3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Apr 28, 2017 at 4:38 AM
    #2201
    Harley08
    Harley08 Active Member
    Southern MD
    2017 Inferno Tacoma TRD OR
    20% Tint, 5" Oval Tube Step, Tri Fold Bed Cover
    Taco is getting a new diff today due to the howling noise. Hope I have no more issues but only time will tell.
    shakerhood likes this.
  2. Apr 28, 2017 at 8:42 AM
    #2202
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    In all seriousness, could this diff bolt recall potentially be a source of the howl? I know that so far, the TRD OR (which is most definitely howling too) is not recalled, but hear me out.
    Everyone so far has been speculating that it's the ring & pinion that are howling. Could it maybe potentially be that the side gears / spider gears are getting loaded because the diff bolts are soft & stretching, allowing the axles to apply a load?
    My understanding is that side gear noise because of axle misalignment WOULD go away under load & would only be during "feathering" , plus this would explain why replaced diffs started to howl again, if the stretched studs were not replaced.
    Is it really that easy? Have we just been looking at the wrong gears this whole time?? I'm a noob at diff setup / drivetrain diagnosis though, anyone care to comment?
  3. Apr 28, 2017 at 9:14 AM
    #2203
    DontPanic
    DontPanic Well-Known Member
    VA
    It is not that easy. The recall is for under-torqued fastners which can in some cases cause a leak of fluid resulting in a dry diff. The pinion howl is a completely different issue but both point toward lapses in QC.
  4. Apr 28, 2017 at 9:19 AM
    #2204
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    In that email thread that was posted yesterday or it might have been on the Recall itself, it said something along the lines of more future resolutions coming, maybe that will address the howling.
  5. Apr 28, 2017 at 9:21 AM
    #2205
    Nitori
    Maricopa AZ
    2021 T4R SR5
    The recall states to check the fasteners, but the speculation (based on snapping studs that a number of members have experienced) is that it is not because of under-torque (read what smitty posted again, note that it does not say under-torqued anywhere, and when a leak is found, all fasteners are replaced.) Basically the bolts are thought to be stretching because of improper heat treat, not under-tightened from the factory.
    Hence why I'm saying maybe it's NOT a different issue.
  6. Apr 28, 2017 at 9:32 AM
    #2206
    DontPanic
    VA
    Almost right: the vehicles with no leak just get re-torqued. If leaking the gasket gets replaced and in that case one gets new fasteners.
    At any rate - very unlikely this condition would result in pinion howl.
  7. Apr 28, 2017 at 9:42 AM
    #2207
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Correct
    specter208 likes this.
  8. Apr 28, 2017 at 9:45 AM
    #2208
    ToyoMann
    I think there are 2 issues here. First off, your logic is good, and the leak could lead to all the other mess. However, I know of 2 Tacomas with howls; that never leaked and have the right fluid levels of Toyota lube.
  9. Apr 28, 2017 at 9:59 AM
    #2209
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Are there any videos showing this howl? Haven't kept up with this thread...
    I'm at 24300km on my TRD Sport and started hearing something recently. Might be a howl, might not be. Seems like it's coming from the front, though. And it's more audible with the windows rolled up than rolled down... go figure. I did hear it last night at around 50mph with coasting or feathering of the throttle, so that much lined up with the diff howl.
  10. Apr 28, 2017 at 9:59 AM
    #2210
    Nitori
    Maricopa AZ
    2021 T4R SR5
    My thoughts are the re-torque is the Toyota cost effective method of saying "F*** it, close enough" - as in, if it's not a problem now, don't worry about it because the studs are "probably" fine.
    Let's not forget that replacing every last set of diff studs and gaskets gets expensive fast, because it requires removal of the 3rd member.
    also AAAAAAAA I DIDN'T SAY PINION HOWL, why does everyone keep going back to pinion howl?!?!
    That's the point I've been trying to make!! I've been told that side gear loading does sometimes cause a howl on decel...
    Hmmm, one would think that stretched bolts would inevitably lead to gasket failure... I dunno though, I have no idea how sensitive the side gears and axles are to depth vs how much "slop" can a gasket take up.
    If a gasket can take up 1mm of play without leaking but axles misaligned by 0.5mm causes noise, it might still be the cause. However, if the tolerances are the opposite then that theory is completely out the window.
  11. Apr 28, 2017 at 10:05 AM
    #2211
    Bob_S
    Bob_S Well-Known Member
    2016 TRD OR 4x4 DCSB
    None yet
    Mine does it. Along with clanking slowly over speed bumps, leaking rear diff (not on vin list for recall), terrible brakes. What fun this truck has been.
  12. Apr 28, 2017 at 10:11 AM
    #2212
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I posted a video I don't know how many pages back of both my old howling differential and the new one they gave me howling. Might try searching on youtube for 2016 tacoma differential noise. I'll try to find them later and repost them.
  13. Apr 28, 2017 at 10:19 AM
    #2213
    0210
    Vancouver, BC
    Thanks. Found your videos in these posts:
    https://www.tacomaworld.com/threads...thering-throttle.442341/page-36#post-13082394
    https://www.tacomaworld.com/threads...thering-throttle.442341/page-46#post-13174957
    Definitely not the sound I heard in mine. I guess that's good news? :/
    Tacoma2166 likes this.
  14. Apr 28, 2017 at 10:23 AM
    #2214
    ToyoMann
    485 Hz. Were you going about 58 mph?
  15. Apr 28, 2017 at 10:24 AM
    #2215
    shakerhood
    Southern Ohio
    There is a whistle sound that comes from the front and is the Lower A Arms, there is a TSB to plug the holes, may possibly be what you are hearing.
  16. Apr 28, 2017 at 10:55 AM
    #2216
    Tacoma2166
    Tacoma2166 Member
    2016 TRD Sport 4x4 V6 MT
    Clazzio Seat Covers, UnderCover Tonneau, Raptor Nerf Bars. OEM Bed Mat
    Mine sounds exactly like the video. I have a MT, when I put into neutral howl goes away. Back into gear and the howl is heard again. Also, inspected this morning, noticed I have rear diff leakage. My VIN is not on the list, but it's my understanding the list hasn't been completely updated?
  17. Apr 28, 2017 at 11:18 AM
    #2217
    0210
    Vancouver, BC
    Thanks, but no. I had the LCA whistle before and have since had the TSB done.
    shakerhood[QUOTED] likes this.
  18. Apr 28, 2017 at 12:29 PM
    #2218
    aero90
    Yep, right on the money. 58-59 mph.
    shakerhood and ToyoMann[QUOTED] like this.
  19. Apr 28, 2017 at 1:03 PM
    #2219
    cgalloni
    cgalloni Well-Known Member
    I can't believe there are so many people complaning about this issue (including me) and Toyota has not been able to fix it.
    shakerhood and 48boot like this.
  20. Apr 28, 2017 at 1:18 PM
    #2220
    mbtex
    mbtex Well-Known Member
    Pearland Texas
    94 4X4 Exc Cab, 2017 DCSB TRD OR, 2023 DCSB TRD OR 4x4
    I may have heard one time briefly but it was only when I had a full load of passengers. Have not heard since.
