3rd Gen Poll: Rear End Noise howling when feathering throttle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 21, 2016.
Does your rear end make a slight howling noise at 50-65mph when feathering throttle?
  1. Yes
  2. No
  3. Have not checked it yet but will report back
Results are only viewable after voting.
  1. Sep 11, 2017 at 9:19 PM
    #2901
    Kj15991
    Kj15991 New Member
    Kyle
    2017 tacoma or
    2017 double cab off road with 6 speed manual. Howling line crazy at 6000 miles. Dropped off at dealer today. Will report back
  2. Sep 11, 2017 at 9:34 PM
    #2902
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good luck with it.
  3. Sep 11, 2017 at 9:40 PM
    #2903
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    Same here.... I'm at 3500 miles and it's getting progressively louder every day. I'm taking it in for the 5K service in a few weeks and will see what they have to say about it... Having done my fair share of re-gears, I'm 98% sure it's just a bad setup/pattern on the gears.
    GPsevinSixx likes this.
  4. Sep 11, 2017 at 9:47 PM
    #2904
    EMT760-
    EMT760- Well-Known Member
    17 Tacoma TRD Offroad 4x4 DCLB
    What mileage have u guys changed your differential fluid at? I was going to change mine at 500. Some on here said that is " too early" so I'm doing everything at 1,000.
    I'll be using Amsoil 75w90 severe gear.i have a faint whine at 50-55 mph.
    I took it to two different dealers. They all claim " fluid is within spec. Test drove another TRDOD which produced the same noise". Their narratives were almost identical like a script. But the other dealer didn't even have me in their system. So I wanted my own test to remain accurate without conflict of intetest....very interesting
  5. Sep 11, 2017 at 10:26 PM
    #2905
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Never changed mine. Totally unnecessary to change it.
    MasterPenguins likes this.
  6. Sep 11, 2017 at 11:10 PM
    #2906
    Jerrfylube
    CA
    30K is the normal service interval and while it certainly won't hurt to change it after initial break-in, it's totally unnecessary. In this case, changing the oil early isn't going to prevent the howl--bad gear setup is bad gear setup and no amount of snake oil is going to fix\prevent it.
  7. Sep 12, 2017 at 12:35 AM
    #2907
    smitty99
    Scottsdale
    Nailed it.
  8. Sep 12, 2017 at 9:31 AM
    #2908
    EMT760-
    What other option do I have when Toyota states " normal operation. Test drove another 4x4 TRDOR".
    I'd have to pay for a independent shop to confirm the noise.
  9. Sep 12, 2017 at 9:40 AM
    #2909
    Jerrfylube
    CA
    Find another dealership or, like you said, pay an independent shop for a diagnosis...
    specter208 likes this.
  10. Sep 12, 2017 at 9:44 AM
    #2910
    EMT760-
    I've been to two different Toyota dealerships. Both stated almost identical reports on the service paperwork. Almost like a script.
    I did this to avoid conflict of interest. It seems that now they just " cover up" no matter what.
    My guess is a memo floating around not to replace anymore rear differentials. Could be wrong though.
  11. Sep 12, 2017 at 10:01 AM
    #2911
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Just did my 5k service. Told service adviser about the whine, he mis-heard me and wrote 55mph - 65 mph on the service sheet. I didn't correct him as he said they were busy and if they had time they would take it out for a spin. He noted this is the first he heard of it.
    Got done, service adviser told me they took it out and heard the noise, technician initial thought was it is a wind noise. I could schedule back as they were busy and they could start troubleshooting it with 2 technicians. One to drive and the other one to pinpoint the noise.
    I told him I wasn't concerned and would have them do it at the 10k service. Hoping that the rumored TSB fix is released before the 10k service. Checked my paperwork, didn't mention that the noise was confirmed, also the noted speeds were corrected (55-60 mph).
    All my driving is below or above the range speed. I hear it once a day on a offramp going home.
    Had some free time, checked the lot of Tacoma. The DCSB OR all had 1-2 degree shims between the leafsprings and axles. None of the Sports, both SB and LB had them. There wasn't any LB OR to check.
  12. Sep 12, 2017 at 10:20 AM
    #2912
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Any pictures of said shims? 0.o
  13. Sep 12, 2017 at 10:24 AM
    #2913
    Critical05
    2017 DCLB TRD OR
  14. Sep 12, 2017 at 10:34 AM
    #2914
    specter208
    California
  15. Sep 12, 2017 at 10:36 AM
    #2915
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    That was the initial theory, but many here who confirmed they have the shim installed from factory and have the howling. I'll have to check mine today (build 3/17) and see if it has shims.
  16. Sep 12, 2017 at 11:14 AM
    #2916
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I rotated my tires last Saturday and noticed the howl is now subdued. Almost to the sound levels of my first diff, which is much more manageable.
    They rotated my tires at 5.5k service but not at 7k when the diff was replaced. I rotated my tires at 10Kish.
    I'll keep and ear on it and see what happens. Might not ever rotate my tires again...
  17. Sep 12, 2017 at 11:17 AM
    #2917
    shakerhood
    Southern Ohio
    My truck (3-17) has those shims too and I also rotated my tires and the sound is the same.
  18. Sep 12, 2017 at 11:21 AM
    #2918
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    The shims started popping up in the 17s but I've read on here that they don't have a part number for them..which seems weird.
    I think that's more for the rumble strip vibration issue
    shakerhood likes this.
  19. Sep 12, 2017 at 12:39 PM
    #2919
    nDub
    Lead Free Gasoline
    1/2017 build date for me. No shims. No rumble strip feeling either though, so I'm good.
  20. Sep 12, 2017 at 5:27 PM
    #2920
    2017OR
    2017OR Well-Known Member
    2017 TRD Off-Road
    TRD exhaust, Pro Grill, Access Tonneau cover, TRD Pro wheels, BumperShellz, Pro shift know, Yota LED grille lights
    I have the shims on my OR and the howl. Shims are not the remedy.
