3rd Gen Maintenance Maps - Get 300k+ miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soft Taco, Jan 14, 2023.
  1. Jun 19, 2024 at 6:54 PM
    #461
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    No clue. I don't pop their hoods. :notsure:
  2. Jul 24, 2024 at 1:25 PM
    #462
    mazz
    mazz Member
    @Soft Taco First off, thanks for all this (especially the one for the 2.7L!!) and thanks for your videos.
    My 2016 2.7L 4WD Tacoma is coming up on 60k miles. I've always had a shop do my maintenance, but the prices are getting crazy now so I'm off researching to learn how to do most everything myself now. Team Oil Drop videos are awesome (even though they show the 3.5L).
    Anyway, after going through the service manual (that I also got from another Tacomaworld thread), I wrote down pages of notes and want to print out your 2.7L pdf as a summary. I compared it with my notes from the service manual and found some differences. Can you confirm what is and is not correct? I am not a mechanic, so if I mis-read the service manual, let me know... I do give the service manual page numbers and section titles for reference for where I get my info:
    1. Spark Plugs - your PDF shows part # DENSO SK20HR-A11 ... I show DENSO FK20HR-A8 (page 5988 under section "2TR-FE IGNITION: IGNITION SYSTEM: ON-VEHICLE INSPECTION")
    2. Front Diff Fluid drain plug torque - your PDF shows 48 ft-lbs. ... I show 29 ft-lbs (page 2143 under section "DIFFERENTIAL: DIFFERENTIAL OIL: ADJUSTMENT"). Here's what the manual says (looks like its saying for both drain and fill plugs, the torques are the same for front (29 ft.lbs) and same for the back (36 ft.lbs) ??):
    Torque:
    Front differential carrier assembly -
    39 N·m {398 kgf·cm, 29ft·lbf}
    Rear differential carrier assembly -
    49 N·m {500 kgf·cm, 36ft·lbf}
    3. Engine Oil drain plug torque - your PDF shows 30 ft-lbs ... I show 28 ft-lbs. (page 5996 under section "2TR-FE LUBRICATION: OIL AND OIL FILTER: REPLACEMENT")
    CrashZone likes this.
  3. Jul 24, 2024 at 5:16 PM
    #463
    Soft Taco
    Soft Taco [OP] Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
    Hey, I love the attention to detail!
    1. 2015 the 2TR-FE was using the SK20, 2016 Toyota did switch to to the FK20. I should annotate this on the tracker.
    2 & 3 - I’ll dive in next time in front of a computer.
    The note needing added for 1 warrants a version change of the tracker regardless. Appreciate the help!
    ToyoTRD21, Chew and TartanEagle like this.
  4. Jul 25, 2024 at 2:14 PM
    #464
    Epitoma-rei-militaris
    Epitoma-rei-militaris Member
    2022 mgm Tacoma SR5 DCSB 4x4
    SoftTopper, 255/85R16s
    Random autistic side note but a TOD grill emblem vinyl cover or some such would be kinda baller.
    Soft Taco[OP] likes this.
  5. Jul 25, 2024 at 6:39 PM
    #465
    Soft Taco
    Tyler
    Ayyy lol. We got things similar in the channel shop but no straight-up grill jewelry (yet)
  6. Aug 1, 2024 at 9:27 AM
    #466
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  7. Oct 16, 2024 at 6:57 PM
    #467
    Ngneer
    Ngneer Well-Known Member
    And again very nice
  8. Oct 17, 2024 at 2:24 PM
    #468
    Soft Taco
    Tyler
    Thanks yall, it’s been a pleasure
    Painter99 likes this.
  9. Dec 15, 2024 at 6:54 PM
    #469
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    We could use one for the current generation RAV4. Seriously.
    That said I haven't looked at this thread in close to a year. It's evolved quite nicely. I need to print it out as my 2019 is a few thousand away from 100,000 miles.
  10. Jan 6, 2025 at 8:24 PM
    #470
    TRD_dee151
    TRD_dee151 Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    Question I am at 12,184 miles Only and I don't do any off roading so should I change my front & rear diff at (15k service ) or wait to ( 30k routine ) ? what's the difference ? my Tacoma is a pavement princes .....
  11. Jan 7, 2025 at 7:02 AM
    #471
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    The red circles apply to 'Severe' use only.
    As a self-identified pavement princess, and the fact that you have tint and a TRD Pro grille listed in your avatar, you have zero to worry about at 15,000 miles when it comes to the F&R diff fluid.
  12. Jan 7, 2025 at 8:46 AM
    #472
    TRD_dee151
    Oregon
    OK cool then when I hit 30k I can do my first diff change right....
    Soft Taco[OP] and Brownie_Man like this.
  13. Jan 8, 2025 at 4:05 PM
    #473
    Soft Taco
    Tyler
    Si, even I don't follow "severes" except of course for engine oil. I actually just pushed out another map that eliminated severe intervals and remedied the 10k oil change issue.
    Mrcooperou812 and DSRamsey13 like this.
  14. Jan 8, 2025 at 8:00 PM
    #474
    TRD_dee151
    Oregon
    I see that 40$ map with frame, I need that in Celestial silver ......
  15. Jan 27, 2025 at 6:57 AM
    #475
    InfernoAlt
    InfernoAlt Well-Known Member
    New York
    Just hit 50k miles but I went on at least 6 off road trips last year. Anything additional I need to do for 50k service?
    I probably have a bad thermostat and I think the engine burns a little rich
  16. Mar 5, 2025 at 6:31 PM
    #476
    m0d4h5
    m0d4h5 Well-Known Member
    New to me 2023 Tacoma v6 base
    Thanks for this Tyler. I’m new to the Tacoma gang and look forward to learning how to take care of my own truck. Hoping I can get to 2-3 billion kms.
    Soft Taco[QUOTED][OP] likes this.
  17. Mar 8, 2025 at 3:43 AM
    #477
    Soft Taco
    Tyler
    Welcome to the club! Those are rookie numbers.
    TartanEagle likes this.
  18. Apr 1, 2025 at 10:08 AM
    #478
    jlhoang
    jlhoang Member
    2023 Lunar Rock Tacoma TRD OR DCLB
    Thank you for the time and effort on this Tyler! The free maintenance that came with my taco is going to end soon and I plan on doing future maintenance myself, so this maintenance map helps a ton.
  19. Apr 5, 2025 at 2:44 AM
    #479
    Soft Taco
    Tyler
    Hey my pleasure!
  20. Apr 20, 2025 at 10:37 AM
    #480
    bryannn
    bryannn Active Member
    These maintenance maps are great. The videos are even more impressive. I appreciate that they are no frills and cut right to the chase.
    I just did my 30k service and it went pretty smooth. Luckily I didn't have any issues with the front diff drain plug but it did require some penetrating spray and a little bit of ooga dooga to break it loose. I had more issues with the rear diff drain and fill plugs. They were on there solid and I pulled out a breaker bar after a few failed attempts. I didn't drop the spare or have to use a fill hose for the front. I found some valvoline gear oil but they packaged it in these "flex fill" containers. They're kind of great. It allowed me to bend the nipple and squeeze the bag to push fluid into the diff. I'd recommend it just for ease of use.
