3rd Gen Tacoma A/C Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dpippel, May 23, 2018.
  1. Aug 22, 2019 at 8:41 AM
    #261
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There was a TSB for 2016's that had the Dealer add plugs to the lower A Arms, starting in 2017 they already come plugged from the factory so your truck won't need it.
  2. Aug 22, 2019 at 9:06 AM
    #262
    dpippel
    dpippel [OP] Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    20K, but the problem has been there since Day 1.
  3. Aug 22, 2019 at 9:18 AM
    #263
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Now you’re justifying the entitlement.
  4. Aug 22, 2019 at 12:38 PM
    #264
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    yes he's entitled to whatever his little heart desires cause the AC is making a quote "sighing" noise unquote. [​IMG]
    stun gun[QUOTED] likes this.
  5. Aug 22, 2019 at 12:53 PM
    #265
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Mine does it too. It's not a sigh. It's a high pitch whistle. OR maybe similar to the sound a finger on a wine glass makes. Its only when the compressor I think runs and while under acceleration.
  6. Aug 22, 2019 at 12:58 PM
    #266
    BillsSR5
    bill
    2014 SR5
    you should make Toyota give you some Super Bowl tickets for your inconvenience you deserve better than having to live with that noise shame on them
  7. Aug 25, 2019 at 3:55 AM
    #267
    SixthToyota
    SixthToyota New Member
    2019 Tacoma TRD Sport
    Just signed up for this forum when I saw this thread. Traded in my 2015 TRD Sport for a 2019 and I am getting the annoying "Darth Vader' noise as it is described hear. 2015 had no noise. Will be heading to the dealer to discuss this. I am a long time Toyota owner and have never had any issues, so if someone has some constructive advice to tell the service dept, I would appreciate the help. (Such as a Service Bulletin reference, etc.)
  8. Aug 25, 2019 at 3:03 PM
    #268
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    My new one sounds like someone straining to breathe with a scuba mask on..but its ice cold
  9. Sep 2, 2019 at 6:03 PM
    #269
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    A DIFFERENT A/C NOISE?
    I figured I just hop in this thread so ...
    Sometimes I’ll here a noise when the a/c is on .. not all the time just a couple of time when I’m standing out side the truck with the a/c running the best way I can describe it sounds like a swamp cooler pump when the water level has gotten to low. Its not a slurping sound but more like the droning sound you’d here from inside the house when you no it needs water. A/c is cold , temp doesn’t fluctuate, it doesn’t “pulsate” to the sound in any way and I’ve only noticed it a few time. Other times I’ve been wiping my truck down real quick with a/c and everything sounds normal. When the charging system is low does it make a sound or just warm air. Cause that sound does sound like something is low but it’s not consistent enough and I know if I take it in it will be fine. I have the 100k extended warranty so I at least want it documented when I take it in for an oil change in case later it turns into something I’m covered. It’s a needle in a haystack but this forum is the home of serious Tacoma drivers so I always post here before I go in. Saves time and money. Thanks for any input bros
  10. Sep 2, 2019 at 6:21 PM
    #270
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    My 2019 makes the sound from the clip posted earlier. Usually under acceleration with the ac on. Other than that it gets down right frigid in the cab. No other sounds than the “harmonic” noise.
    BlazinBlueTaco likes this.
  11. Sep 2, 2019 at 6:38 PM
    #271
    djgynee
    Southern California
    Ya I posted a separate thread hoping to get feedback since this one thread is getting too deep in pages. Little things like this bug me when you’re not consistent but I appreciate the feedback bro thank you
  12. Sep 3, 2019 at 1:30 PM
    #272
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    Toyota is aware of this problem, they don't have a fix for it yet. You need to open a claim with Toyota motor corp and get it documented.
  13. Sep 3, 2019 at 1:53 PM
    #273
    Sequoia1321
    Sequoia1321 Well-Known Member
    Dallas, Texas
    2019 Tacoma SR Crew 4cyl
    I have opened a claim with Toyota regarding Darth Vader sound and the whistling sound. Will hear back soon.
    TRDPro916 likes this.
  14. Sep 3, 2019 at 4:17 PM
    #274
    TacoMike
    Pennsylvania
    I usually only run my AC in regular mode.
  15. Sep 8, 2019 at 5:28 AM
    #275
    Duff49
    Duff49 Well-Known Member
    Bucks County PA
    17 Sport TRD DCLB Barcelona Red
  16. Sep 8, 2019 at 8:15 PM
    #276
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
    Yes my brand new 2019 is doing this but only with AC on and the blower motor on the first two settings .... With the A/C off it stops immediately or if I go up to the high settings .....
    This is absolutely a joke if this is considered normal and the last thing I want is a dealer monkey tearing half of the dash out ..... So what is it exactly that is taking place here
    The blend doors opening or the mode selector motor moving or the blower fluctuating ..... Unacceptable for a brand new truck
  17. Sep 9, 2019 at 4:40 PM
    #277
    MyWifesTaco
    TRD pro grille .
    Thank you Duff for the link
    To be clear here the wooshing sound and the high pitched noise are two different sounds I am getting at two different times and yes sometimes they coincide only because the ringing resonance noise is only present while running on a incline or acceleration
    The wooshing and or "Darth Vader " sound only is present when the a/c is on and the blower motor is on the two lower settings
  18. Sep 9, 2019 at 6:07 PM
    #278
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    :yay:The whistling sound is a turbo that Toyota has installed in all Tacoma’s.
  19. Sep 9, 2019 at 6:21 PM
    #279
    daltondrose
    daltondrose Well-Known Member
    Dalton
    Forest Grove, OR
    2019 Tacoma TRD Pro Voodoo Blue, 2008 FJ MT Sand Storm / White
    • Victory 4x4 front Strike Bumper • Warn Winch Zeon 10 Synthetic • White Knuckle Offroad Rock Rails • Prinsu Full Rack System front and rear • ARB On Board Twin Air Compressor • Nitro 5:29 gears w ARB Air Lockers • 315 70/17 BFG KM3 • 17” Wheels KMC XD with Matching Spare • Decked Storage System • SnugTop Canopy with Windoors • Expedition One Rear Bumper with Dual Swing Outs • Baja Designs Rock Lights • Switch Pros SP 9100 • Victory 4x4 LED Light Bar • Front Baja Designs Driving Lights • Rear Baja Designs Flood Lights • Body Mount Chop (installed by Accessory Outfitters in Aloha, OR) • OME Rear LEAF Springs (soon Deaver Stage III w/ Archive Hammer Hanger) • Ride Rite Airbag System with Daystar airbag free floating cradle • Tailgate panel, Black Mountain Hatch • Tacoma Bed Stiffeners, Chaos Fab • Spindle Gusset, Chaos Fab • ICON 2.5 (58735c FR / 57805P RR) Suspension
    HOLY SH*T!!! I noticed both of these sounds in my truck and I was thinking to myself... "WTF???" Then... I started going down the what have I done to the motor to have caused those strange noises.... NOTHING!!! :rofl:That said... wtf?
  20. Sep 25, 2019 at 5:04 AM
    #280
    TacomaBeast67
    TacomaBeast67 Well-Known Member
    Calgary, Alberta
    2017 TRD Sport, Dbl Cab, Manual
    K&N Cold Air Intake, N-Fab Rock Rails, Removeable Steps, BAC Revolver X2 tonneau, 265/70/17, engine bay LED’s, Amber/clear strobes
    I’ve also experience the same high pitched intermittent sighing noise when AC is on, but even when off it will continue but become less frequent until it’s all quiet after about 4 days or so.
    I’ve had the noise for a while, maybe since driving it new off the lot 2 years ago (2017 TRD Sport, manual trans). Same identical noise as in post #33.
    I wasn’t too worried about it as I have the 200k warranty and the dealership has other things they are working on but I’ve mentioned it on my file now and yesterday took the shop quality assurance manager out for a test drive. Was able to make the sound happen several times but it was very quiet but told him it gets very loud. I will have to show him this thread. Thanks for creating the forum.
