3rd Gen Maintenance Maps - Get 300k+ miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soft Taco, Jan 14, 2023.
  1. Jan 30, 2023 at 5:41 PM
    #81
    PaToy
    PaToy Active Member
    Bucks County Pa
    2019 TRD Sport
    Awesome..... Thank you
    Soft Taco[OP] likes this.
  2. Jan 30, 2023 at 5:53 PM
    #82
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Stick-e-worthy!
    Soft Taco[OP] and skippyscage like this.
  3. Jan 30, 2023 at 6:05 PM
    #83
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    This is very nice. Not that I plan to do my own maintenance, but I can use it as a reference for service intervals without having to dig into the manual.
    Definitely going to print it out.
  4. Jan 30, 2023 at 6:12 PM
    #84
    skippyscage
    skippyscage Well-Known Member
    2023 Tacoma TRD Off Road
    very much so!
  5. Jan 30, 2023 at 6:38 PM
    #85
    Soft Taco
    Soft Taco [OP] Team Oil Drop
    Tyler
    Colorado Springs, CO
    2016 4WD Auto DCLB TRD Sport
    Thanks y’all. 100k to 300k not too far away. Maybe even by this weekend.
    rainsux likes this.
  6. Jan 30, 2023 at 6:40 PM
    #86
    Soft Taco
    Tyler
    This is always my fav thing to hear, my project is hanging somewhere helping somebody :cheers: I use mine all the time
    BadDogMax and HisDad like this.
  7. Jan 30, 2023 at 6:51 PM
    #87
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Nice! Thanks, @tcBob, for the sticky!
  8. Jan 31, 2023 at 9:57 AM
    #88
    Soft Taco
    Tyler
    Updated
    Version 1.1
    • Fixed error listing power steering fluid on map at 40k
    • Fixed error not showing severe interval of transmission fluid at 60k on map
    • Added black frame behind yellow text on printer-friendly version
    • Added 11x17 printer-friendly option
  9. Jan 31, 2023 at 10:41 AM
    #89
    HisDad
    Texas at last
    And maybe to show an over eager Service Writer now and then.
    Just sayin'.
  10. Jan 31, 2023 at 4:49 PM
    #90
    JerTaw
    JerTaw Well-Known Member
    Jeremy
    Seattle
    2021 TRD OR DCSB
    This is so cool, thanks man!
  11. Feb 1, 2023 at 4:08 AM
    #91
    nds0000
    nds0000 Well-Known Member
    Awesome work! Thanks!
    Could you please add the quantities of the fluids needed?
  12. Feb 1, 2023 at 6:48 AM
    #92
    Soft Taco
    Tyler
    I chose to leave them off because other than oil change, xfer case, and front diff, the quantities can fluctuate based on number of drain and fills or other factors. However, exact quantities are in the videos with deeper explanations that don’t really fit on the chart. Thanks for the words!
  13. Feb 1, 2023 at 1:46 PM
    #93
    HisDad
    Texas at last
    Off hand anyone have an idea of how much the front and rear differential fluid change goes for? I hardly ever use 4WD, so I don't know if I really need to do the front differential. Also, the transfer case fluid change price?
    I should probably ask the labor time since different dealers in different parts of the country will have different rates per hour.
  14. Feb 1, 2023 at 2:03 PM
    #94
    Soft Taco
    Tyler
    If memory serves me you should plan to pay between $250 and $300 for both diffs to be done (parts and labor) / approx $125-150 a each. You can DIY both for approximately $70 total depending on fluid cost at the time. It’s about the easiest task there is but be wary of how tight the front diff drain plug is if you choose to DIY. I stripped mine even after all precautions being taken. It’s a pretty normal thing. My front diff video will cover a better front drain plug to use as well.
    Transfer case is equally as easy and if using OEM fluid can be done for $50-80 depending on fluid cost at the time. Half that or less if you use an alternative fluid which I won’t speak on. A dealer should charge ballpark of $150+ for transfer case id assume but not be surprised if they want $200+.
    Both my local dealerships put conventional 75w - 90 in transfer case and diffs just to maximize their profit margins. Cheap bastards.
  15. Feb 2, 2023 at 8:11 AM
    #95
    Buhlockaye
    Buhlockaye Well-Known Member
    Montana
    2016 Tacoma
    Your typical overlander mods
    This is amazing! Definitely will be printing one out for the truck. Can't wait to see what the 100k+ map will look like!
  16. Feb 2, 2023 at 9:18 AM
    #96
    Soft Taco
    Tyler
    Might be done as soon as tonight!
  17. Feb 2, 2023 at 9:28 AM
    #97
    Carpedm
    Carpedm Well-Known Member
    Annapolis MD
    2023 Lunar Rock TRD Sport DC SB
    Cup Holder Mod, bed cover, and steps.
    This is awesome and very well done! I plan to print these as soon as I get home!
  18. Feb 2, 2023 at 10:02 AM
    #98
    HisDad
    Texas at last
    Thanks. I don't have the equipment or a garage to do my own maintenance, so the Tacoma still goes to the dealer. After 100K I might switch routine stuff to a garage near me.
    I'm pretty sure my dealer uses the Tacoma specified fluids, filters, and intervals, but it's nice to have a reference.
    They have a new Service Manager and I'm not totally sure about him. Last time I was there I had the transmission flush since there was about 65K on the truck. That was fine, but then he showed me three sheared off bolts on the front skid plate. He didn't have an answer when I asked how that could happen. I agreed to pay the hour labor rate, but I knew how it happened. I ended up calling his boss and having a chat. As a result I have an hour's labor credited to me.
    So, as in "Meet the Parents" he's a bit outside of my "Circle of Trust."
    Which is why I like having this handy reference.
  19. Feb 2, 2023 at 10:40 AM
    #99
    carsontheguy
    carsontheguy Member
    Carson
    South Lake Tahoe
    '22 DCRB OR
    --Exterior-- Some stupid KMC Wheels Even dummer (j/k) Toyo Open Country A/T III tires - whatever size Super Pacific Switchback X1 Camper Body armor 4x4 hiline bumper + Wings - 6" diode dynamics ambers - 20" Dual Row LED Light Bar with Black Bezel Prinsu cabrack - Cali-raised 42" light bar Winjet Automotive Tail light (black/smoke) --Under Hood-- Genesis Off Road duel battery - 2x Odyssey Extreme type 34 Auxbeam switch pannel --In Cab-- Garmin Dashcam 57 --In Bed-- Total Chaos Bed stiffeners Dometic CFX3 45 on DFG Offroad Slide mount GTFO Light Kit - HardKorr LED Lighting --Accessories-- Cascadia Hybrid Telescoping Ladder
  20. Feb 2, 2023 at 3:55 PM
    #100
    Soft Taco
    Tyler
    That right there is enough to make me not go back. I know there are a lot of honest mechanics out there, and dealerships tend to be dare I say, a bit more honest in the maintenance realm even… but these routine works are for the most part very simple. The most basic of tools gets the job done and I do all my work outside in my driveway. That’s just my thoughts. I’ll never knock anyone with money for having someone else do it either, that drives our economy! Best wishes - Tyler
