3rd Gen Saggy Leafs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rgvaggie11, Nov 4, 2021.
  1. Nov 5, 2021 at 8:40 AM
    #41
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    maybe people with blocks just steamroll over everything because they have a lift causing the springs to wear out
  2. Nov 5, 2021 at 8:47 AM
    #42
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What leverage? I see zero reason blocks would put any extra downward force on the springs. I do see how they can put more lateral bending force on the springs due to extra leverage and subsequently increase the chance of axle hop.
  3. Nov 5, 2021 at 8:48 AM
    #43
    gudujarlson
    Minnesota
    I don't see why increased ride height would incite a driver to steamroll over everything. lol
    rgvaggie11[OP] and Speedfreak like this.
  4. Nov 5, 2021 at 8:58 AM
    #44
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
  5. Nov 5, 2021 at 9:08 AM
    #45
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I second this.
    cryptolyme and Red Alert[QUOTED] like this.
  6. Nov 5, 2021 at 9:23 AM
    #46
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    I simply haven’t experienced this. My Deaver AAL has settled 1/4” in a year and 27,000 miles of use. Further, if I did lose an unacceptable amount of the initial 1.5” lift, it couldn’t be simpler or cheaper to replace them.
  7. Nov 5, 2021 at 9:28 AM
    #47
    YF_Ryan
    Kent, WA
    I think the issue is if your leaf pack is already in really poor shape. Sticking a nice fresh U shaped AAL in a pack that is currently arched in the opposite direction isn't the best solution. But yes, an AAL added to keep the pack from getting into that situation should work!
  8. Nov 5, 2021 at 9:44 AM
    #48
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I see Texas license plates and palm trees… RGV bro?!?
  9. Nov 5, 2021 at 10:24 AM
    #49
    ALI3N_123
    Eric
    Austin, Texas
    Reynosa my G, there’s a badass leaf spring shop there.
  10. Nov 5, 2021 at 2:18 PM
    #50
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Most people don't know how to drive a leaf spring vehicle; no lift required.
    For example, most folks brake going over a bump. Under 'brake wrap' only half the spring is carrying the weight of the vehicle, making the bump twice as severe if they had let it run free.
    Same thing applies for accelerating over bumps.
  11. Nov 5, 2021 at 3:01 PM
    #51
    rgvaggie11
    rgvaggie11 [OP] Well-Known Member
    2017 Quicksand TRD 4x4
    Yessir! Mcallen Tx
    ALI3N_123[QUOTED] likes this.
  12. Nov 5, 2021 at 3:39 PM
    #52
    ALI3N_123
    Eric
    Austin, Texas
    Nice to see another member from our hood. There’s a guy from the Palmview area that lurks around from time to time…
    @Justanotherhemi get yo ass in here boye.
  13. Nov 5, 2021 at 5:21 PM
    #53
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I believe the flat look is a normal characteristic of the truck and I wouldn’t loose any sleep over it. Excessive bottoming out without a load may not be.
    First, U-bolts tight to 52lbs?
    Second I would make sure the part number on the aftermarket shocks matches the vehicle.
    Third, I would inspect the frame, bounce the rear bumper to check for any abnormalities, loose rivets, fasteners etc.
    Fourth, a spring leaf(s) may have a hair line crack not easily visible without disassembly from vehicle, I would therefore take them to a re-build shop if any are near you, or just order a new set after exhausting/checking all other possible culprits.
    Good luck and let us know what you find
  14. Aug 24, 2022 at 12:57 PM
    #54
    MT_Advocate
    MT_Advocate Ramblin' In the Rambler
    Flagstaff, AZ
    2022 TRD Off-Road 6MT
    TRD Lift Kit; GFC; CaliRaised Trail Sliders
    Those RoadMasters work well for towing and DD but when taken off road they'll produce a terrible clapping noise when the vehicle starts to go down into a compression (aka, moguls). When the rear of the truck gets unweighted those springs will snap back pretty fast - I ran them on my Chevy Colorado for years but took them off when I would head off-road since they were so loud and seemed kinda dangerous.
  15. Aug 24, 2022 at 9:07 PM
    #55
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I haven’t noticed any problems like that when I have off-roaded. We’re you going fast when you noticed this?
  16. Aug 25, 2022 at 7:42 AM
    #56
    MT_Advocate
    Flagstaff, AZ
    It seemed like it happened anytime I was over 10 or so mph. Mainly it was when the truck hit the backside of moguls and started descending. It could also be that I used the thicker spacer when setting them up since I needed a lot of initial strength for my old rig.
    Regardless, this thread is really interesting to me since the initial sag on the springs is way more pronounced than on my Colorado. It's good to know that Tacos are just kinda built that way.
    Captqc[QUOTED] likes this.
  17. Aug 25, 2022 at 7:46 AM
    #57
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    It's widely known (& accepted) that Toyota uses wet noodles for leaf springs. You can add an AAL, new spring pack or a spring assist, as mentioned early in the thread. If you're keeping the truck long term, I'd go for a new spring pack with more carrying capability than the OEM noodles.
  18. Aug 25, 2022 at 11:52 AM
    #58
    gudujarlson
    Minnesota
    Widely believed by a vocal minority perhaps.
  19. Aug 25, 2022 at 12:43 PM
    #59
    Mad German
    2016 TRD Off Road
    :rofl:
