3rd Gen JBL Full System Upgrade w/ Factory HU
Discussion in 'Audio & Video' started by jerzsubbie, Apr 20, 2019.
  1. Oct 31, 2019 at 8:06 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I was thinking component 6x9 with 30-40w rms would be OK, or sound deadening for doors and different tweeters up top. It's not something I am in a rush to do though.
  2. Nov 3, 2019 at 4:03 PM
    xporkxpiex
    xporkxpiex New Member
    2016 Tacoma Limited
    Dam well I might have to just get an aftermarket stereo
  3. Nov 16, 2019 at 5:44 AM
    Captain_Slow
    Captain_Slow Well-Known Member
    I've been kicking around in threads on this subject for a couple of weeks, and I have to admit i'm lost. I'm not usually the type to go full on speakers, amp, all the doodads, new sub, etc. I generally just get the tech package on any new vehicle and swap out the mids if they aren't up to par. It sounds like there is a lot of conflicting reports on whether that's an upgrade (yes, I understand the best speakers in the world aren't going to shine without proper power, but they're usually just better even on factory power) or even a downgrade (something with the JBL amp being tuned specifically on the factory speakers, and it being hit or miss on whether a set of speakers will play well?).
    In any case, I generally defer to the experts. I have yet to find a list of speakers that folks have done direct swaps without changing anything else that they consider to enhance the sound over factory. Mind you, I don't have a volume issue, I just would like better quality sound, which up to now has been a pretty simple thing to get with better quality speakers.
    AU DIGG3R likes this.
  4. Nov 16, 2019 at 7:48 AM
    Hooper89
    I don't see why you can't swap out the JBL speakers as long as you get replacements with appropriate wattage and wire them up correctly.
  5. Nov 20, 2019 at 10:34 AM
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    you can swap the stock jbl speakers and see a gain in sound quality and clarity. It’s been done plenty. I did it over a year ago plus added sound deadener... Frankly the sound deadener helps tremendously. I’ve since gone back and covered the back wall, sub box and rear floor in noico deadener.
    https://www.tacomaworld.com/threads/jbl-system-with-after-market-speakers.600862/#post-20202620
  6. Nov 20, 2019 at 12:05 PM
    Hooper89
    I'd be interested in how you wired stuff up, the speakers I was looking at are called fosgate primes and then maybe JBL tweeters up top with some sort of adapter. The fronts seem to have a factory crossover that's one thing that made me wonder if components might be better.
  7. Jan 13, 2020 at 2:37 PM
    CyberJock13
    CyberJock13 Active Member
    BSly (916)
    Sacto, California
    2016 Black TRD 4x4 Sport
    275/70/18s, Fuel rims, OEM Audio+ with sub, Meso,
    So looking back, is there anything you can edit/change at the top of your "things bought", I want to mimic your purchases and install..no need to re-invent the wheel here
  8. Jan 15, 2022 at 9:41 AM
    captainvfr
    captainvfr Member
    2020 Limited Cement
    Does anyone have a clear recommendation on upgrading the amp and or sub to improve loudness in my 2020 Limited with JBL. I have already upgraded the speakers w/2ohm JBL tweeters and Powerbass door speakers. Sound is better. Just not loud enough.
  9. Jul 20, 2022 at 3:11 PM
    AltezzaTaco
    AltezzaTaco Master Debator
    Detroit, MI
    2022 Lunar Rock TRD OR
    Thanks for this post, i couldn't find any info in search that retained the factory headunit. Going to attempt this on my 2022.
  10. Jul 20, 2022 at 5:19 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Change the head unit
    You could even do a Sony high power unit. New speakers and a sub with a amp and it will blow away the jbl system . Check out the units on Extreme Terrain website . They have prewired bundles that are plug and play
  11. Jan 20, 2023 at 7:13 AM
    Doolsmack_Bud
    Doolsmack_Bud Well-Known Member
    USA
    2023 Lunar Rock TRD OR 4x4 w/Advanced Tech Package
    ATHFab Bed Stiffeners OGFabrications MOLLE command center panels ARE Overland Bed Cap
    Is there any way to just relocated the factory JBL stuff and free up the storage space? I really want to put in a lockerdown long gun box behind the rear seats and would need to relocate the JBL system in order to do it.
  12. Jan 20, 2023 at 7:17 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    It might take a lot of wire extensions, but you can try mounting the amp under one seat, and a sub box under another :notsure:
    soundman98 likes this.
  13. Jan 20, 2023 at 7:31 AM
    Doolsmack_Bud
    USA
    I'm fine with that. I assume i'd have to make the extensions myself? And possibly the sub box?
  14. Jan 22, 2023 at 7:08 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    sub isn't going to fit anywhere else. you could try some ultra-custom stuff and adapt an 'underseat' sub to the factory sub output(bypassing most's internal amp), but there's significant risk it won't work anywhere near as well, but you won't know 'till it's all over.
  15. Jan 22, 2023 at 8:41 AM
    #35
    RyanDCLB
    4/19 DCLBOR
    @Doolsmack_Bud
    Check out what @Guccitaco did over Here & here :thumbsup:
    soundman98[QUOTED] likes this.
