3rd gen Stalling in intersection.... UPDATE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cclogan8, Nov 7, 2016.
  1. Nov 30, 2016 at 3:07 PM
    #41
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Berlin or Prime?
  2. Nov 30, 2016 at 3:10 PM
    #42
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    I do that lots.
  3. Nov 30, 2016 at 3:11 PM
    #43
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Prime, if I had to do it over I would have purchased at Berlin, they were straight forward, nice to deal with, but prime is closer and bigger and convinced me they could get the truck easier than Berlin could. I think I got a better deal with prime in the end than I would have with Berlin as well
    PROseur[QUOTED] likes this.
  4. Nov 30, 2016 at 3:33 PM
    #44
    PROseur
    Pussy
    Hope you get it sorted!!
  5. Nov 30, 2016 at 3:52 PM
    #45
    Spare Parts
    Southern Maine
    Thanks, I'll pay closer attention now.
  6. Nov 30, 2016 at 3:52 PM
    #46
    tj714
    tj714 Active Member
    Tj
    2017 TRD OFFROAD DCLB 4x4
    Plasti dip
    This sort of sounds like an issue I had on my 16 Taco. The dealer said it was a faulty brake switch. This faulty brake switch made the Tacoma think I was pressing the brakes while accelerating causing it to go in to a limp mode while making a left turn in to an intersection. The truck would accelerate then cut off all the power while the accelerator was pressed.
  7. Nov 30, 2016 at 4:42 PM
    #47
    PROseur
    Pussy
    We want you alive and well
    Spare Parts[QUOTED] likes this.
  8. Nov 30, 2016 at 5:09 PM
    #48
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    Mine did the exact same thing today. I nailed the pedal to the floor to avoid some idiot and my truck "died" The RPMS were at+- 3500 but I wasn't moving an inch. Good thing the other driver realized I was there and didn't hit me. It was the most bizarre thing that has ever happened. I tried to replicate the problem the whole was home but I couldn't make it happen again...WTH?
  9. Nov 30, 2016 at 7:00 PM
    #49
    Cclogan8
    Cclogan8 [OP] Well-Known Member
    Logan, Utah
    16 Taco DCLB
    Its getting bad, Im almost broke.
    Come to a complete stop, then mash the gas, will most likely happen again. Its not every time, but it happens alot.
  10. Dec 1, 2016 at 3:17 AM
    #50
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Does it do it with traction control disabled? I know it's been asked multiple times but has anyone tried it? Instead of looking for the TC light to illuminate when the symptom happens, try reproducing the symptom when you know for sure TC is disabled.
    Does anyone know if TC is completely turned off when disabled or is it "kind of turned off" and will re-engage if it thinks we're being complete lunatics? Some vehicles will only limit how much nanny aids can be circumvented, not sure about the 3rd gen.
  11. Dec 1, 2016 at 4:30 AM
    #51
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    How sensitive is the inertia switch and accelerometer? If you swerve too quickly it cuts cruise control, and any sudden movements will activate VSS. Perhaps this is cutting fuel/throttle?
  12. Dec 1, 2016 at 5:07 AM
    #52
    Spare Parts
    Southern Maine
    I believe it is off, I have messed around a little bit, spun the tires basically. Once we get some real snow up here, I will know for sure.
  13. Dec 1, 2016 at 5:23 AM
    #53
    Cclogan8
    Logan, Utah
    16 Taco DCLB
    Ive turned traction control off. Still does it. Its definitely an error in the transmission computer and toyota absolutely knows about it. A brand new one off the lot will do the same exact thing. I've had it hesitate as much as 4 times across an intersection. ?I dont mash the gas much, but maybe 1 o3 2x a week i need to get on it and it royaly pisses me off. It is dangerous as well.
    kngharley likes this.
  14. Dec 1, 2016 at 6:16 AM
    #54
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
  15. Dec 1, 2016 at 6:26 AM
    #55
    TacoMan2017
    TacoMan2017 Well-Known Member
    I test drive a new Tacoma on the lot that did this. When getting out unto the busy road and turning right. Had to floor it and it basically the engine went limp. It did it another couple of times during the test, then it stopped doing it. Glad my new one has never done this...
  16. Dec 3, 2016 at 8:10 AM
    #56
    kngharley
    Corona, Ca
    Your not losing the throttle. The RPM's go up but its like the transmission goes into neutral
  17. Dec 3, 2016 at 8:36 AM
    #57
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    For all you manual guys in this thread I will talk about my experience. I have a large hesitation that occurs anytime I mash the throttle between 1500 and 2000 rpms. it's like the engine cuts out and then takes off again. I just try and avoid it by always keeping the revs above 2000.
    Now here is the strange part. my truck did this all last winter. Then last spring at sometime it completely quit. I tried and tried to replicate throughout the summer and it never once did it. Now the even stranger part. about a month and a half ago it started back up and I can replicate 90% of the time?
    Is it a coincidence that it happens when winter blend fuel is available? or is it temp related? Thoughts?
  18. Dec 3, 2016 at 8:47 AM
    #58
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My auto trans has always had a delayed kick down when I mash on it also it stutters if I mash on it from a stop. Figured it is just a characteristic of the TirdGen. Dealer told me it's normal
  19. Dec 6, 2016 at 3:06 PM
    #59
    NC_Mtn_Taco
    NC_Mtn_Taco Member
    Jordan
    2017 White Tacoma DCOR
    My truck was delivered yesterday '17 DCSB OR. Went to pull out of where I live today, where every now and then it requires a good punch on the accelerator and had this exact problem happen. Lagged for what felt like 2-3 seconds and had traffic laying on the horns. This needs to be addressed ASAP!
  20. Dec 6, 2016 at 4:51 PM
    #60
    Friggin Fuego
    That's a serious safety issue.
    Dawnpatrol likes this.
