3rd Gen Tacoma 3.5L Forced Induction Port Fuel Rail Group Buy
Discussion in 'Automotive Group Buys' started by JamesT, May 21, 2022.
  1. Nov 15, 2022 at 8:12 AM
    #101
    JamesT
    JamesT [OP] Well-Known Member
    2018 TRD Pro, MT
    It's common for the seals to expand when exposed to gasoline as well, which is likely what caused yours to pinch. Normally they should go in without issue, especially if oiled, but if swollen and dry can be troublesome to get seated. If they are swollen and just don't want to go completely in the boss, you can get it mostly seated, then use a very blunt thin object (like a flathead screwdriver, making sure it isn't sharp) to help coax the seal into the boss the rest of the way.
    I've had my rails in/out probably 2 dozen times, plus changed injector size, and very rarely had an issue with the seal seating properly. As long as you are careful it's easy to prevent. It was much more difficult to seat before I machined in the lip in each hole. Oiling the seals is absolutely required as well.
    rj_taco and virginiamarine like this.
  2. Nov 15, 2022 at 8:22 AM
    #102
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    I'm lucky that I had a pro install mine!
    JamesT[OP] likes this.
  3. Feb 26, 2023 at 6:53 AM
    #103
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    any reports back on how truck runs with these? are there any kits left?
    republic_of_texas likes this.
  4. May 16, 2023 at 5:53 PM
    #104
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Has anyone installed these rails yet?
  5. May 17, 2023 at 5:27 AM
    #105
    Zoey'sTaco
    Noah
    Dirty Jersey
    You just getting to it now? I know you said you were waiting till spring. Try PM'ing one of the guys earlier in the thread who have installed.
  6. May 17, 2023 at 6:29 AM
    #106
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I have a Maggy set with lines that I’ll let go for $250 shipped. Brand new, never installed.
  7. May 17, 2023 at 5:21 PM
    #107
    Pinchaser
    Alan
    Not exactly, more thinking than doing. I am considering WMI, and if I decide to pull the trigger on that, then the rails will install at the same time. Without a new tune, it seems these rails will even out fuel injection left and right, by making both sides over rich. Makes it easy to hold the install till there is a tune. No other feedback, so eh, will get to it eventually.
  8. Jun 30, 2023 at 1:31 AM
    #108
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Ive got a brand new set for the stock intake manifold setup. Can use with a Procharger Kit or in N/A form. $250 shipped. Will not work with Magnuson SC!
  9. Jun 30, 2023 at 2:09 AM
    #109
    JamesT
    2018 TRD Pro, MT
    The hoses for the factory intake are shorter. You cannot use them on the supercharger manifold. They will not fit. Additionally the factory kit comes with a 90 degree crossover. This will not fit the supercharger, which requires a 135 degree crossover.
    The supercharger kit can fit the factory manifold.
    The factory kit will NOT fit the supercharger.
    Torspd likes this.
  10. Jun 30, 2023 at 2:49 AM
    #110
    RedLantern
    Honolulu, Hi
    Thanks for those details. Original post has been edited.
  11. Jun 30, 2023 at 6:19 AM
    #111
    JustDSM
    Justin
    Ogden, UT
    I have a Supercharger kit w/lines and hardware. Never installed.
    $old shipped!
  12. Aug 9, 2023 at 6:24 AM
    #112
    Trush3
    Trush3 Member
    Tristan
    Twin turbo
    Yes wondering where I find these on the market place....bought a 16 Tacoma with the twin turbo setup already on it. Keep getting rich bank 1 and lean bank 2 and just recently threw an injector code so was hoping this would fix my issue. If not while I change injectors upgrade for later on more boost. Correct me if I'm wrong there. Still new to turbos.
  13. Aug 11, 2023 at 4:25 PM
    #113
    JamesT
    2018 TRD Pro, MT
    Rails are currently out of stock, but working to get more. There are a few sellers on here looking to re-sell though.
    If your port injection is the cause of the imbalance, then yes this will help correct that by converting from a linear narrow rail to a large bore parallel rail setup.
  14. Aug 11, 2023 at 6:17 PM
    #114
    Trush3
    Trush3 Member
    Tristan
    Twin turbo
    Not sure whats the issue just keep having a missfire on cylinder 6 and code reader says replace injectors but doesn't which.
  15. Aug 11, 2023 at 6:18 PM
    #115
    Trush3
    Trush3 Member
    Tristan
    Twin turbo
  16. Aug 11, 2023 at 11:10 PM
    #116
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    If you get back to us with various requested photos per our email convo that we've been having with you, we can help still
  17. Aug 12, 2023 at 5:23 AM
    #117
    Trush3
    Trush3 Member
    Tristan
    Twin turbo
    You never explained to what photos you would like to have k reached out to matt and sent him photos and he determined that I have the base turbo kit. From the photos I sent over to him.
  18. Feb 1, 2024 at 1:54 PM
    #118
    turboeverything
    turboeverything New Member
    2GR-FKS Camry
    Hi all. Noob here. are these kits still available? I would like to try these on a camry (fks) along with an Aeromotive fuel pressure regulator.
  19. Feb 4, 2024 at 3:28 PM
    #119
    JamesT
    2018 TRD Pro, MT
    The rails are designed specifically for the 2GR in the 3rd gen Tacoma. The tacomas have longer intake runners if I am not mistaken, so I can not guarantee any fitment outside that platform. That being said, I believe they might. One other gentlemen had a 2GR-fks in a lexus and he got a set. I didn't hear back about any fitment issues or success though. The mounts should be the same, as Toyota likely makes them similar across the board for injector height, but I am unsure of the clearance above the rails with the intake manifold. Also I am unsure of the hose fitment.
    As for availability, I have not had any for a minute, but I plan to have a 2nd generation set in the works here shortly. Most of my bandwith has been consumed with building a stronger engine for my test truck for development of high boost parts. I just finished setting the engine in today, and will hopefully do it's first start this week.
  20. Feb 8, 2024 at 2:24 PM
    #120
    turboeverything
    2GR-FKS Camry
    :eek::mudding:
    That truck is going to be awesome!
    Let me know if you do more. I'd like to buy one. If not I'll have to piece together a kit. Probably from radium and they haven't been very helpful. I'm still going through all the part numbers on multiple sites. Most p/n are the same for Tacoma, Camry, and Is350. The websites that show different p/n have the same pictures for both versions.
