3rd Gen Maintenance Maps - Get 300k+ miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soft Taco, Jan 14, 2023.
  1. Jan 15, 2023 at 5:44 AM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I never reach those mileages- have to go by time. Maybe add time to the x axis? Very nice.
    mquibble likes this.
  2. Jan 15, 2023 at 6:55 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Let's see it
  3. Jan 15, 2023 at 6:57 AM
    shotgunbilly420
    Maybe make one for us high mileage guys . Make it to 250k mi. I'm at 188k mi on my 2017
    ExplorHer, Road_Warrior and rainsux like this.
  4. Jan 15, 2023 at 7:57 AM
    Soft Taco
    Soft Taco [OP] Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
    In order to prevent it from getting too big I left it out. There’s multiple tools as you know involved with each of these that deserve mention. All those little images are from the video series I made covering all these tasks. I’ll DM you the link! And thank you for the words!
  5. Jan 15, 2023 at 8:02 AM
    Soft Taco
    Tyler
    I’ll tell ya, spark plugs are the only “difficult” item in that list in my opinion. But even then, not that bad. Most of this to me is therapeutic ha
    Ponch1776, TexasWhiteIce and mquibble like this.
  6. Jan 15, 2023 at 8:18 AM
    Soft Taco
    Tyler
    Check the note on the right. It is generalized but should cover the Sunday driver needs.
    Most of these jobs are cyclic and continue at normal intervals. A deviation from that would be coolant recommendation to change at 50k intervals after the first 100k. Add: the shape pattern for the 100k to 200k etc would be super similar. Not exact, but not worth recreating ya know?
  7. Jan 15, 2023 at 8:49 AM
    Avanchent
    Avanchent Well-Known Member
    Longmont CO
    2017 TRD Sport MGM DCSB
    Should I be concerned that I'm at 52k on my 2017 and all I've done is oil and filter every 5k and air filters when needed? Still on original brake pads and all the fluids are original. I guess 60k is looking like I should just about change all the fluids...
    mrbetelman and Ponch1776 like this.
  8. Jan 15, 2023 at 8:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    nice work, thanks!
    Sticky req.
    Soft Taco[OP] likes this.
  9. Jan 15, 2023 at 8:59 AM
    Soft Taco
    Tyler
    Not really a reason for massive concern and congrats on doing more than most! You are in the gray area where fluids like transfer case, diffs, and transmission are maturing based on age to the point where you should consider swapping out. If I were you I would swap them to ensure the long life of the truck. With that said, as long as you aren't crossing water every time you leave the pavement you are relatively safe. If the color green is "new" and red is "change now" you are a nice yellow ha. As for brakes, they are not hard at all on the front and time-consuming but not hard on the rear. You probably don't need rear brake shoes at 52k but definitely check.
  10. Jan 15, 2023 at 9:10 AM
    Avanchent
    Longmont CO
    I planned on the diffs and trans at 60k anyway, I checked all the brake pads and shoes at 50k and I'm surprised by how thick they still are. My truck has been babied though, and the only reason I didn't change things sooner is because I was considering a Tundra when the used market was so hot, but it looks like those trucks have a lot of improving to do yet.
    bulalo likes this.
  11. Jan 15, 2023 at 9:18 AM
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Diggin the chart!
    Im on the road to 90k. :(
  12. Jan 15, 2023 at 9:30 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    If this is designed to mirror the "official" maintenance schedule, it looks great! I wonder if it should also include a "TW recommended interval for most trucks." For example, changing the oil every 5-7000 miles is likely ideal in most circumstances. Consensus is generally that 10k is pushing it for most trucks. Also, I'd bet some people are paying attention to their transmission fluid a bit before 60k. Curious what others think here.
  13. Jan 15, 2023 at 9:36 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    This is cool. I've been meaning to make something like this for myself but just never got around to it.
    I'll probably copy a bit of it and then convert it to metric.
  14. Jan 15, 2023 at 9:43 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    The chart awesome man, good stuff.
  15. Jan 15, 2023 at 9:52 AM
    #35
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Nicely done OP. This chart is off the charts (pun intended :D) and I will be saving it to my service folder. Can you shoot me the link to your how to videos?
  16. Jan 15, 2023 at 9:55 AM
    #36
    Soft Taco
    Tyler
    Worth noting on oil change intervals for sure. I’m a 5k guy and also change at severe numbers generally. That charts next round of updates will squeeze various smaller font notes in the bottom without it getting too bulky.
  17. Jan 15, 2023 at 9:55 AM
    #37
    Soft Taco
    Tyler
    Thanks! DMing now.
  18. Jan 15, 2023 at 10:24 AM
    #38
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Awesome. Might be a sticky material .
  19. Jan 15, 2023 at 10:34 AM
    #39
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Great stuff! You might consider adding a version number just in case you update it, so we know which version we have.
    Also, a PDF printable 11x17 would be super useful. That, and adding hyper-links for parts, youtube how-to videos, etc. :notsure::thumbsup:
  20. Jan 15, 2023 at 10:42 AM
    #40
    Soft Taco
    Tyler
    I’ll do you one better and make a version on a white background to be printer friendly as well. All great info!
