3rd Gen Maxtrac Spindles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SergeStorms, Feb 16, 2016.
  1. Dec 19, 2016 at 6:12 PM
    TacoTimmy7414
    TacoTimmy7414 Well-Known Member
    Sarasota, FL
    2016 Quicksand Tacoma TRD Sport
    Unfortunately no I don't remember. Sorry
    @IamJorgeEdward do your remember seeing it anywhere like when you were spraying them or something?
    285/70/17 grappler g2
  2. Dec 19, 2016 at 6:56 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    This might answer your question, haven't read the whole thing. Haha
    http://www.maxtracsuspension.com/about-us/
  3. Dec 19, 2016 at 6:59 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Thanks! They say everything they market is made here in Southern California locally.
  4. Dec 19, 2016 at 7:55 PM
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    Any dimensions, fender to hub?
    ChadsPride likes this.
  5. Dec 20, 2016 at 4:25 AM
    TacoTimmy7414
    Sarasota, FL
    Before was 21ish. After its about 25ish
  6. Dec 20, 2016 at 6:28 AM
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Looks good! I've been looking up some install videos on YouTube but they're all for 2nd gen. I'd imagine it's the same concept though. Do the spindles push the wheels out some? Or is it just the wheel specs?
  7. Dec 20, 2016 at 6:29 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Increases tract width by .75"
    TacoTimmy7414 and Leo4x2[QUOTED] like this.
  8. Dec 20, 2016 at 6:34 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Each side
  9. Dec 20, 2016 at 6:39 AM
    ChadsPride
    :amen:
    I am still learning here also!!! lol
  10. Dec 20, 2016 at 6:42 AM
    Leo4x2
    Leo
    San Antonio, Tx
    lol so I am running wheel spacers on my stock tss wheels. If I get the spindles, they'll be sticking out 2" right? So would it be best to get 2" wheels spacers for the back? or just get smaller front spacers?
  11. Dec 20, 2016 at 6:44 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Copied from Maxtrac's site
    SPECIFICATIONS
    WHEEL FITMENT:
    - 17" Minimum Wheel w/ 4.75" Max Backspacing or less
    - +0.75" Track Width increase per side
    - Will Clear up to a 33" tire with the correct wheel & tire combination.
    NOTE:
    - Prior to installation—measuring is required when selecting a wheel & tire combination.
    - Trimming may be required for optimal fender well clearance.
    - 6 Lug ONLY
    ChadsPride[QUOTED] likes this.
  12. Dec 20, 2016 at 6:44 AM
    ChadsPride
    what size spacers do you run currently??
    You could take em off the front and move them to the rear for matching offset
  13. Dec 20, 2016 at 6:45 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    If his wheel specs will work. Otherwise he'd need spacers.
  14. Dec 20, 2016 at 6:46 AM
    ChadsPride
    For sure - My Texas Edition wheels are working without spacers. But im not running a 285 tire....yet
  15. Dec 20, 2016 at 6:47 AM
    #35
    Leo4x2
    Leo
    San Antonio, Tx
    1.25" spacers all around
  16. Dec 20, 2016 at 6:48 AM
    #36
    Leo4x2
    Leo
    San Antonio, Tx
    My TX Edition wheels and 285s w/o spacers rubbed on UCA's and fender wells so spacers helped a lot.
  17. Dec 20, 2016 at 6:48 AM
    #37
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    If it's close now with 265's it may rub the spindle or uca with 285's. But you have new wheels coming so you have nothing to worry about. You got the same specs a mine & I have no clearance issues.
  18. Dec 20, 2016 at 6:49 AM
    #38
    ChadsPride
    :yes:
    SpruceTaco[QUOTED] likes this.
  19. Dec 20, 2016 at 6:50 AM
    #39
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I run 1.25 on the rear to even it out. You can try your wheel & tires without the spacer on the front, if it rubs put the spacer back on. The good thing is you already have them on hand.
    Ngneer and ChadsPride like this.
  20. Dec 20, 2016 at 7:02 AM
    #40
    Leo4x2
    Leo
    San Antonio, Tx
    True true. Thanks man!
