3rd Gen - Quad LED Projector Retrofit
Discussion in 'Lighting' started by MESO, Jul 6, 2017.
  1. Jul 7, 2017 at 1:50 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    :hattip:
    ChadsPride likes this.
  2. Jul 7, 2017 at 1:59 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
  3. Jul 7, 2017 at 2:00 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    :cheers:
  4. Jul 7, 2017 at 2:06 PM
    tcjacado
    tcjacado Well-Known Member
    Very nice!
  5. Jul 7, 2017 at 2:13 PM
    MESO
    State of Jefferson
    Thanks guys. I usually stick to tails, but when I saw these LED projectors available(I'm an LED whore) I couldn't resist doing a build with them. BTW, here is how bright the new Amber DRL strip is (compared to the OEM white one, which is still plenty bright)
    duece5811, djginji, DUBENZ and 3 others like this.
  6. Jul 7, 2017 at 2:31 PM
    tcjacado
    You are going to get me divorced I swear. :rofl:
    Do you have a lay away plan. Lol
  7. Jul 7, 2017 at 2:41 PM
    AsianAnts
    AnT
    or lawyers......;)
    ChadsPride and tcjacado[QUOTED] like this.
  8. Jul 7, 2017 at 8:51 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Looking forward to the finished product.
    ChadsPride and MagneticTaco4x4 like this.
  9. Jul 8, 2017 at 12:37 AM
    iBoosted
    iBoosted It's go to be the king
    Niko
    Mesa, Arizona
    2017 BBP Tacoma TRD Off-Road 4x4
    TRD PRO Front Grille Icons stage 3 lift Icons Billet Upper Control Arms Method Roost's Toyo Tires Caliraised Ditch Lights Caliraised Rear facing amber lights Caliraised Fog Lights Interior: Many Patches Greyman Tactical Rigid Insert Molle Panel
    Want
  10. Jul 8, 2017 at 5:52 PM
    MESO
    State of Jefferson
    did some updates. Post #2
  11. Jul 8, 2017 at 6:47 PM
    MagneticTaco4x4
    MagneticTaco4x4 Well-Known Member
    2017 Tacoma
    pics?
  12. Jul 8, 2017 at 6:49 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Check post #2 of this thread.
  13. Jul 8, 2017 at 6:56 PM
    MagneticTaco4x4
    2017 Tacoma
    DAMN! That looks badass. How do the cut off lines affect the brightness when you switch to high beam though?
  14. Jul 8, 2017 at 8:09 PM
    WhiteBeltBatman
    WhiteBeltBatman Well-Known Member
    Bay Area, CA
    2017 Super White TRD Pro
    Solid work as expected! I prefer the smoked look of the DRL vs the all-amber, only because I mostly consider how it looks when the truck is parked and electronics are off.
  15. Jul 9, 2017 at 7:15 AM
    #35
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I would rotate those angry halos a little more counterclockwise from your mockup to get the look you want
  16. Jul 9, 2017 at 8:56 AM
    #36
    MESO
    State of Jefferson
    I have seen them done like that. For a single halo I think it looks good. But with 2, I want the "cutoff line" to taper down at the same angle. Also trying to follow the lines of the inside headlight bezel. Which would mean the inner halo will have more black covering it. Idk, I'll wait until I have them in hand and play around with different designs. Appreciate all the input!
  17. Jul 9, 2017 at 9:03 AM
    #37
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Looking killer man
    :jellydance:
  18. Jul 9, 2017 at 9:06 AM
    #38
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    wow thats bad ass
  19. Jul 9, 2017 at 9:17 AM
    #39
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Very cool
  20. Jul 9, 2017 at 10:57 AM
    #40
    MESO
    State of Jefferson
    If you're having Permaseal problems I feel bad for you son.
    No heat, no solvents, no problem. Just a flat head screwdriver and some patience.
    Here is the result. Factory clean channel!:D
    You can see the before/after the OEM permaseal is still at the bottom.
    Here is how I do it. Your technique may vary. Pull on the sealant with one hand while using the flat head to "roll" it out of the channel. (sorry for video quality, I was trying to film and do it at the same time)
    https://player.vimeo.com/video/224846606
    P.S.: I have found 295° @ 15min is the magic number, and these things pop right open.
