3rd Gen Remote Start Using OEM Remote
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickj718, Dec 7, 2016.
  1. Dec 29, 2016 at 8:06 PM
    #701
    GoGoStAm
    GoGoStAm Well-Known Member
    George
    2016 WHITE TRD SPORT DCSB
    Just to make it clear: the 2 auto lights wires are not there to make the car headlights go on when remotely started, they are there to make sure your headlights go off
    when the car shuts down from the remote start session
  2. Dec 29, 2016 at 8:10 PM
    #702
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
  3. Dec 29, 2016 at 8:15 PM
    #703
    nickj718
    nickj718 [OP] Well-Known Member
    Nick
    2016 Tacoma TRD Sport
    Nailed it
  4. Dec 29, 2016 at 8:27 PM
    #704
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I normally leave the headlight switch on the parking light. I then switch on headlights when I need them then turn them off when I'm done. I never use auto
    Will this act the same as off or does the switch need to be in off position if wires are connected?
  5. Dec 29, 2016 at 8:31 PM
    #705
    nickj718
    Nick
    If you don't leave the switch in auto it will leave the parking lights on along with the fogs when the remote start turns off till the door is open
  6. Dec 29, 2016 at 8:38 PM
    #706
    ratcityrain
    Seattle, WA
    Sounds good. All makes sense now.
  7. Dec 29, 2016 at 8:56 PM
    #707
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We're going to get a new unit out to @bdaniel
    Frogsauce likes this.
  8. Dec 30, 2016 at 4:56 AM
    #708
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Maybe so, but they probably assume you have already applied power to the unit before plugging it in. I put it all together, plugged it in, and then reconnected the battery. At least a couple others have done the same thing and reported theirs worked fine as well. Even in your install video you mention nothing about which one to plug in first. It appears you did the same thing I just described, bud.
    https://youtu.be/8nWCX6QY1Ms?t=187
  9. Dec 30, 2016 at 5:00 AM
    #709
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    Does this only apply to those with auto lights? I do not have auto lights, but leave my lights set on drl.
  10. Dec 30, 2016 at 6:01 AM
    #710
    nickj718
    Nick
    You have installed how many remote starts?
  11. Dec 30, 2016 at 6:03 AM
    #711
    nickj718
    Nick
    You have to turn the switch to off. If left in any position they will stay on when the remote start turns off
  12. Dec 30, 2016 at 6:16 AM
    #712
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    4 but what's that got to do with this? All I've tried to do here is help the people having an issue and you swoop in an attack my attempt to do so. If what I did was "wrong" then you need to update your video because it is also "wrong", despite the fact that it worked fine for both of us.
    Drop your issues bud and start trying to help people.
  13. Dec 30, 2016 at 6:27 AM
    #713
    nickj718
    Nick
    Directions state the plug sequence. Notice in the video it says refer to directions!
    Your not helping anyone by saying what you did. You didn't follow the directions! Sure maybe nothing happen to yours but what happens when incorrect plug sequence effects them?
    opentang likes this.
  14. Dec 30, 2016 at 6:32 AM
    #714
    MVBassYak
    MVBassYak Well-Known Member
    NeverNeverland MA
    2016 MGM TRDOR DCSB
    I used the 20-22's and they worked fine. I do think the 24-26's are the "proper" size but the 20-22's work well.
  15. Dec 30, 2016 at 6:34 AM
    #715
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Whatever, back to my original post.... @Kennedyusmc did you check the ground crimp and was the battery disconnected when you originally plugged it in?
  16. Dec 30, 2016 at 8:00 AM
    #716
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Is anyone going to help me with the ghost that's in mine?
  17. Dec 30, 2016 at 8:04 AM
    #717
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Yes, I actually redid the ground crimp because it fell off. I recrimped and soldered it into place.
    I attempted a soft reset last night, though the instructions say to plug in a 4 pin harness while holding the reset button. I don't have said harness.
    Either way, it settled down... I was cold and assumed that fixed it.
    Got up this morning and went to tidy up the harnesses. When I picked up the unit it started again. I thought maybe there's a bad connection in the module. I stuffed it away, it settled again for 10 minutes, then started again... there's gotta be something in the module here. FML.
  18. Dec 30, 2016 at 8:10 AM
    #718
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We'll get a new module out to you and see if that fixes it.
  19. Dec 30, 2016 at 8:12 AM
    #719
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Nice. Hopefully that does it.
  20. Dec 30, 2016 at 8:15 AM
    #720
    nickj718
    Nick
    One thing to remember here is this is a electronic device. They are sensitive and sometimes you will get one that is just defective due to thousands made a year
    Either way we will get you right.
