3rd Gen fuses
Discussion in '3rd Gen. Tacomas (2016+)' started by RedAlertCA, Jul 16, 2017.
  1. Jul 16, 2017 at 4:24 PM
    RedAlertCA
    RedAlertCA [OP] I like her a little dirty.
    Rob
    Sonora CA
    2016 DCLB Off Road - The most maligned Tacoma ever!
    Rockford Fosgate all around AllPro Differential/Exhaust Skid AllPro Apex Sliders
    As a younger man I had to replace fuses in various vehicles from time to time and so always carried spares.
    No vehicle I have owned since 2004 has ever blown a fuse.
    I found some info on older Tacos blowing fuses but not about 3rd gens.
    Obviously carrying spare fuses is cheap insurance, especially considering how far from "civilization" I get with my Taco. But it appears there are about 217 different types of fuses now.
    Ever blown a fuse in your 3rd gen? What fuses are the most critical to carry? Or do I just break down and buy one of each?
    Thanks for your advice.
  2. Jul 16, 2017 at 4:30 PM
    9TRDTCO
    9TRDTCO Well-Known Member
  3. Jul 16, 2017 at 9:57 PM
    RedAlertCA
    Rob
    Sonora CA
    Thanks for that. Anyone else?
  4. Jul 17, 2017 at 6:27 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    I purchased a slightly larger kit with ATM-LP, maxi and the larger type which are female maxi fusible links IIRC. It is irritating that there are so many types in the vehicle. I carry them the same reason you do. If I am way out away from civilization I want to at least be able to jury rig something.
    I don't have every single amp rating but I have a good assortment. I also carry butt connectors and wire strippers on long trips just in case I need to fix a broken wire or short to ground. With modern vehicles it is probably a good idea to learn and get comfortable with basic electrical diagnostic techniques.
  5. Jul 17, 2017 at 6:31 AM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    So I bought a packet of the mini fuses for under the dash when I added my add a fuse for my LED light bar switches. The mini fuses are a different animal than the ones that came stock with the truck. The blades on the packet from the parts store were wider than stock. I guess not all mini fuses are the same.
  6. Jul 17, 2017 at 7:09 AM
    RedAlertCA
    Rob
    Sonora CA
    Thanks for the info.
  7. Jul 18, 2017 at 12:53 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    I have the micros in my garage, but do not stock them in the truck. If something essential blows a fuse, figure I can borrow one from a non-essential system to get me moving again.
    Tacoma3rdGen and RedAlertCA [OP] like this.
  8. Jul 18, 2017 at 2:14 PM
    Hoangde
    Hoangde Well-Known Member
    Tibetan Nomad, Boghog1 and daohaus like this.
  9. Jul 19, 2017 at 10:44 AM
    tallpilot
    David
    Florida
    Not a bad idea, those fuses are junk though. I would use one to get home in an emergency but swap it out with a Bussman when I got there. I like made in Japan fuses and relays. China is garbage.
  10. Feb 18, 2019 at 5:29 AM
    Burritoma
    Burritoma Well-Known Member
    Deep South
    2019 Quicksand SR5 V6 DCSB
    Can anyone recommend a kit with at least one quality replacement fuse for every factory fuse in a 3rd gen Tacoma?
    Thanks!
  11. Feb 18, 2019 at 6:07 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Had my gen2 for 10 years. Bought it with 15 miles on it and ran it to 117k. Never once blew a fuse. That being said, I grew up much the same. I have a small wrench and socket set with other basic tools. I also carry a small pack of of each sized fuse, the style you can pick up at your basic auto parts store. $10-$12 is cheap and good insurance. I’d rather do that then break down in an overly rural area or during sub zero weather.
  12. Feb 18, 2019 at 6:09 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Go to your favorite auto parts store and get a pack of large and a pack of small fuses. As long as you get them there you shouldn’t have to worry about brand.
  13. Feb 18, 2019 at 7:52 AM
    tallpilot
    David
    Florida
    The truck is mostly mini fuses but there may also be low profile mini fuses. It's been a while since I checked.
    Like much of the automotive aftermarket there is a deluge of cheap parts. I like Bussman which are usually made in Japan. The good ones cost at least double the crappy ones but I think it is foolish to replace quality with junk to save a few pennies.
    Finding a large Bussman assortment will be difficult and expensive since they are marketed for repair shops. Something like this is a decent place to start. If you want more of a specific rating buy a 5 pack at NAPA.
    https://www.google.com/aclk?sa=L&ai...t=&hvlocphy=9053049&hvtargid=pla-608461441895
  14. Feb 18, 2019 at 8:56 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    If you’re using good quality fuses, and it blows for no apparent reason, doesn’t that failure suggest something else is at issue vs the fuse “just blowing”? I also grew up with the occasional fuse blowing event, and carried spares in the glove box. However, in those days (like most 16 year olds just starting to drive) I did full tuneups myself, including adjusting timing with a screwdriver and timing light... today’s vehicles are totally different and full of advanced technology.
    IDK, maybe it’s my flight training/profession... if a circuit breaker “pops”, we don’t just reset it without considering why it blew. I just carry that physiology over to my personal vehicles... just a thought.
  15. Feb 18, 2019 at 9:00 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    If you blow a fuse your first thought probably shouldn't be to swap in a new one right away. Best to figure out what the problem is first.
    There's a couple spares under the hood, and if you're in a bind on the side of the road you can always take a fuse out of a non-critical system to put in the blown fuse circuit.
    Tibetan Nomad, Sgt.Tee and Racerchoi like this.
