3rd Gen. Tacoma Front, Rear Camera, Navigation Bypass, Homelink, Smartphone Mirroring Mod.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hoangde, Jan 31, 2017.
  1. Jul 11, 2017 at 7:35 PM
    #141
    bstrange
    bstrange Well-Known Member
    2017 Tacoma Off Road
    I got this cable but the only tihng im seeing is constant 12V on the black wire. how are you using it?
    Im hoping to wrap this up in the next week or so and I'll pot what I've done.
  2. Jul 11, 2017 at 7:45 PM
    #142
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    @Hoangde pin 13, 14. If I have a rca cable. Which part ie: center conductor to pin?? And the braiding pin ?? Can I just run 1 16awg wire from each pin to the camera. Cut the cameras rca off and hardwire it that way?
  3. Jul 11, 2017 at 8:06 PM
    #143
    bstrange
    13 would be the center pin. positive which is usually a red wire or center co doctor if coaxial.
    14 would be the return. negative which is black wire or braided shield.
    you can definitely cut the rca connector off and hardwire though the wires are pretty thin.
    Braves95[QUOTED] likes this.
  4. Jul 11, 2017 at 8:10 PM
    #144
    Braves95
    David
    Central PA
    So 15 cuts. Taps into 11 just splice into it? 25 splice to 12? This adds the aux button on the HU?
  5. Jul 11, 2017 at 8:27 PM
    #145
    bstrange
    yes sir.
  6. Jul 12, 2017 at 6:57 PM
    #146
    bstrange
    the video signal positive may be yellow
  7. Jul 12, 2017 at 7:22 PM
    #147
    Braves95
    David
    Central PA
  8. Jul 12, 2017 at 8:56 PM
    #148
    Hoangde
    Hoangde [OP] Well-Known Member
  9. Jul 12, 2017 at 9:16 PM
    #149
    Braves95
    David
    Central PA
    #65 page 4.
  10. Jul 12, 2017 at 9:33 PM
    #150
    Hoangde
    Here is your issues
    The switch that you bought is not double throws which in turn do not connect 12 v dc needed to turn HU to Camera mode. Look at the schematic again at that switch, noticed that required double throws switch and connect to 12v dc
  11. Jul 12, 2017 at 9:34 PM
    #151
    Braves95
    David
    Central PA
    Is there a way to make it work with that switch?
  12. Jul 12, 2017 at 9:40 PM
    #152
    Braves95
    David
    Central PA
    I can make the camera turn on. But reverse lights come. When I turn switch off goes back to screen and lights off. When putting shifter in reverse lights come on and camera comes on. But I put both wires together at switch to green wire. Black to ground. And red to battery. Then blue the dash light's.
  13. Jul 12, 2017 at 9:45 PM
    #153
    Hoangde
    Look at my post # 108 schematic
    To do so you needed a diode.
  14. Jul 12, 2017 at 9:48 PM
    #154
    Braves95
    David
    Central PA
    What diode? Size. And I forget how to tell which way it goes. Think the bands go which way?
  15. Jul 12, 2017 at 9:55 PM
    #155
    Hoangde
    Any 12 v dc Diode
    The band is connect to purple dot in that schematic
  16. Jul 12, 2017 at 9:59 PM
    #156
    Braves95
    David
    Central PA
    Doesn't matter the size? 100ohms 1k ohms. I haven't messed with diode's since the old satellite days.
  17. Jul 12, 2017 at 10:03 PM
    #157
    Braves95
    David
    Central PA
    Also is this something that can be picked up at a auto parts store?
  18. Jul 12, 2017 at 10:07 PM
    #158
    Braves95
    David
    Central PA
    So I cut wire 2. Put diode on. The stripe towards radio side of wire 2. Then tap wire from radio side wire 2 to switch green wire. Then red to fuse. The black to ground. Then blue to dash lights. Sound right?
  19. Jul 12, 2017 at 10:28 PM
    #159
    Hoangde
    @Braves95
    Easier just go to Radio Shack and ask for one diode.
    images_498ffe948bc74dc51d05019bd5ae3dbfbd155799.jpg Think green wire (power In) in the picture as number 2 in S1 switch, and (To Light(Device) as number 1 in S1 switch.
  20. Jul 31, 2017 at 2:26 PM
    #160
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    were you able to complete your mod? Could you share the stl file?
    Thanks.
