3rd Gen Bilstein 6112/5160 review
Discussion in 'Product Reviews' started by VangaSTL, Oct 17, 2016.
  1. Jun 10, 2018 at 8:45 PM
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    I went to Perry’s Quality Auto Repair in Simi Valley. The owner was a really nice guy.
  2. Aug 11, 2018 at 8:36 PM
    Vertaco
    Vertaco Well-Known Member
    How much do you thinking would cost to install the 6112s?
  3. Aug 11, 2018 at 9:24 PM
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    No clue, they charged me $50 to assemble them. I installed them myself.
  4. Jan 25, 2019 at 8:59 AM
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    How did you not mess with the alignment cams when installing? Did you unbolt the upper control arm and use a pry bar to pry the lower control arm low enough to squeeze in the new/taller strut assembly?
  5. Jan 25, 2019 at 10:24 AM
    kodaco771
    So Cal
    2017 OR DCLB 4x4
    I left the UCA connected. I used a floor jack under where the lower ball joint connects and slightly jacked up the rotor assembly (I don’t know what it’s really called). This gave me more room by moving the UCA higher up. Then I used a pry bar by putting the tip of the pry bar in the LCA where the shock mounts with the pry bar against the the lower shock mount. By putting upward force on the pry bar, the LCA is pushed down and the shock slides in. It takes some time and force but it will go. I don’t know if that made any sense but I found a video showing how to do it. This guy hit the shock with a mallet to get it in though, I definitely didn’t do that.
    https://m.youtube.com/watch?v=xFgzwqOsbFo
  6. Jan 25, 2019 at 10:33 AM
    bunz559
    Fresno, CA
    Absolutely, got it. I've never done it this way as I figured it's probably just quicker if I loosen the 2 alignment bolts. But I have seen videos of doing it this way. I figured this method is a bit harder as you'd have to put some good pressure to get that LCA low enough to slip in the extended strut assembly.
  7. Feb 3, 2019 at 2:53 PM
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Any idea what the longevity is of these shocks? I am just a weekend warrior. No rock crawling or anything drastic. Just want to know how much time can be expected with this much money put in. Thanks.
    CygnusX191 likes this.
  8. Feb 13, 2019 at 2:11 PM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    Hey do you ever make your way up to Santa Clarita area? I'd love to see your setup in person if you don't mind. I'm torn between doing 5100s vs the 6112/5160s.
  9. Sep 11, 2019 at 8:48 PM
    Laloplus4
    Laloplus4 Tacoattack
    Jose
    BAY AREA!
    2017 white tacoma trd off road 2004 tacoma king cab short bed supercharged
    Thinking on going this set up.. Is there a way I can get a 3inch all around with this set up?
  10. Nov 17, 2019 at 8:52 AM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    OMG! the "car doctor" is the worst! I watched him try to remove one rustyish bolt and he ended up leaving it after one pull with the wrench and says I don't know how you guys deal with rusty bolts... And moves on... WOW. My mouth dropped... And this guy makes money doing this?
  11. Nov 22, 2020 at 11:36 AM
    _Xaviermoringlane
    _Xaviermoringlane Well-Known Member
    Xavier
    2006 Silver Tacoma
    Grill, Tires/Rims/Leveling kit
    i doubt you’ll see this, but it’s worth a shot.
    i’m mot sure if you’ll see this. but i’m considering 6112 in the front, but i have a steel bumper and you said to avoid the 6112 if you have one?
  12. Jan 26, 2021 at 7:57 PM
    AusRunner
    AusRunner Well-Known Member
    Las Vegas, NV
    2021 TRD Off Road 4X4 DCSB - Cement
    Old thread but I just ordered the 6112/5160 for a new '21 TRD OD and would be interested to hear how this setup performs off-road compared to stock OR suspension.
  13. Feb 3, 2021 at 10:00 AM
    tedNugent
    tedNugent Well-Known Member
    ted
    2019 trd Sport
    I’m interested also. I would also like to know how long these last. How do these compare to 5100 in ride quality?
  14. May 4, 2021 at 10:49 AM
    crazyjeys
    crazyjeys Well-Known Member
    SoCal
    2018 TRD Off Road 4x4
    I have mine going on for almost 3 years now with extensive offroading in varying conditions and trails. Still holds nice. No leaks whatsoever. Didn’t encounter any shock fade on high speed desert runs and takes bumps pretty good. Not the best, but pretty good. Best bang for your buck if you ask me.
    econwatch likes this.
  15. May 31, 2021 at 7:40 PM
    #35
    TacoedBars
    TacoedBars TacoedBars
    Sacramento
    16 TRD 4x4 OR
    I thought to accommodate for the "taco lean" you would just have one notch higher than the passenger side instead of using the 1/4 spacer? I was leaning on getting these but somehow ended up with Fox 2.5s. Nice write up though
    SandyTaco4x4 likes this.
  16. Jun 2, 2021 at 11:22 AM
    #36
    VangaSTL
    VangaSTL [OP] Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I ended up on the highest setting for each shock though so I had to do the spacer
  17. Jun 13, 2021 at 2:00 AM
    #37
    Anadahawaiiantaco
    Anadahawaiiantaco Active Member
    Isaiah
    2018 Tacoma Off-road 4x4
    16x8 Scs ray10. 285/75r16 Yokohama Geolander M/T. Bilstein 5160 5/6. Bilstein 5100. Icon rxt leaf pack stage 2. TRD PRO skid plate. TRD PRO Grill. Softopper canopy. All-pro rock sliders.
    I got the 6112s in the front of my 2018qc OR long bed and 5100s in the back. About 2 years now with mostly street driving but taken on a couple good trails and beaches. Long story short is I love them. They worked well on washed out dirt roads going 30-40 mph with dips and potholes. I did notch 4 and 5 with no spacer and resulted in no lean. I may go up 5/6 and add an inch to the rear to try and squeeze some 33’s with a bunch of cutting.
  18. Jun 13, 2021 at 3:27 AM
    #38
    2020_TRD_OR
    2020_TRD_OR Well-Known Member
    Pennsylvania
    2020 Cement Tacoma TRD Off Road
    Bilstein 6100s & 5160s Wheeler's Super Bump Stops Wheeler's AAL SPC UCAs Sway Bar Relocation Kit RCI Front Skid Plate
    I'm getting mine installed at months end on the 5/6 setting.
    My thoughts about the spacer are that 6/6 with a 1/4" spacer is equal to a 2 1/4" lift in the front and 5/6 is just 2"
  19. Nov 3, 2021 at 12:34 AM
    #39
    Anadahawaiiantaco
    Isaiah
    update as I have finally moved up a notch on the 6112s. Currently sitting at 6/5. Also changed out the rear leafs with icon rxt stage 2. Height is perfect. I’ll chime in again with height differences from my original 5/4 setup. I’ll get to test out the suspension this weekend. Drove nice tho on the way home from the shop. Didn’t notice much difference in ride quality
  20. Nov 3, 2021 at 12:47 AM
    #40
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I thought having 6/5 is to adjust for the "taco lean" 6/6? :annoyed:
    6/5 is a lot stiffer but I love it.
