3rd Gen - Need a Leaf sag solution
Discussion in 'Suspension' started by CooleyOne, Apr 5, 2018.
  1. Apr 5, 2018 at 11:38 AM
    CooleyOne
    CooleyOne [OP] TRD OffRoad
    EastBay, NorCal
    2017 TRD OffRoad Taco
    2017 TRD OffRoad
    So, on my 2017 OffRoad, I've installed the 6" BDS Fox 2.5 kit. The stock rear leafs, however, are FLAT. There's zero concave and that doesn't seem normal. I'm measuring < 3" from the bump stop to the frame. Ideally, I would think that there should be a bit more room in there, for suspension travel, etc. Any one else seeing this on theirs? I mean it's flat, even maybe even slightly convex, curving down like the leafs are fatigued.
    To help get some of the natural concave back, I'm looking at AAL, Helper Springs and just new leaf packs. Insights welcome for others that may have addressed the world famous Taco Leafs.
  2. Apr 5, 2018 at 11:39 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Just go new leaf pack and never look back.
  3. Apr 5, 2018 at 11:46 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    That's normal. Even with the Dakar EL095r leaf pack they flattened out quite a bit. It wasn't until I added a leaf to the EL095r that gave it the convex shape. It's not hurting anything. TBH if your not planning on lifting leave it the way it is, you'll have a softer spring rate and a more comfortable ride.
  4. Apr 5, 2018 at 11:54 AM
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    I do have a lift, the 6" BDS mentioned. That includes 4" blocks on the rear.
  5. Apr 5, 2018 at 11:56 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I apologize, your achieving your lift by blocks, not by leaf pack. I would still leave the OEM leafs in there for the softer spring rate. Unless you plan on doing a lot of hauling or getting additional lift.
  6. Apr 5, 2018 at 12:00 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    I would go with a burlier leaf pack to minimize axle wrap and add lift, and then drop down to a 2" or 3" block to compensate.
  7. Apr 5, 2018 at 2:24 PM
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    Recommendations? OME? Others... Thx
  8. Apr 5, 2018 at 5:11 PM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    OME, deaver, All pro... those all make good springs for your application. The all pro standard pack will give you about 3" lift from stock if Im not mistaken, and without the harsh ride of the expedition leaf pack. Lots of guys run the Dakar pack from OME with the 3rd leaf removed for improved ride. Lots of threads to read on this! Search function is your friend!
  9. Apr 5, 2018 at 6:30 PM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    You can try giving these guys a call and see what they have to say.
    http://nationalspringinc.com/
