3rd Gen - Quad LED Projector Retrofit
Discussion in 'Lighting' started by MESO, Jul 6, 2017.
  1. Jul 9, 2017 at 11:12 AM
    #41
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Do you turn off the oven when you put them in? Or keep the heat on?
    P.S. Love your projects
    ChadsPride likes this.
  2. Jul 9, 2017 at 11:16 AM
    #42
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Thanks man. I love tinkering and working on little projects like these, and happy to share my journey.
    No. Preheat oven... when up to temp set 1 in. Leave oven ON for 15min.
    Take out and work quickly. Start with going around the entire perimeter of the headlight with a flat head "breaking" the seal. This helps A LOT. Then start prying it open.
    duece5811, eccracer104 and ChadsPride like this.
  3. Jul 9, 2017 at 11:21 AM
    #43
    Rome604
    Dave
    Alexandria, VA
    Cool thanks. I'm slowly trying to grow my confidence to try cracking mine open.
  4. Jul 9, 2017 at 6:43 PM
    #44
    ChadsPride
    Sponsored by TacomaWorld.com
    Bump
    WhiteBeltBatman likes this.
  5. Jul 9, 2017 at 6:47 PM
    #45
    MESO
    State of Jefferson
    Waiting for the sun to go down so I can get them aligned. In the meantime, I'm digging the madmax look
  6. Jul 9, 2017 at 6:48 PM
    #46
    ChadsPride
    :bowdown::bowdown::bowdown:
    tcjacado, eccracer104 and RigginsTaco like this.
  7. Jul 9, 2017 at 7:16 PM
    #47
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    moe2o4, PvilleJohn, tcjacado and 2 others like this.
  8. Jul 9, 2017 at 7:16 PM
    #48
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah... Cause this really needs it. You so silly
    Fortunt1, tcjacado, MESO[OP] and 2 others like this.
  9. Jul 9, 2017 at 7:19 PM
    #49
    ChadsPride
    It did! :wink:
  10. Jul 9, 2017 at 9:29 PM
    #50
    MESO
    State of Jefferson
    The famous "OMG LOOK HOW BRIGHT these are" front pic
    My guesstimate adjustments were pretty close, end result:
    (There are 4 cutoff lines!!!)
  11. Jul 9, 2017 at 9:34 PM
    #51
    memario1214
    Colton
    Missoula, MT
  12. Jul 9, 2017 at 9:40 PM
    #52
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    We need video driving and showing highs and lows!
    duece5811, tcjacado and ChadsPride like this.
  13. Jul 9, 2017 at 9:43 PM
    #53
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    :devil: Evil Genius!!
    tcjacado, ChadsPride and MESO[OP] like this.
  14. Jul 9, 2017 at 9:45 PM
    #54
    MESO
    State of Jefferson
    For sure. I already popped them out and put my RX's back in. Just wanted to make sure everything was perfectly level/aligned before sealing them up.
    While I'm waiting on the halos, I need to fit the second shroud(using another set of OEM donor lights that I am cutting the shrouds out of) so they both will look stock.
    Then BHLM, some various wiring, etc
  15. Jul 10, 2017 at 9:17 PM
    #55
    MESO
    State of Jefferson
    Here is a a little OEM touch for you guys;
    Sacrificed some donors to extract the factory shroud. Now I can have a matching set in each headlight.
    Since the inside projector is offset, I whipped up an ABS "extension" so it would transition smooth to the outside shroud
    Violla! Fitment is spot on. The new shroud meets right up with the turn signal fins, no room to spare.
    Don't worry, it will all get painted
    duece5811, DUBENZ, tcjacado and 3 others like this.
  16. Jul 10, 2017 at 10:17 PM
    #56
    MESO
    State of Jefferson
    Or hydrodipped..:anonymous:
    tcjacado likes this.
  17. Jul 10, 2017 at 10:39 PM
    #57
    memario1214
    Colton
    Missoula, MT
    Youre gonna beat me to the punch and imma throw up!
  18. Jul 10, 2017 at 10:40 PM
    #58
    MESO
    State of Jefferson
    You're doing pink camo too??!
    :angrygirl:
  19. Jul 11, 2017 at 3:00 PM
    #59
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    This is turning out awesome.
    So many people gunna flash their brights at you though.
  20. Jul 11, 2017 at 3:13 PM
    #60
    MESO
    State of Jefferson
    Not if they are adjusted properly.
