Oct 13, 2016 at 1:37 PM
    #112
    HeadStrong Off-Road
    Just keep in mind the lift heights for the 2nd Gen 5100 shocks (0.85, 1.75, 2.5) are for the 2nd Gen Tacos using the factory coils, if using these shocks for the 3rd gen Taco the lift heights will be different because the coils are different. We don't offer lift #s for the 3rd Gen Taco using the stock coils with the 2nd Gen 5100 shocks.
  13. Oct 13, 2016 at 4:18 PM
    #113
    bulldog
    bulldog [OP] Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Shocks came in today, I haven't opened them, but I have them now.
    mrjordan415, bigfoote13 and Siblue like this.
  14. Oct 13, 2016 at 6:28 PM
    #114
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    no because they start at different heights. 2nd Gen stock height is 20 inches and 3rd Gen is 21 inches. 2nd Gen at .85 would theoretically make is 20.85. First notch on 3rd Gen would be 21.65. Second notch on 2nd Gen is 21.75 second notch on 3rd Gen is 22.1. 3 notch on 2nd Gen would be 22.5. 3rd Gen would be 22.55 and so on...
  15. Oct 13, 2016 at 8:16 PM
    #115
    fatz
    fatz Well-Known Member
    Ontario, Canadian
    2022 Trail
    255/75/17 Duratracs on FJ color matched steelies
    Post pics and settings when you bolt them in.
  16. Oct 14, 2016 at 3:37 AM
    #116
    Texas Duck
    Texas Duck Active Member
    2016 Silver Tacoma SR5 4x4
    My head hurts
    TheCiscoKid, mikestaco17 and alf like this.
  17. Oct 27, 2016 at 8:12 PM
    #117
    rvon719
    rvon719 Well-Known Member
    Robert
    Cape Cod MA
    2016 White Tacoma TRD OR
    soo anyone got pics of their truck with the new height settings?
    HeadStrong Off-Road likes this.
  18. Oct 27, 2016 at 9:20 PM
    #118
    RBfastback
    mike
    FL
    16 mgm TRD off road
    ya know i wonder what the more experienced ppl with suspension think about this thought:
    if the old 5100's have more overal travel then the new 5100's for the gen 3 taco then if u go with the bilstiens old 5100 but use ome springs for the lift and leave the shock at 0 then wouldn't the old 5100's be better and have more travel??
    also u can't use the new 5100's with ome 887 or 888 unless u wanna go over the 2" lift and that definitely isn't recommended without other modification.
    please school me if i'm completely wrong.
  19. Oct 28, 2016 at 4:59 AM
    #119
    bulldog
    SW MO
    2023 Pro
    Mine are still in the box, still deciding what to do.
  20. Oct 28, 2016 at 6:44 PM
    #120
    HeadStrong Off-Road
    I haven't received any before and/or after pictures of them yet. I will try to remember to post them once I get some.
    rvon719[QUOTED] likes this.
