3rd gen deep transmission pan
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Billy Bada$$, Sep 7, 2020.
  1. Sep 7, 2020 at 6:44 AM
    Billy Bada$$
    Billy Bada$$ [OP] Well-Known Member
    Bill
    2018 Cement Grey Tacoma TRD
    3inch lift, 18ich wheels with Toyo Tires. MBRP dual exhaust, Rough Country side steps and Gator tonneau cover. More to come....
    Hey all I'm not sure if a thread for this has been done, I'm new to the forum and all I could find on this subject was for 2nd gens. I want to put a deeper transmission pan on my 18 Taco, I also plan to add a larger cooler. I will be hauling a smaller enclosed trail to tow my wife and my sport bikes around to different areas across the country to ride. I know this sounds excessive with the larger cooler and deeper pan but I want to do everything I can to keep the trans cool. So I searched everywhere and can not find a company that makes a deep pan for the 3rd gens. I came across a company from the 2nd gen thread called PML. I went to there site PML yourcovers.com. I sent them an email about 3rd pans and they said they have gotten a few people asking and IF they get enough interest they will design one. So if any of you are interested in putting a deeper pan on your 3rd gen Taco shoot them and email. If we can get enough people showing interest I'm sure they will design one..
    Take care all.
    DAS Taco and Skydvrr like this.
  2. Sep 7, 2020 at 7:08 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Was it yourcovers.com?
  3. Sep 7, 2020 at 7:12 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  4. Sep 7, 2020 at 7:22 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    You might hit up OVTune in the twin turbo thread. I think he has a custom pan option for extra cooling support for his high boost turbo kits. My guess is it won’t be cheap though.
  5. Sep 7, 2020 at 7:25 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Isn't that engine oil?
  6. Sep 7, 2020 at 7:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I doubt theres a deep trans pan for a 3rd gen ,but I know Pizza hut has deep pan pizzas
    specter208 and Grossomotto like this.
  7. Sep 7, 2020 at 7:28 AM
    Bishop84
    Bishop84 Well-Known Member
    You put your wife in the trailer??
    Junkhead, sbx22, Vbpiper and 2 others like this.
  8. Sep 7, 2020 at 7:30 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Savage
    Junkhead, Vbpiper and DWD484 like this.
  9. Sep 7, 2020 at 7:31 AM
    RushT
    North Texas
    Doh! Yah, I’m all confused with it being Monday morning and me not at work. LOL.
    Skydvrr[QUOTED] likes this.
  10. Sep 7, 2020 at 7:33 AM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    You don't need a deep pan, or pinning the thermostat - that doesn't add cooling capacity but rather increases the thermal buffer. The best option is to actually increase the cooling capacity. Upgrade the tiny factory auxiliary air cooler with a larger cooler, including a fan if you think you need it.
  11. Sep 7, 2020 at 7:40 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    please explain how that larger cooler works when the thermostat is closed and no fluid is moving through it? :confused:
  12. Sep 7, 2020 at 7:43 AM
    BillsSR5
    bill
    2014 SR5
    Scott4032 likes this.
  13. Sep 7, 2020 at 7:46 AM
    Bishop84
    The thermostats work. Pinning is actually detrimental to the operation, especially in winter time.
    specter208 likes this.
  14. Sep 7, 2020 at 7:48 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    BillsSR5 likes this.
  15. Sep 7, 2020 at 7:52 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    not if you live in a warm climate zone 1-3
    All that adding a larger cooler does is open and close the thermostat more often. The thermostat is going to close as soon as the fluid drops to ~195*F and won’t open again until hits ~205-210*F.
    with that being said you’ll never see temps lower than that while at operating temp. So unless you pin the thermostat you aren’t really going to cool the fluid sub-190*F and extend the life of the fluid.
    my trans fluid stays around 155-165*F even on the hottest days sitting in traffic. :cool:
    scotkw likes this.
  16. Sep 7, 2020 at 8:02 AM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    The transmission thermostat either directs warmed / bypassed engine coolant to heat the transmission or once warm it directs fluid to the main radiator and then to the aux air cooler. All pining the thermostat does is force the use of the cooling loop, it still uses the same loop with the exact same cooling capacity. While that may lower temps at light engine loads it does nothing for when you need it, climbing a hill with an unlocked torque converter. When you start a long hill, while the fluid temp may be lower to start, with the same cooling capacity it will quickly heat up to the same temperature as if you didn't have it pinned. All that did was create a very small thermal buffer. Deep pans are the same, extra fluid provides more thermal mass but the cooling capacity remains the same. It will still heat up on a long hill just the same.
    A better cooler will increase cooling capacity. Add enough capacity and the thermostat can use the extra cooling to maintain the fluid temperature at the same temperature on a long hill as it does on the flats.
    Scott4032, hiPSI and RushT like this.
  17. Sep 7, 2020 at 8:05 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Because Of course the design engineers have no idea what they’re doing and just picked an arbitrary value for the thermostat with no thought behind it.
    Stocklocker and Vbpiper like this.
  18. Sep 7, 2020 at 8:13 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    the same engineers who claim WF is “lifetime fluid” lol ok
    heat kills transmissions and lessens the life of transmission fluid, period. There is no getting around that. The transmissions in these trucks already have enough problems (supposedly).
    jetfishn likes this.
  19. Sep 7, 2020 at 8:17 AM
    tirediron
    Not going to argue on the “lifetime oil” but I bet that’s more the marketing folks than the engineers. Your right, heat can be detrimental, but so can cold. How would your engine do if you kept it 30 degrees below operating temp?
  20. Sep 7, 2020 at 8:20 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I agree with you, but it also doesn’t solve the problem of getting the trans temp below the set point of the thermostat during normal driving.
    if you start with cooler fluid before making a long ascent, then the temperature delta is much higher than it otherwise would be, no? Start with 160* fluid, end up at 210* at the peak of the hill, once you are back on flat ground the temp can get back down to 160*. So you have a 50* delta, where you would otherwise have a 15* delta with a pinned tstat.
    engineer-splain all you want, but in real world applications the lower the temp (to a certain degree) the better. I understand these trucks have better technology and components than a TH400 from 1968, but I still want to keep my trans as cool as possible to get a longer life out of it.
    I live in climate zone three, so even the coldest days (32-34*) I still see 150*F pan temp at operating temp. That’s with the factory cooler.
