3rd Gen - Quad LED Projector Retrofit
Discussion in 'Lighting' started by MESO, Jul 6, 2017.
  1. Jul 13, 2017 at 9:06 PM
    #101
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    So clean! Put some power to em!!!!
    ChadsPride likes this.
  2. Jul 13, 2017 at 9:06 PM
    #102
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    :hungry: :drool:
    ChadsPride and MESO[QUOTED][OP] like this.
  3. Jul 13, 2017 at 9:12 PM
    #103
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
  4. Jul 13, 2017 at 9:13 PM
    #104
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    You want them to WORK too?
    Never said anything about that...
    Malls have lights already in the parking lot.
    WildLand, eccracer104, BVita and 5 others like this.
  5. Jul 13, 2017 at 9:17 PM
    #105
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    HAHA very true. Truck will look great sitting in front of the Nordstroms!
    ChadsPride and tcjacado like this.
  6. Jul 13, 2017 at 9:19 PM
    #106
    MESO
    State of Jefferson
    After all these mods, I'll only be able to afford ROSS Dress for less.
  7. Jul 14, 2017 at 7:12 AM
    #107
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    holy cow:laser:
  8. Jul 14, 2017 at 9:06 AM
    #108
    Fresh6390
    Fresh6390 Well-Known Member
    TN
    17' Super White Tacoma DCSB SR5
    Are your halos going to be lit up amber or white when powered? Where did you get the halo rings from since they fit perfectly? And I'm assuming to achieve the half amber halo you blacked out portion of halo ring and just tinted the remaining amber?
    I'm trying to figure out a configuration for my SR5 headlights. I know I will black out with satin black and light smoke amber reflectors. Probably leave turn signal and high beam location chrome since I'm not as talented as you (and want functionality). And just have the amber DRL and half amber halo ring on projector. Probably look good, right?
  9. Jul 14, 2017 at 9:19 AM
    #109
    MESO
    State of Jefferson
    The halos will be Amber when powered. They will not be my DRL, but wired to parking lights. So on for dusk/evening/etc. I sourced the lens from superbrightled.com they are 80mm rings. They do not fit perfect, will require trimming on the OEM shroud.
    Correct, half of the ring was blacked out completely to give the angry look, the lower half was smoke tinted.
  10. Jul 14, 2017 at 9:59 AM
    #110
    MESO
    State of Jefferson
    Woke up this morning and my 3D printer magically had a bunch of parts sitting there!
    So how do you seal off/watertight the back of a cut up headlight?
    A few options:
    Ghetto level: Plastic bag and duct tape
    Novice level: Home depot rubber plumbing boot
    Mesojdm Level: Designed and Printed custom cap which still accepts the OEM rubber grommet
    (**this is my test bucket, disregard the hole on the side)
  11. Jul 14, 2017 at 10:07 AM
    #111
    ChadsPride
    Sponsored by TacomaWorld.com
    So legit!
    1bad2k and MESO[OP] like this.
  12. Jul 14, 2017 at 3:57 PM
    #112
    Fresh6390
    TN
    Thanks for always replying. Last question (probably not) How can I achieve an amber/amber switchback halo ring? I've seen the morimotos white/amber switchback halo rings, but I don't want white just amber. Any suggestions? Thanks in advance
    TRDPugz and ChadsPride like this.
  13. Jul 14, 2017 at 5:11 PM
    #113
    MESO
    State of Jefferson
    ^just use a single color Amber halo, and use a switchback driver.
    Got the back of the housings all sealed up. May not look like much, but damn the OEM bucket has so many curves/weird elevations it took some time to get the covers to fit perfect.
    They were plastic fused to the buckets, then I went over the entire thing with black silicone for added moisture security. Doesn't look pretty, but they are bomb proof.
  14. Jul 14, 2017 at 10:13 PM
    #114
    MESO
    State of Jefferson
    Another change yet again before they get sealed up.
    Wasn't too fond of the marker being side illuminated, so I soldered some strips together to sit directly in the channel.
    Mucho better. Look more like plasma beams now.
    I am running them as side turn signals as well. Wiring them to the Parking lights with a PWM(to dim them) and so they''ll still flash to bright for turns at night.
    duece5811, SuperBad, TacoWave and 4 others like this.
  15. Jul 15, 2017 at 7:48 AM
    #115
    Jakoda
    Jakoda beep boop
    Jackson
    SoCal
    2017 TRDOR DCSB
    Bunch O Shit
    this is too friggin legit please don't quit
  16. Jul 15, 2017 at 8:16 AM
    #116
    MESO
    State of Jefferson
  17. Jul 15, 2017 at 10:10 AM
    #117
    ChadsPride
    So custom, mad props OP!​
    1bad2k, eccracer104 and MESO[OP] like this.
  18. Jul 15, 2017 at 10:38 AM
    #118
    MESO
    State of Jefferson
    I just do it for the chadspride likes :thumbsup:
    duece5811, Rome604, 1bad2k and 2 others like this.
  19. Jul 15, 2017 at 10:44 AM
    #119
    ChadsPride
    :rofl::rofl::rofl::rofl:
    eccracer104 likes this.
  20. Jul 15, 2017 at 11:35 AM
    #120
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    HAHA yes
