3rd gen needle bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bossman14, Sep 30, 2016.
  1. Oct 1, 2016 at 5:20 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    So I won't go into details too much. However, I'm an engineer at Ford, and I work on some projects that have expected aftermarket modification. It's pretty normal for the engineers to design for certain modifications in mind, including lift/lowering, wheels/tires, etc., just depends on the specific platform. I honestly have zero idea how all of these drivetrain vibration problems made it through the Tacoma development cycle. We routinely deal with NVH issues, hood flutter, and all these other things that seem to have plagued the Tacoma platform since day one. Every OEM deals with these things, and then they work on countermeasures to eliminate or minimize the issues. However, Toyota doesn't seem fit to design it out of the Tacoma. These aren't new problems to the 3rd gen, they've been there forever. It's still a great truck, but it definitely has it's character flaws.
  2. Oct 1, 2016 at 5:22 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Awesome post! Thanks for the info share. I'm a bit baffled too. I'm thinking this truck was rushed to market.
  3. Oct 1, 2016 at 6:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    So, fluid movement in the transfer case?
    In your opinion, what's a little?
    This is OP's video.
    One quart of transfer fluid has enough ass to make it move like that?
  4. Oct 2, 2016 at 3:32 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    That's about normal.
  5. Oct 2, 2016 at 4:34 AM
    SC_Titan
    SC_Titan Active Member
    2016 DCLB TRD Sport
    Lifted my 2016 1600 miles ago. Used 4wd briefly yesterday and got the cyclical growl 50 miles later. 887/5100 and HS 3 leaf. No diff drop.
    Guessing dealer won't help with the lift on there? What's my next move. Truck has 3500 miles on it.
  6. Oct 2, 2016 at 4:38 AM
    Aussiek2000
    2016 Offroad AC
    Put mud tires on.You wont hear it any more
    stealthmode likes this.
  7. Oct 2, 2016 at 4:41 AM
    SC_Titan
    2016 DCLB TRD Sport
    Ko2s on it. Mud tire days are over.
  8. Oct 2, 2016 at 4:54 AM
    SC_Titan
    2016 DCLB TRD Sport
    No noise in 4wd. Assuming it's needle bearing is it okay to drive on?
  9. Oct 2, 2016 at 12:40 PM
    Bossman14
    Bossman14 [OP] Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    From what I've read it's ok to drive on.
  10. Oct 2, 2016 at 1:24 PM
    SC_Titan
    2016 DCLB TRD Sport
    Think I'm going to let the dealer check it out tomorrow before I start throwing parts at it.
    Bossman. When will you have diff drop installed? Surely between the ECGS and the DD, it will fix it. I can't live with this on a brand new truck!
  11. Oct 2, 2016 at 3:36 PM
    Bossman14
    Stock
    I ordered it yesterday so I will put it on some time this week I will let you know how it works out.
  12. Feb 20, 2018 at 7:12 PM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Hi its 2018 any update
  13. Feb 21, 2018 at 9:02 AM
    Bossman14
    Stock
    lol I put in the diff drop and it did nothing so I took it out, I have also put in the east coast bushing and it helped a bit (made it less noticeable) but it's still there, so I just zip tie the front driveline and the noise completely goes away. The only real fix is to replace the carrier and super gears with aftermarket.
  14. Feb 21, 2018 at 9:04 AM
    Chipi3s
    San Diego
    Yeah thats what i have gathered from watching a vid ecg posted. Or if your one of the lucky ones you never get the sound
  15. Apr 23, 2018 at 11:34 AM
    #35
    kksrunner
    kksrunner Well-Known Member
    Whit
    Havelock
    2018 tacoma TRDOR and 2014 4runner
    5th gen T4R -3" toytec -285 trails -18" XD Grenades -Total Chaos UCA 2018 TRDOR Front: 2.5” bilstein/OME, Total Chaos UCA, driver side shim Rear: 2” Toytec Boss shocks and AAL 285/70R17 trail grapplers 17” XD grenades Spidertrax spacers
    How do you zip tie the front driveshaft? Just do that so it doesnt spin?
  16. Apr 23, 2018 at 11:59 AM
    #36
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    I have a diff drop and just had the ECGS bushing put it. The bushing seems to have solved it 80-90%, but it is still there.
    I think I may remove my diff drop as well - how hard is this to do?
    Can you explain what you did with the zip ties?
  17. Apr 23, 2018 at 7:55 PM
    #37
    Bossman14
    Stock
    The diff drop is easy to remove, just a few bolts, I zip tie the driveline through the front yoke to the frame it takes long zip tie or a few lines together, I do this to eliminate the spin of the drive shaft which stops the spiking of the spider gears. And when you put it in to 4 wheel drive the zip tie break right off, pretty nice actually. What people fail to realize is the needle beating is not the issue, the spider gears in the carrier are the real cause, such loose tolerance from the manufacture.
    kksrunner and drewhaus like this.
  18. Apr 23, 2018 at 7:58 PM
    #38
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Worked for mine
  19. Jul 7, 2018 at 6:08 PM
    #39
    dagsamp
    dagsamp Unknown Member
    Marla
    16' TRDOR DCSB OV Tune
    OV Tune
    Any chance the spider gears got damaged when you installed the ECGS? From either using their tool or setting the bushing to deep? I saw that the bushing is slightly longer than the needle bearing
  20. Apr 8, 2020 at 4:19 PM
    #40
    PerRunner_Taco2wd
    PerRunner_Taco2wd Member
    Joseph
    2013 white Tacoma
    Stock
    Question do you need to add the needle bearing when adding 3' lift. I'v been hearing about this alot and im confused. wondering if someone can help me out on this.
