3rd Gen Reliability experience from owners so far
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Codester, Jan 12, 2020.
  1. May 4, 2023 at 7:21 AM
    #221
    SlizzyMcSlizFace
    SlizzyMcSlizFace Well-Known Member
    New Hampshire
    2020 Black Tacoma TRD Off Road
    I've got a 2020 OR purchased new and have around 46,000 miles.
    It's been great so far, with the exception of water leaking through the top driver side of the front windshield. I had thought it was from the Cali Raised roof rack since I did not use silicon to seal the mounting holes, but upon doing a cup of water pour test, I discovered the open seal was where the weather strip meets the top of the windshield. The water dripped all the down the A-pillar and down some electronic relays and wiring behind the passenger kick plate. Luckily the only thing that seemed damaged was the bed light relay that I took out, dried out, and put back in. I cleaned the dripping water and sealed the top of the windshield with silicon. Now there is no more leaks! I think I caught it early enough to avoid worse electrical issues. But I always still check it during/after a big rainstorm.
  2. May 4, 2023 at 7:38 AM
    #222
    BJamesBeck
    BJamesBeck Well-Known Member
    Illinois
    2016 TRD OR Magnetic Gray Metallic
    I am the 2nd owner of my 2016 OR DC AT. I'm at 99k miles now and have had no real issues (nothing but scheduled maintenance listed in the vehicle history report).
    Third brake light TSB was covered shortly after I purchased the truck.
    Planning to replace the door check in the driver's side today which sounds worn out.
    Otherwise just standard scheduled maintenance.
    turbosnail likes this.
